Question about West Bend Kitchen Appliances - Others
Why my new microwave turns on when first plugged in?
    Champion:
  • 252 Answers
Either it is a boot up sequence, or really possesed by popcorn machine ghosts.
Posted on Oct 17, 2013
    Master:
  • 359 Answers
If it turns on when plugged in try hitting the off/stop button after plugging it in. If it is an analog knob make sure it is in the off position before plugging in.
Posted on Oct 11, 2013
1996 Onan Propane 2500 Microlite Generator often will not start & dies when microwave is started?
Microwave ovens need to be connected to a separate, dedicated line.
Nov 28, 2013 | Grilling
The microwave does't make any noise ,,,but the count down on clock is working ...light is working but no fan ...or huming noise ...what could it be
HELLO.
The likely thing to be is that the microwave fan is faulty.the solution is to replace the fan.
Needed instrument:Phillips-head screwdriver.
Instructions on how to replace the fan is detailed given below.
    • 1. Unplug the microwave from the wall outlet to prevent an electrical shock while
    • working on the microwave oven.
    • 2 .Remove the screws holding the fan shroud to the top of the microwave oven. Using a Phillips-head screwdriver, turn the screws counterclockwise to back them out of the panel. Set the screws in a safe place so they will be available for installing the new fan.
    • 3.Slide the fan shroud--also referred to as a damper plate--forward, toward the front of the microwave, to remove it. Set the shroud to the side.
    • 4. Lift the fan assembly out of the microwave. An electrical cable and plug is accessible once the fan assembly is out of the way.
    • 5. Unplug the electrical connector from the fan and fully remove the fan assembly.
    • 6. Set the new fan assembly close to the top of the microwave to facilitate plugging the new fan into the microwave's connector. Plug in the fan assembly.
    • 7. Position the new fan in the same orientation as the old fan's before its removal. Lower the fan assembly into position.
    • 8. Slide the fan shroud in place and install the screws to secure the shroud.
    • 9. Tighten the screws with the Phillips-head screwdriver by turning the clockwise.
    • 10. Plug the microwave oven into the wall outlet and test the new fan installation.
Thanks
Sep 20, 2011 | Haier Microwave Microwave Oven
Carousel does not turn when microwave in on and running
There is a panel under the microwave, held on by one or more screws. Remove it and you will see the synchronous motor inside. There should be a plug to disconnect the wires. Remove the motor and fit a new one. Ensure that the microwave is disconnected from the wall outlet before attempting any work on it.
Feb 11, 2011 | Jenn-Air JMC8100 Microwave Oven
Just bought new Samsung SMH9151 OTR Microwave. Installed it and it turns on for 3 seconds and turns off. I took it back down and just plugged it in the wall plug (while sitting on the counter) and same...
I don't mean to be coy, but if you bought it from a local company (Best Buy, Lowes, Home Depot), take it back (within the 30 day window) for a refund. I bought three microwaves (all poor quality) and returned them all!
I may be returning this Samsung if your review turns out to be true for my microwave.
Jun 03, 2010 | Samsung SMH9151 Microwave Oven
F7 code on Whirlpool Microwave model GH9185XLT - 1
Power to magnetron
interrupted
12. Replace inverter.
13. Replace all parts and panels before operating.
14. Plug in microwave oven or reconnect power.
15. If problem persists, unplug microwave oven or disconnect power.
16. Replace electronic control.
17. Replace all parts and panels before operating.
18. Plug in microwave oven or reconnect power.
19. If problem persists, unplug microwave oven or disconnect power.
20. Check for reversed plug connection on controls or loose wiring.
21. Replace all parts and panels before operating.
22. Plug in microwave oven or reconnect power.
May 23, 2017 | Whirlpool GH9185XL Microwave Oven
The microwave just stopped working in the middle of heating
Always have something in the microwave before turning on. A glass of water is OK. It's needed to absorbed the energy.
All microwaves will stop if the door is opened. This a safety feature. Never operate with the door opened.
The button below the plug outlet is a test button for the GFI (Ground Fault Interrupter). This is a safety feature of the electrical wiring for your home. Make sure it's turned on.
Since this is a new unit, you may want to take it back to the store you bought from for an exchange/refund.
WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance Warranty Notes For models produced on or after January 1, 2006
See written warranty for full details
Mar 30, 2009 | General Electric JES0736SMSS 700 Watts...
My ge profile microwave oven sometimes turns on when door is clos
hi and wellcome to FixYa this is a comon problem with the control unit for the microwave being damaged the buttons start to stop working more or few buttons at a time, there are companys that sell the front units seperate for these microwaves but can cost more than a new microwave itself , the unit itself is damaged by heat from the microwave or on rare accasions damp im sorry there is no other way to sort this apart from a new front control unit or a new microwave
Thanks Hope this helps a little
Feb 06, 2009 | Whirlpool MH7140XF Microwave Oven
Sanyo microwave model em-s5002w won't heat...sounds louder
Sounds like a component failure in the microwave circuit.
It will be one or more of the following -
Fuse
Diode
Capacitor
Transformer
Magnetron
Reply back and I can help you more. These failures happens to new or old microwaves.
Feb 01, 2009 | Microwave Ovens
Kitchen Appliances - Others Logo
35 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Angel Joseph Jr.
Angel Joseph Jr.
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
