From any windows machine go to Start>Programs>Accessories>System Tools>Character Map. Here you will see all the characters you can use and select them to copy and paste elsewhere.
Hi
You probably have a multifunctional keyboard - so there is a key somewhere that is currently in its "on" state. It is usually located along the top or bottom of your keyboard and marked function / num.lock (numerical lock) or something similar.
Hope this helps
In messaging, you can change the symbols by pressing # key and choose if you want numeric,alpha mode ect. with this(hotkey),you can easily access your desire symbols or key in messaging.
The epson has a self cleaning program. press together the top buttons - power and maintenance key. and the printer will start a cleaning process. If you had installed the full sofware of the printer to your PC then you can also access the printer functions and do it fromt he PC.If this wont clear the issue, there could be a possible printing head damage. Hope you had used only the original ink and not the refilled ones.. Hope this helps. Good Day
You must have a different keyboard selected other than the standard US keyboard My numeral 6 has ^ on it and the numeric keypad 6 has a right arrow. One generally uses the SHIFT key to access symbols that are written above the main alpha or numeric key. The numeric keypad on side of PC has a button labeled key marked NUMLOCK that is engaged to allow use of the numerals as a calculator or to also be inserted into text.
CP315C/310CN/120C/115C/117C/110C (1) Press the (1) Press the Menu and Mono Start keys. Menu and Mono Start keys. Next press the key four times to make the machine Next press the key four times to make the machine enter the maintenance mode. enter the maintenance mode. (2) Enter 8 and 0 by using the and (2) Enter 8 and 0 by using the and Set keys.* Set keys .* (*To enter a numerical code on models having no numerical keypad, press the key several times to (* To enter a numerical code on models having no numerical keypad, press the key several times to display the numerical code to be entered and then press the display the numerical code to be entered and then press the Set key. Set key. Repeat this operation for each Repeat this operation for each numerical code.) numerical code.) (3) Press the (3) Press the Mono Start key several times until the purge count appears on the LCD. Mono Start key several times until the purge count appears on the LCD. (4) Enter 2, 7, 8, and 3 by using the and (4) Enter 2, 7, 8, and 3 by using the and Set keys to reset the purge count to zero.* Set keys to reset the purge count to zero .* (5) Press the (5) Press the Stop/Exit key to return to the initial stage of the maintenance mode. Stop / Exit key to return to the initial stage of the maintenance mode. (6) Enter 9 twice by using the and (6) Enter 9 twice by using the and Set keys to exit from the maintenance mode.* Set keys to exit from the maintenance mode .*
Hope this will give you hints. To pin point directly you need to replace printer head. But before replacing please consider suction cartridge caps or nozzle by cleaning and freeing clogged airways by dettaching manually. I understand that the long time being not used has caused the problem. However if you can still use black and other colors then used it than complicating downtime in repairing procedures. Yes, you are right no need to clean deeper more than three times it will consume inks half empty. Have a nice day.
if using XP go to my computer, right click>properties>hardware tab>device manager>look down list for keyboard, click '+' sign and highlight your keyboard and right click and select uninstall.
Restart the notebook and the keyboard will be installed automatically along with the drivers and should set it back to default.
