Mcp61pmam motherboard beep code - Computers & Internet
    Brigadier General:
  • 3,400 Answers
Http://pcsupport.about.com/od/nonworkingcomponent/ht/beepcodestb.htm
HERE ARE BEEP-CODES FOR AMI,AWARD AND PHOENIX BIOS.
Posted on Oct 11, 2013
Why is it important to know different beeps when dealing with computers?
Beep codes come from a piezo speaker on your motherboard and identify problems with the power or configuration of the motherboard.
Different motherboard manufacturers use different beep codes, so Googling the words "beep codes" along with the model number of the motherboard (an etching on the board itself) will usually locate your results.
In any case, go to the website of the motherboard manufacturer to find the information, ususally in support or downloads to find the manual for your specific motherboard.
Most common beep codes:
  • . Missing keyboard
  • Can't find CPU
  • RAM missing, improperly installed or failing
Sep 25, 2017 | Computers & Internet
Tip
System Beep Code Error
Beep Code Manual, Better Than Gold Techies, American Megatrends Int. & Phoenix
BIOS Beep Codes
When a computer is first turned on, or rebooted, its BIOS performs a power-on self test (POST) to test the system's hardware, checking to make sure that all of the system's hardware components are working properly. Under normal circumstances, the POST will display an error message; however, if the BIOS detects an error before it can access the video card, or if there is a problem with the video card, it will produce a series of beeps, and the pattern of the beeps indicates what kind of problem the BIOS has detected.
Because there are many brands of BIOS, there are no standard beep codes for every BIOS.
The two most-used brands are AMI (American Megatrends International) and Phoenix.
Below are listed the beep codes for AMI systems, and here are the beep codes for Phoenix systems.
AMI Beep Codes
Beep Code Meaning
1 beep DRAM refresh failure. There is a problem in the system memory or the motherboard.
2 beeps Memory parity error. The parity circuit is not working properly.
3 beeps Base 64K RAM failure. There is a problem with the first 64K of system memory.
4 beeps System timer not operational. There is problem with the timer(s) that control functions on the motherboard.
5 beeps Processor failure. The system CPU has failed.
6 beeps Gate A20/keyboard controller failure. The keyboard IC controller has failed, preventing gate A20 from switching the processor to protect mode.
7 beeps Virtual mode exception error.
8 beeps Video memory error. The BIOS cannot write to the frame buffer memory on the video card.
9 beeps ROM checksum error. The BIOS ROM chip on the motherboard is likely faulty.
10 beeps CMOS checksum error. Something on the motherboard is causing an error when trying to interact with the CMOS.
11 beeps Bad cache memory. An error in the level 2 cache memory.
1 long beep, 2 short Failure in the video system.
1 long beep, 3 short A failure has been detected in memory above 64K.
1 long beep, 8 short Display test failure.
Continuous beeping A problem with the memory or video.
BIOS Beep Codes
Phoenix Beep Codes
Phoenix uses sequences of beeps to indicate problems. The "-" between each number below indicates a pause between each beep sequence. For example, 1-2-3 indicates one beep, followed by a pause and two beeps, followed by a pause and three beeps. Phoenix version before 4.x use 3-beep codes, while Phoenix versions starting with 4.x use 4-beep codes. Click here for AMI BIOS beep codes.
4-Beep Codes
Beep Code Meaning
1-1-1-3 Faulty CPU/motherboard. Verify real mode.
1-1-2-1 Faulty CPU/motherboard.
1-1-2-3 Faulty motherboard or one of its components.
1-1-3-1 Faulty motherboard or one of its components. Initialize chipset registers with initial POST values.
1-1-3-2 Faulty motherboard or one of its components.
1-1-3-3 Faulty motherboard or one of its components. Initialize CPU registers.
1-1-3-2
1-1-3-3
1-1-3-4 Failure in the first 64K of memory.
1-1-4-1 Level 2 cache error.
1-1-4-3 I/O port error.
1-2-1-1 Power management error.
1-2-1-2
1-2-1-3 Faulty motherboard or one of its components.
1-2-2-1 Keyboard controller failure.
1-2-2-3 BIOS ROM error.
1-2-3-1 System timer error.
1-2-3-3 DMA error.
1-2-4-1 IRQ controller error.
1-3-1-1 DRAM refresh error.
1-3-1-3 A20 gate failure.
1-3-2-1 Faulty motherboard or one of its components.
1-3-3-1 Extended memory error.
1-3-3-3
1-3-4-1
1-3-4-3 Error in first 1MB of system memory.
1-4-1-3
1-4-2-4 CPU error.
1-4-3-1
2-1-4-1 BIOS ROM shadow error.
1-4-3-2
1-4-3-3 Level 2 cache error.
1-4-4-1
1-4-4-2
2-1-1-1 Faulty motherboard or one of its components.
2-1-1-3
2-1-2-1 IRQ failure.
2-1-2-3 BIOS ROM error.
2-1-2-4
2-1-3-2 I/O port failure.
2-1-3-1
2-1-3-3 Video system failure.
2-1-1-3
2-1-2-4 I/O port failure.
2-1-4-3
2-2-1-1 Video card failure.
2-2-1-3
2-2-2-1
2-2-2-3 Keyboard controller failure.
2-2-3-1 IRQ error.
2-2-4-1 Error in first 1MB of system memory.
2-3-1-1
2-3-3-3 Extended memory failure.
2-3-2-1 Faulty motherboard or one of its components.
2-3-2-3
2-3-3-1 Level 2 cache error.
2-3-4-1
2-3-4-3 Motherboard or video card failure.
2-3-4-1
2-3-4-3
2-4-1-1 Motherboard or video card failure.
2-4-1-3 Faulty motherboard or one of its components.
2-4-2-1 RTC error.
2-4-2-3 Keyboard controller error.
2-4-4-1 IRQ error.
3-1-1-1
3-1-1-3
3-1-2-1
3-1-2-3 I/O port error.
3-1-3-1
3-1-3-3 Faulty motherboard or one of its components.
3-1-4-1
3-2-1-1
3-2-1-2 Floppy drive or hard drive failure.
3-2-1-3 Faulty motherboard or one of its components.
3-2-2-1 Keyboard controller error.
3-2-2-3
3-2-3-1
3-2-4-1 Faulty motherboard or one of its components.
3-2-4-3 IRQ error.
3-3-1-1 RTC error.
3-3-1-3 Key lock error.
3-3-3-3 Faulty motherboard or one of its components.
3-3-3-3
3-3-4-1
3-3-4-3
3-4-1-1
3-4-1-3
3-4-2-1
3-4-2-3
3-4-3-1
3-4-4-1
3-4-4-4 Faulty motherboard or one of its components.
4-1-1-1 Floppy drive or hard drive failure.
4-2-1-1
4-2-1-3
4-2-2-1 IRQ failure.
4-2-2-3
4-2-3-1
4-2-3-3
4-2-4-1 Faulty motherboard or one of its components.
4-2-4-3 Keyboard controller error.
4-3-1-3
4-3-1-4
4-3-2-1
4-3-2-2
4-3-3-1
4-3-4-1
4-3-4-3 Faulty motherboard or one of its components.
4-3-3-2
4-3-3-4 IRQ failure.
4-3-3-3
4-3-4-2 Floppy drive or hard drive failure.
3-Beep Codes
Beep Code Meaning
1-1-2 Faulty CPU/motherboard.
1-1-3 Faulty motherboard/CMOS read-write failure.
1-1-4 Faulty BIOS/BIOS ROM checksum error.
1-2-1 System timer not operational. There is a problem with the timer(s) that control functions on the motherboard.
1-2-2
1-2-3 Faulty motherboard/DMA failure.
1-3-1 Memory refresh failure.
1-3-2
1-3-3
1-4-1 Address line failure.
1-4-2 Parity RAM failure.
1-4-3 Timer failure.
1-4-4 NMI port failure.
2-_-_ Any combination of beeps after 2 indicates a failure in the first 64K of memory.
3-1-1 Master DMA failure.
3-1-2 Slave DMA failure.
3-1-3
3-1-4 Interrupt controller failure.
3-2-4 Keyboard controller failure.
3-3-1
3-3-2 CMOS error.
3-3-4 Video card failure.
3-4-1 Video card failure.
4-2-1 Timer failure.
4-2-2 CMOS shutdown failure.
4-2-3 Gate A20 failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure.
4-3-3 Timer failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port failure.
4-4-2 Parallel port failure.
4-4-3 Math coprocessor.
on Feb 02, 2010 | Computers & Internet
Tip
Beep Code Manual
(I'm Computer Technician, I use these codes to trouble shoot hardware issues at my job. Enjoy.)
BIOS Beep Codes
When a computer is first turned on, or rebooted, it's BIOS performs a power-on self test (POST) to test the system's hardware, checking to make sure that all of the system's hardware components are working properly. Under normal circumstances, the POST will display an error message; however, if the BIOS detects an error before it can access the video card, it will produce a series of beeps, and the pattern of the beeps indicates what kind of problem the BIOS has detected. Because there are many brands of BIOS, there are no standard beep codes for every BIOS.
AMI Beep Codes
Beep Code Meaning
1. beep DRAM refresh failure. There is a problem in the system memory or the motherboard.
2. beeps Memory parity error. The parity circuit is not working properly.
3. beeps Base 64K RAM failure. There is a problem with the first 64K of system memory.
4. beeps system timer not operational. There is problem with the timer(s) that control functions on the motherboard.
5. beeps Processor failure. The system CPU has failed.
6. beeps Gate A20/keyboard controller failure. The keyboard IC controller has failed, preventing gate A20 from switching the processor to protect mode.
7. beeps Virtual mode exception error.
8. beeps Video memory error. The BIOS cannot write to the frame buffer memory on the video card.
9. beeps ROM checksum error. The BIOS ROM chip on the motherboard is likely faulty.
10. beeps CMOS checksum error. Something on the motherboard is causing an error when trying to interact with the CMOS.
11. beeps Bad cache memory. An error in the level 2 cache memory.
1 long beep, 3 short A failure in the video system.
1 long beep, 8 short display test failure.
BIOS Beep Codes
Phoenix Beep Codes
For example, 1-2-3 indicates one beep, followed by a pause and three beeps. Phoenix version before 4.x use 3-beep codes, while Phoenix versions starting with 4.x use 4-beep codes.
4-Beep Codes
Beep Code Meaning
1-1-3-2
1-1-3-3
1-2-1-2
1-2-3-3 DMA error.
1-3-3-3
1-3-4-1
1-4-1-3
1-4-2-4 CPU error.
1-4-3-1
1-4-3-2
1-4-4-1
1-4-4-2
2-1-1-3
2-1-2-4
2-1-3-1
2-1-1-3
2-1-4-3
2-2-1-3
2-2-2-1
2-2-3-1 IRQ error.
2-3-1-1
2-3-2-3
2-3-4-1
2-3-4-1
2-3-4-3
2-4-2-1 RTC error.
2-4-4-1 IRQ error.
3-1-1-1
3-1-1-3
3-1-2-1
3-1-3-1
3-1-4-1
3-2-1-1
3-2-2-3
3-2-3-1
3-2-4-3 IRQ error.
3-3-1-1 RTC error.
3-3-3-3
3-3-4-1
3-3-4-3
3-4-1-1
3-4-1-3
3-4-2-1
3-4-2-3
3-4-3-1
3-4-4-1
4-2-1-1
4-2-1-3
4-2-2-3
4-2-3-1
4-2-3-3
4-3-1-3
4-3-1-4
4-3-2-1
4-3-2-2
4-3-3-1
4-3-4-1
4-3-3-2
4-3-3-3
3-Beep Codes
Beep Code Meaning
1-2-2
1-3-2
1-3-3
3-1-3
3-3-1
3-3-2 CMOS error.
on Dec 31, 2009 | Computers & Internet
NO SOUND HEAR
Hi, Do this beeping code for motherboard troubleshooting. First disconnect all memory,external video card, etc only motherboard and power supply. Then power on if you hear continuous beeping means the motherboard working good. Please do this beeping code troubleshooting.
No beeping means Short, No power, Bad CPU/MB, Loose Peripherals. One beeping means Everything is normal and Computer posted fine. Two beeping means POST/CMOS Error. One Long Beep, One Short Beep means Motherboard Problem.
One Long Beep, Two Short Beeps means Video Problem.
One Long Beep, Three Short Beeps means Video problem.
Repeated Long Beeps means memory error.
Continuous Hi-Lo Beeps means CPU Overheating.
Jul 14, 2011 | Computers & Internet
Tip
Beep Code Explained
Thanks to Transcend Technical Support for this great Brief of understanding beep codes that is found here
This is a long post and it may be truncated at the bottom. If so, use the link above to go to the Transcend web site where these are found
1.General POST (initial system boot) BEEP Codes
If you do not know the BIOS manufacturer, the following will be the general Beep codes:
• 1 Long and 1 Short Beep ?Bad Motherboard
• 1 Short Beep and nothing else happens ?Disk Drive/Video Related Problems
• 1 Long and 2 Short Beeps ?Bad Video Card
• 1 Continuous Beep or Non-stop short Beeps ?Bad Power Supply
• 3 Short Beeps - Bad Memory
2.American Megatrends Inc. (AMI) BEEP Codes
• 1 Beep - Memory refresh timer error.
Reseat the memory, or replace with known good modules.
• 2 Beeps - Parity Error
• 3 Beeps - Main memory read / write test error.
• 4 Beeps - Motherboard timer not operational
• 5 Beeps - Processor Errors
• 6 Beeps - Keyboard controller BAT test error.
• 7 Beeps - General exception error.
• 8 Beeps - Display memory error.
If the system video adapter is an add-in card, replace or reseat the video adapter. If the video adapter is an integrated part of the system board, the board may be faulty.
• 9 Beeps - ROM checksum error
• 10 Beeps - CMOS shutdown register read/write error
• 11 Beeps - Cache Memory Bad
Beeps 4-7, 9-11
Fatal error indicating a serious problem with the system. Consult your system manufacturer.
Before declaring the motherboard beyond all hope, eliminate the possibility of interference by a malfunctioning add-in card. Remove all expansion cards except the video adapter.
?If the beep codes are generated even when all other expansion cards are absent, the motherboard has a serious problem. Consult your system manufacturer.
?If the beep codes are not generated when all other expansion cards are absent, one of the add-in cards is causing the malfunction. Insert the cards back into the system one at a time until the problem happens again. This will reveal the malfunctioning add-in card.
3.Award Bios BEEP Codes
1 Long Beep: Memory problem
Explanation: There is a failure of some sort related to the system memory.
Diagnosis: The first bank of memory probably has a failure of some sort; this is usually just a physical problem such as an incorrectly inserted module, but may also mean a bad memory chip in a module. It is possible that there is a failure related to the motherboard or a system device as well.
• 1 Long, then 2 Short Beeps: Video error
Explanation: The BIOS is unable to access the video system in order to write any error messages to the screen.
Diagnosis: This is usually caused by a problem with the video card, or the memory on the video card. It can also be a motherboard issue.
• 1 Long, then 3 Short Beeps: Video error
• Continuous Beeping: Memory or video problem
Explanation: The system is producing constant beeping in no specific pattern, or a fast "ringing" sound.
Diagnosis: This is usually caused by a problem with the system memory, or possibly the video card. The memory is more likely--the system complains long and loud if it can't find any usable memory, as there is no way to even start the boot process when this is the case. The motherboard itself could also be the problem.
• Other Beep Codes
Explanation: You have encountered an Award BIOS beep code I do not have documented.
Diagnosis: Award says that any beep patterns other than "one long followed by two short" are likely problems with the system memory. However, of late they have started adding other beep codes to their systems as well.
4.Phoenix BEEP Codes
• 1-1-3
Explanation: Your computer can't read the configuration information stored in the CMOS.
Diagnosis: Replace the motherboard.
• 1-1-4
Explanation: Your BIOS needs to be replaced.
Diagnosis: Got to your motherboard manufacturers web site and download the new Bios.
• 1-2-1
Explanation: You have a bad timer chip on the motherboard.
• 1-2-2 or 1-2-3 or 1-3-1 or 1-3-3 or 1-3-4 or 1-4-1
Explanation: Motherboards is bad.
• 1-4-2
Explanation: Some of your memory is bad.
Diagnosis: Go to Basic Trouble Shooting
• 1-3-1
• 2-_-_ Any combination of beeps after two
Explanation: Some of your memory might be bad.
• 3-1-_
Explanation: One of the chips on your motherboard is broken.
• 3-2-4
Explanation: Keyboard controller failure.
Diagnosis:
• 3-3-4
Explanation: Your computer can't find the video card.
Diagnosis: Is it there? If so, try swapping it with another one and see if it works.
• 3-4-_
Explanation: Your video card isn't working.
Diagnosis: Replace Video Card.
on Jan 20, 2009 | ASUS P5W DH Deluxe Motherboard
Motherboard beep code errors
  1. What steps you take to solve a particular beep code will differ depending on the BIOS manufacturer.
    Choose the correct beep code troubleshooting guide below based on your motherboard'sBIOS manufacturer:
    Tip:Not sure what brand of BIOS is on your motherboard? See thisHow to Determine Your Motherboard BIOS Manufacturerguide for some helpful advice.
Nov 20, 2010 | Computers & Internet
Long beep error alarm ?
    Choose the correct beep code troubleshooting guide below based on yourmotherboard'sBIOS manufacturer:
Sep 14, 2010 | MSI 661FM2-LSR Motherboard
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Apr 20, 2010 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
Motherboard pc chips m810 lmr v7,1
The beep codes are not universal, but there are a few popular BIOS's and you can figure out what 2 beeps means if you can find your BIOS listed here:
http://www.computerhope.com/beep.htm
The name of your BIOS should appear on the monitor as you're booting.
Nov 20, 2007 | Asrock M810LMR Motherboard
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
