Lg gas dryer hs (or h5) code meaning?
  • 18 Answers
SOURCE: Sharp Copier AR-C270 Code Problem
jam in the fuser unit, try simulation 14
and/ or possible bad sensor switch actuating as tho paper is stuck in the fuser. check that exit switch is not stuck open or bad. if jam elsewhere , fuser will not allow operation untill jam somwhere is removed.
Posted on Jan 31, 2008
roadrunning1
  • 152 Answers
SOURCE: doesn't work get the code HS ?
check your filters and coils for blockages , both these codes are pressure related , if the filter is blocked the system will not create the desired environment for the refrigerant to work properly as it is directly related to increasing and decreasing temperature .
Posted on May 11, 2009
  • 760 Answers
SOURCE: Our Hayward gas heater keeps giving us a H5 error
Could the Error code be HS? That is high temperature limit. Perhaps you' don't have enough flow, allowing the heater to heat the water to a temperature higher, than the thermostat setting. Make sure your bypass valve is closed, allowing full flow through the heater. Check your filter pressure differential , and skimmer baskets.
You didn't give your model number, and there are many models. You can go the Hayward website below and select your exact model number and download the manual. The manual will explain each error code.
http://www.haywardnet.com/inground/products/manuals.cfm
Posted on Jul 05, 2010
  • 33 Answers
SOURCE: we are getting a code H5-01 what does this
H5-01 means there were five consecutive jams at the fuser section. Open the left jam door and look up in the fuser (heat) section and at the top of it You should find sheets crunched into an accordian After clearing all the paper from this area close up the copier Turn it on and press the copy mode key Then the following keys in order one after the other Program..*..C..* The display will change to service mode input 14 then the copy start key enter 1 for yes then the copy start key if the copier does not restart itself then hit the CA key the copier sholr reset and start with out the code
Posted on Jul 20, 2010
  • 4 Answers
SOURCE: error code H5-01
That is an easy one. That code means you had 5 jams at the POD1 sensor.
1) press #,*,C,*(enter simulation mode)
2) press 14, print, CA(clear all)
Should reset the copier to a normal state.
Posted on Aug 31, 2010
Lg dryer model# DLEY1201V what does error code HS mean?
Humidity sensor error code. Clean humidity bars below filter housing on inside of dryer.
Aug 15, 2017 | LG Dryers
We a "service" message on our Hayward gas heater h250fnd also error message HS or H5
the code is HS. it means that the maximum allowed temperature has been reached too fast. there are a few situations that may cause this. restricted flow is the most common
Mar 05, 2017 | Hayward Pool & Spa
I have a LG dryer model DLE5932W with a error code of HE
I'm sure you have fix the situation by now, but could the error code be a "HS" and not a HE? HS is a humidity sensor issue. often the metal strips below the filter on the inside of the drum are coated with fabric softener and cause issues. clean them with goof off or denatured alcohol will often fix issue. sometimes(rarely) one of the connectors comes off and causes errors. if you are still having issue, post a picture of the error code as a comment to your original post.
Aug 31, 2016 | LG Dryers
My Hayward H400FD is showing a H5 or HS error code, what does this mean, and what do i need to replace?
HS represents a problem with the temperature being too high. (maximum return water temp exceeded). this can be caused by a restriction in the plumbing system. i have that problem when i start my pool after a cold night. the water temperature rises too fast and the heater protects itself by flashing that code and turning off. reset the power to unit and it should work ok. if not, you may have to dig deeper as to why this code is being generated
Oct 02, 2014 | Hayward Pool & Spa
Pool heater throws code h5? smoked
HS
Water Temperature Sensing Error
A) Inlet water temperature sensor is reporting a temperature in excess of 104 degrees.
Normal operation resumes 2 minutes after inlet water temperature sensor reports temperatures of 104 degrees or less. This error functions in both normal and remote thermostat modes.
or
B) Inlet water temperature sensor is reporting a temperature change at a rate faster than 6 degrees in 60 seconds, indicating a potentially damaging low water flow conditon. Normal operation resumes when temperatures stabilize. If this condition is detected 3 times, the heater will lock-out until the electrical power is cycled off and back on.
Jun 10, 2014 | Hayward H Series Pool & Spa Heater...
What does this mean Hayward pool heater h150FDN gives us an hs or h5 error?
HS = High Limit Sensor
Heaters Maximum Water Temperature has been Exceeded.
A few reasons this occurs...
  • Low water flow thru heater, check :
    • Dirty Filter
    • Opened By Pass Valves
    • Plugged pump impeller
    • Dirty/Full baskets at skimmer or pump
    • Anything that may reduce water flow
  • Sensor could actually be doing its job, in a different aspect, Thermostat failure, and water is overheating in spa or pool?
But anyway, your heaters fault code you asked about is: hs, not h5
May 17, 2014 | Hayward Pool & Spa
Our Hayward gas heater keeps giving us a H5 error code and then shuts off. What does this mean?
Jul 05, 2010 | Hayward Pool & Spa
Doesn't work get the code HS ?
May 11, 2009 | Cfm Klimaire KSWG009H113 Split System Air...
sir there is no code of HS may be it is other code H4 or H2 so please write correct code
Oct 06, 2007 | Sharp AR-C270 Color Copier
Washing Machines Logo
134 people viewed this question
Top Washing Machines Experts
