Question about Gevalia Coffee Makers & Espresso Machines
Need replacement filter basket - Gevalia Coffee Makers & Espresso Machines
    Top Expert:
  • Gevalia Master
  • 39,039 Answers
Gevalia may be able to supply a replacement or possibly you can get one from an appliance parts supplier
Posted on Oct 11, 2013
Have just bought a secondhand Ruby and replaced the blades and basket - still having problems with the basket collecting pulp (apples) and becoming noisy - unbalanced I assume. When I clean out the basket...
Hi Kathy, we had the same problem. You need to soak you basket overnight (every day) in a chlorinated solution/detergent. This will keep your filter basket clean. Also, make sure you rinse out your juicer if you know you are not going to use it much for a few hours as the pulp will dry up and clog your filter. Since adopting we started doing this we haven't had any more problems.
Feb 13, 2011 | Nutrifaster Ruby 2000 Juicer
The filter is filling w/ liquid instead of draining into the coffee pot.
The release button on the bottom of the grounds basket is not working or the small drain hole is plugged. Make sure that you are using the correct size #4 paper filters to hold the coffee grounds. Remove the basket and check to make sure that the release button is working freely. Put some water in the basket and push the bottom of the basket. The water should drain. If it does not drain, You will need to replace the basket assembly.
Check the carafe to make sure that the lid of the carafe is pushing the drain button up to release the liquid in the basket.
Let me know if you have any other questions. Thanks.
Jan 13, 2011 | Cuisinart DCC-1200 Coffee Maker
No pot or instructions, how much water do you put in the coffee pot?Need a replacement pot for vp17 series. thank you
You should be able to pick up a replacement/new pot at your nearest Restaurant Supply store. Make sure you get a 64 oz./ 1/2 gallon pot.
Before plugging in your brewer, unscrew the sprayhead located just above where the filter basket sits and replace the basket, pour 3 pots of cold water through the opening on the top if the brewer is empty. This brewer has a reservoir that holds about 2 1/2 pots of water at brewing temperature when heated. Make sure you put an empty pot under the filter basket after pouring in the water. Water will flow from the brew basket when the reservoir has reached its capacity. Once water flows you can then plug in and energize your brewer and replace the sprayhead. It will take about 15 to 20 minutes for the brewer to reach brew temp, you will hear the heating stop. Put an empty filter and a dose of coffee (I recommend starting with a heaping measuring cup of drip ground coffee) into the filter basket, lightly shake it level, replace the basket and pour through 1 full pot of COLD water in the top. For best results pour the brewed coffee into a pre-heated thermal server if you plan on holding the coffee for more than 10 minutes or so.
Enjoy!
Jan 04, 2011 | Bunn VP17-1 Coffee Maker
The coffee will go all over the counter. We did not get a manual with the coffee maker. Could I possibly be setting the pot incorrectly on the plate?
Check the following:
1. Make sure that you are using the correct size coffee filter in the basket. Only one filter is needed to allow proper drainage.
2. Check the spring loaded button on the bottom of the coffee basket. Remove the basket, put some water in the basket, push the button up to make sure the water is released from the basket.
3. Put the basket back in place, insert the carafe and check to make sure that the top of the carafe cover pushes up the button on the basket to release brewing coffee.
If all these check out, then there is an internal leak and the unit need to be repaired or replaced.
Aug 11, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
I have a grind and brew and can't get the grinding basket out to wash.
Open the reservoir lid. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use.
Sep 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Need to replace filter basket drip spout rubber ring
After searching for the replacement basket on web took whole coffee maker back to jcp and they replaced the 12cup coffee maker with a new item.
Jul 28, 2009 | Coffee Makers & Espresso Machines
No Suction + loud Noise
motor is probably is full of dust or needs replacing
May 11, 2009 | Vacuums
Lost rubber grommet in brew basket need replacement
You can order a new brew basket with grommet directly from Cuisinart - I would call them directly, but you can also order from their website - www.cuisinart.com
Jan 21, 2009 | Cuisinart DTC-975 Coffee Maker
Making Coffee
Ok lift the lid and inside you will see a brew basket (it will have a hole in the bottem middle of it) If this unit has a mesh type filter basket you will not need paper filters! you put the coffee in the mesh basket the replace before brewing! if you do not have a mesh basket you will need a paper filter to put down in the coffee holder!(the one with the hole in the bottom!) add coffee and waeter and brew!
I hope this fixes ya up!
Please rate my response!
THANK YOU!
Jan 16, 2009 | Kenmore DCC-KE12 Coffee Maker
Water not coming out of filter basket
Make sure the lid is on the coffee pot or the brew basket will be stuck in the closed position. If the lid is definitely on, replace the brew basket, because the spring may be faulty.
-Tha Mp3 Doctor
Dec 26, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
153 people viewed this question
Top Gevalia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Andrew Taylor
Andrew Taylor
Are you a Gevalia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
