Question about Continental Freezer Wide RefrigeratorFreezer reach in 57" wide two
Continental Freezer model F2 404A refrigerant not cooling properly. Replaced cap tube, and filter drier, evacuated, and charged. Box temp not going below 32' and ice forming at beginning of evaporator. Ambient 85 to 105', condenser temp at 30' above ambient, evaporator pressure 24 to 30 PSI. Nothing I have tried is improving the temp, or pressure. Customer irate. I used a BC1 cap tube (dual feed) at recommended length of 56' each. Did not work, shortened tubes by 1/3 = 19". Still the same. What else can I do?
  • Continental Master
  • 1,252 Answers
Check the compressor efficiency. See if it will pump down. In most cases, a good compressor will pull down to about 15" vacuum. Also, be sure that the refrigerant amount was weighed in and not done by pressures only.
Posted on Aug 08, 2017
2 Suggested Answers
  • 340 Answers
SOURCE: NEED TO KNOW SIZE OF CAP TUBE FOR A MODEL 3 F
call e-mail the manufacture if you can get the oem parts for the cap tube size I'd need the horse power of the compressor.
Posted on Jun 17, 2009
I have a 404-A Low Temp Freezer Box that will not pull down to -10. Stops at a box temp of 18 degrees. I have changed the Compressor , Expansion Valve, Driers, Triple Evzcuated three times. You cannot...
sounds like you covered most all bases. without knowing pressures, I would look for a possible restriction. Since the TXV was replaced, are you sure you went back with OEM? If refrigerant was weighed in, was the drier an oversized one? It's rare but I have found some units that just don't cool right with the factory weigh in charge. You may want to try to charge by pressures. If it has a condensate pan with a hot gas line, be sure it is dry before trying as this effects the pressures. Good luck. Looking forward to hear about the fix.
Jul 04, 2014 | Continental Manufacturing Company...
I have a freezer model #ffu17fc4cw2 upright commercial unit that isnt freezing. It worked before transporting but was transported laying down on its side. I was told that the freon may have leaked out...
Normally, laying a refrigerator down will cause any debris or sediment to float through the tubing and eventually end up in the filter drier which contains silica beads to absorb moisture. Debris will then plug up the drier. A technician will be required to evacuate the sealed system. He will then cut out the old drier and braze in a new drier and recharge the system.
There is usually no guarantee that this will fix it because if the debris is large, it may clog a capillary tube and render the unit un-repairable.
Dec 16, 2017 | Frigidaire 20.6 cu. ft. / 583 liter...
What is the normal operational pressure in lo/hi side at the compressor of commercial freezer like dispaly case, reach in cabinet or other any low temp refrigeration uses 502 or408A/404a. is there any rule...
why yes there is. Generally speaking, the head pressure should be around the "ambient +30" rule.
That is, measure the entering air temp to the condenser, say 75 degrees. Now add 30 to that and get 105 degrees. Look at a P/T chart and see what the pressure is for that temp which is about 253 for R-404-A.
The evap on a freezer leads the load so, as a general rule, the evap temp is going to be around minus 10 degrees to get a 0 degree box. Coolers are different. So, the pressure for a minus 10 evap is around 25 or so. But the unit has to be close to operating temp. If the box is warm, naturally the pressure is higher. And what influences the pressure is whether or not it's a TXV or a cap tube system.
If a TXV and no receiver, charge by subcooling. If a receiver, fill by sight glass. If Cap tube, charge by superheat.
Hope that answers your question.
Oct 03, 2010 | True 49 cu. ft. / 1388 liter Commercial...
Older kenmore freezer low in refrigerant charge of r-12.
There are some drop ins, but none are marketed for consumer products like this. Also, a new unit will use so much less electricity that you'd save enough money in a year or maybe two to pay the cost difference between the cost of recharge compared to new.
And....many times recharging units like this don't last long because they normally use a capillary tube in the system (instead of a thermal expansion valve). The cap tubes have a very small opening, and when the system is opened and recharged even very small contaminants can clog the cap tube later on and then the unit won't work.
Best bet is to get a new one.
Apr 04, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
I have a Frigidaire refrigerator with a top mount freezer, no ice maker. I have noticed that in really cold weather, the unit becomes less efficient, and in extreme cases, stuff in the freezer begins to...
When it gets very cold the gas (freon) in the refrigeration system shrinks....because the properties that make cold also work against you in this case...when the gas shrinks in volume it then does not work properly anymore...the hot gas does not turn back into a liquid but stays as a gas and because of that it does not cool when going through the expansion device...ie. cap tube or expansion valve. If you were to keep it in the cold all the time you could add a bit of charge to make it work, but then if you move it to warm or the weather warms... now you are over charged... just one of those "no win" deals...
They don't make these things to run in extreme environmental changes..they like it a consistent temp. all the time...
Heatman101
Jan 12, 2010 | Freezers
Normal Operating pressure for true 2 door Freezer R404A Room Under 80 degrees F Box at -10 degrees F
The pressures depend, somewhat, on the expansion device,i.e. a TXV or Cap Tube. Take a pressure reading, then convert it to a temperature. The evap temp should be right at 10 colder than the box temp. Remember, heat flows to cold so the evap has to "Lead the Load" in order to cool. In many cases, the condensing pressure is usually ambient temp, plus 30, then convert to a pressure. These are general accepted practices that have been used for many years.
Hope this helps
Jul 11, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Errattic temperatures in Freezer
Check out "victory-refrig.com" for manuals, diagrams, etc.
Cap tube systems are "critical charge systems". Can be difficult to get right. You did not mention pressures that you had. The split on the evap vs.box temp is almost always 10 degrees for freezers. If you want a -10 box, your evap needs to be -20. As a general rule of thumb, you want the high side to be "ambient +30". This seems to work most every time. Your problem might be operations related. Them leaving the door open alot and so on. It could also be a problem with the evap fan or the control to it. It could also be that since there had been a problem with the unit, they are now constantly checking it. Could be checking during a defrost cycle. When your box is at 0 degrees, your pressure should be about a -10 and no less that a -15 degree for the evap. You may have to babysit this thing and see how far it will pull down. You may have a weak compressor. Also, I have had many Hobart freezers fail due to dirty condensers. This causes the oil in cap tube systems to gel and clog up the cap tubes. The only fix is replacing the cap tube. There are alot of variables here so be patient, it's not going to be a quick fix. One last thing, since R404A can fractionate, you really need to pull the charge out and weigh in the correct charge with virgin refrigerant. This will eliminate 2 things. 1, it will ensure the correct amount of refrigerant and, 2 no chance of having a poor mixture of refrigerant in the system causing inconsistant readings and performance.
Hope this helps. And remember, cap tube systems are performance measured by the amount of superheat just prior to the unit making temp and cutting off.
Jan 07, 2009 | Victory Commercial Freezer VSF-3
Low suction pressure high head pressure
That system has a restriction. Most common at TXV valve or capillary tube. Will need to be replaced by Refrigeration company. In this video I replaced TXV valve and filter drier due to the same issue You have. Its Ice Machine, Low side was at 5 PSI, High at 250PSI : 404A; should be around 55-65 Low; 250 -275 High. Replaced drier and TXV, machine works proper.
May 19, 2008 | Hussmann Freezer 12 Facing Straight Glass...
Continental Freezer Wide RefrigeratorFreezer reach in 57" wide two Logo
159 people viewed this question
Top Continental Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Continental Freezer Expert? Answer questions, earn points and help others
