It is now safe to turn off the server - Office Equipment & Supplies
  • giorgio nifosi Oct 11, 2013
    ops i have dc 12 and fiery x12 but on the fiery and see this message "it is now safe to turn off the server"
Get message "Can not connect safely to server"
First check to see if you're router is working as it should.
If it is contact your ISP server ie, comcast, verison.
If they say they can "see' your computer then the problem is with one of many of the privacy settings that are turned on on your software.
Nov 07, 2014 | Samsung Galaxy Tab Tablet PC
How do i boot into safe mode?
To boot into safe mode press F8 continually on and off from before the windows logo!
Oct 04, 2014 | E-Machines eMachines Desktop PC
How can i boot my hp dl380 g6 server in safe mode ? the F8 key didnt help me to boot in safe mode
Different system use different F keys to get to safe mode, If F8 is not it, try F10.
Good Luck
C2Solutions
Feb 14, 2011 | HP ProLiant DL380 G6 Server
I turned it on and now it won't even start up it gets stuck on microsoft windows xp start up screen, what do I do?
See if you cant get it to start up in safe mode and run a check disk.
http://support.microsoft.com/kb/315265
If you cant get into safe mode, I hope you have a windows xp installation disk to run it from the CD: http://kb.wisc.edu/helpdesk/page.php?id=5097
Apr 08, 2010 | Dell PowerEdge 1300 Server
Hay Bahratt, I have uninstalled the 3 SQL programs in the control panel a few times with no effect on the issue. I didn't try moving directory C:\Program Files\Microsoft SQL Server\MSSQL to another...
If you have removed it from control panel, its done. You just have to clean up any left over registry entries using CCleaner and then try installing again
http://www.ccleaner.com/download
You may also want to check out this microsoft link if it doesn;t work
http://office.microsoft.com/en-us/help/HP011128601033.aspx
Jan 10, 2010 | Computers & Internet
How to booting safe mode in HP DL360 G3 server
As soon as the server turns on and you see a BIOS screen press the F8 key constantly. This should be you to the safe mode screen. If not then try another keyboard, or another USB slot.
Nov 12, 2009 | HP Compaq ProLiant DL360 G4 Server
On reboot how do i get to safe mode? I have a virus and things are being blocked from use !
As computer powers up tap the F8 key continuiously. That will bring up the options screen.
Sep 25, 2009 | Dell PowerEdge 1300 Server
Newfolder.exe VIRUS
Kindly go to google and search for flash disinfector and download the software and run it to remove the virus. Connect all the flash drives you have with you to remove the virus.
http://www.spywareremove.com/removenewfolderexe.html
Jul 29, 2009 | HP Compaq ProLiant ML530 Server
Dear All,We have 1 IBM x206M server that been used as a backup server. The problem with the server is whenever you want to shutdown, the server doesn't turn off instead it gives bluescreen error like the...
hi dear
just entering the safe mode
by entering F5, choose the system restore in start menu -programs-accsesorries-system tool-system restor
choose the date ..before the computer running well
oke
Feb 16, 2009 | IBM xSeries 226 Server
jasbo
jasbo
