Question about Euro-Pro EuroPro Shark V900TB Bagless Cyclonic Handheld Vacuum Cleaner with Turbo B
I put on a accessesorie and now it's not coming out from te Vacum
  • Euro-Pro Master
  • 18,392 Answers
Where is belt located on Hoover wind tunnel vacum. And how to replace it. My brushes are not spinning.
Its usually located underneath the body of the unit, turn it upside down and you should see the beater brush. You need to open the bottom cover to get at the brush and drive belt.
Mar 25, 2015 | Hoover U8126-900 Wind Tunnel Dual V...
How to replace vacum belt on new Sharp EC-TU5306
remove bottom plate and pull brush roll out. buy a replacement belt and follow procedure to put back on. sounds like you have a clogged hose also.
Jan 29, 2013 | Sharp EC-TU5306 Bagged Upright Vacuum
Motor noise and burning smell
your belt is of the guide arm try replacing the belt usually located @ the head of the vacum there should be 4-6 screws holding the head on remove it in well ventilated area try putting on mask cause you will release all the dust from the head when you take it apart you will see the belt around the brush remove the brush and bearings togther then replace belt if you know your model # of your vacum u can usually find replacement parts online or @ most sears and walmart outlets.
Jan 26, 2010 | Dyson DC14 Bagless Upright Cyclonic Vacuum
I recently put a new bag in my kirby and now when i turn it on, it will not pick up anything
see if you connected it or install it correctly, see if there is any leackage of air, see if it is air tight, the reason is that the air cannot vacum because there might be some open connection between the bag and the air exhaust of the vacum
Nov 01, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do i change from leaf blower tovac? vac will only blow i need to cahange it to vac mode
fell on top of vacum for the place where the air is being sucked in that is the vacum port put hose on this port
Oct 22, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
The suction in my vacum is not good. I changed
Depending on the type of vaccuum you may have another filter. I have a hoover and there is the hepa filter and another filter under the dirt container. If thats not the case, try taking off the entire hose and shaking it around. There may be stuff crammed in there. If one thing gets stuck, then everything else sticks to that. I had the same problem and when I took off the hose and shook it, a bunch of nails fell out (remodeling) and it worked fine after that.
Aug 19, 2009 | Vacuums
Change belt on bissell vacum cleaner model # 6850
On your Bissell 6850 you need to turn your vacuum over and on the front there is a brush with a cover. Remove the six screws, take the cover off and simply pull up on the brush, the belt is attached to the brush and will come off easily. Put back together in opposite order.
Jun 29, 2009 | Black & Decker Vacuums
Vacums
check belt not broken - could have happened when you caught tassle in head
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Euro-Pro EuroPro Shark V900TB Bagless Cyclonic Handheld Vacuum Cleaner with Turbo B Logo
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
