Question about Mitsubishi WD-60638 DLP TV
Mitsubishi WD-60638 DLP 60 inch. Replaced the bulb.... start the tv up and its fine. About 30 later the colors start to flash/flicker and there is a high pitched squeal.
  • Dan Caetta
    Dan Caetta Oct 11, 2013
    after a few minutes of the flickering the TV turns off.
SOURCE: wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Posted on Jan 28, 2009
mbelectronic
  • 147 Answers
SOURCE: Ok..I had to change the bulb in my 72 inch
the light engine has failed after on 30 min. replace light engine.
Posted on Sep 05, 2009
ladywinn
  • 5138 Answers
SOURCE: I just replaced the blub on a Mitsubishi 65 inch
Ballast Board 1-800-638-3328
Posted on Oct 21, 2010
eagle338
  • 4889 Answers
SOURCE: I replaced the bulb on my mitsubishi DLP WD-57732
The problem seems to be a malfunctioning DMD module. Do you still have sound when this haze appears? Are all the other controls such as volume up/down, channel up/down operational?
Posted on Jan 16, 2011
SD Tech
  • 14553 Answers
SOURCE: replaced lamp in my mitsubishi wd 60638 dlp but now I have a flickering picture
Sounds like a new lamp that is generic (not Mitsubishi) as the set does not know which lamp is in the set--works with one and not the other you have found your problem.
Posted on May 23, 2012
I have a mitsubishi tv model wd 60638 I changed the lamp. Tv works fine for about 20 minutes then I start to smell like something is burning then picture starts to flicker, what could could cause this
You have a bad connector in the lamp. Stop running the TV immediately and contact the company you purchased the lamp from. this is common in older DLP tvs but not in one 5 years old unless you have a lot of hours on it. the connector can crack and arc inside the plug and then melt and smell terrible. It usually very repairable if you can get a ballast for it. the plug is part of the ballast.
Aug 28, 2015 | Mitsubishi WD-60638 DLP TV
Wd60636
Never really had that issue the one I worked on Operated normally for 20 minutes and then shut down completely. The fix for that is to get the OEM bulb instead of the replacement
Jul 08, 2014 | Mitsubishi WD-60638 DLP TV
Can a MIrror in a Mitsubishi DLP tv be replaced with a glass one from my local glass shop?
Yes but it has to be cut perfectly and the ends have to have the same angle cut as the factory one or it wont be able to be properly secured inside the rear covers clamping assembly.
Feb 06, 2013 | Mitsubishi WD-60638 60-Inch 3D-Ready DLP...
I had to replace my lamp bulb in my mitsubishi wd-60638 tv and now i have a picture again but it is fickering and greenish tint to the screen
If you tried a cheap bulb then that might be the problem as some of the bulb carrage may not be complete4lyto spec. I had one that was close but there was a gap between bulb and where it fits. I went with a bulb dealer that had I believe a 1 year warrante and I have had no problems. I had a 73838 tv set.
Jul 26, 2017 | Mitsubishi WD-60638 DLP TV
WD-60638 COLOR WHEEL PROBLEMS
Usually the wheel is not available except with a Light engine.
Aug 31, 2012 | Mitsubishi WD-60638 DLP TV
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
Replaced lamp in my mitsubishi wd 60638 dlp but now I have a flickering picture
May 23, 2012 | Mitsubishi WD-60638 DLP TV
Mitsubishi WD-60638 DLP TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
