Question about Blenders
I need the manual for a Sharp Spc314 alarm clock
    Top Expert:
  • Blenders Master
  • 36,401 Answers
Sharp might be a able to furnish the manual
Posted on Oct 11, 2013
2 Suggested Answers
SOURCE: Atomic alarm clock-sharp spc314
The manual says to hold the snooze button down for 3 seconds. Release as soon as the satellite image pops up on your display
Posted on Aug 04, 2012
Why does water leak out when filled passed the top of blade
About 11,000 results (0.81 seconds) Search Results
    [PDF]Instruction Booklet Premier™ 11-Cup Series - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-2011.pdf
    Cuisinart11 cups (total processed weight varies by food) ... PowerPrep® metal dough blade, metal ... bowl at the top with ... filled out. WHEN. REMOVING BLADE: CAREFULLY REMOVE. THE METAL BLADE BY .... (If machine does not ... not put base in water or... These features, plus the .... have passed into the ... food from leaking.
    [PDF]Download Manual - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
    Cuisinartmatching outline O on top of .... base in water or other liquid. General ... does not fit fully in the outlet, ... as you would sharp knives, out of ... 11. KNEADING YEAST DOUGH WITH DOUGH BLADE. 12. KNEADING BREAD DOUGH ... loodfrom leaking...... uid onto dough as it passes under ..... Fill the feed tube wilh the pieces,.
    [PDF]Food Processor - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-xp.pdf
    Cuisinart
Feb 08, 2016 | Cuisinart Prep 11 Plus Dlc2011chb Food...
Replaced Capacitor and resistors motor running fine but cant keep the belt on keeps running off should rotation be clock or anti clock
Generally speaking, belt tracking issues are usually due to one or more of the shafts that support the pulleys not being perpendicular to each other - this applies to everything from treadmills to fan belts. Check and correct if possible: that the motor is securely mounted in the housing and that it is not installed crooked; and that the shafts aren't loose or have sloppy side to side movement. Belts should be tight - but not overly so.
Jul 22, 2015 | Kenwood Chef A901 901p 907 Quality Motor...
Why does the blade spin but it doesn't blend
The blade may be dull, not sharp.
Jul 11, 2015 | Blenders
Trying to locate shipment
suggest you contact where ever you placed that order but it's not with FIXYA.com
Mar 11, 2015 | Sharp Oliver Bread Slicer Replacement...
Gasket gone in the juice
it probably did.
you wouldn't see it in the blades as they are remarkably sharp and shred anything that gets in them.
Feb 21, 2015 | Magic Bullet Nutribullet Blender
Instructions to set clock
I have a model SPC486A sharp travel alarm clock and I can't figure out how to set the date on it as I bought it and it didn't have a manual with it.
Jan 06, 2014 | Oster Blenders
My blendtec blender doesn't blend as well as it once did. The motor seems to be running fine, but I am not sure if the blades are spinning properly.
You have already found what is the problem the blades.
The blades after a lot of working hours with ice they have mainly three problems.
One the sharp adjes have created a lot of teeths and are not so sharp any more so the blending is not smooth anymore.
Second problem they have loose a title so they have move from corect place some milimeters and this change the wave motion and again the beleding is not so smooth as before.
Third the blades are secure on an axis which is located in two bearings which have een wearing out so the rotating motion of the blades again is not so smooth as before.
So if you are not able to fix the blades kit or to find someone in your area to do it profetionaly and cheap one good idea is to buy a new blades kid.
Good luck
Aug 17, 2010 | Blendtec ABC Work Top Blender
Unable to screw base off to clean
Leave the pitcher on the it's base and twist in the counter clock wise direction.
Nov 02, 2009 | Back to Basics Smoothie Elite Work Top...
Plasic gears
Not usually is the short answer. If you can find a Sharp repairer who may have that part in, they can repair it. Or contact Sharp customer support services (google the company where you are).
In the UK Sharp have more or less closed down most of their Household Appliances other than their microwaves and it is difficult to source parts generally.
Jun 27, 2009 | Sharp EJ-12GDW Work Top Blender
Sep 15, 2008 | Blenders
Blenders Logo
202 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
