Using uberhause deluxe vinyl flooring (foam layer on back). Not recommended to install under kitchen counters, but can it be installed under fridge, stove, dishwasher & hearth pad (under wood stove)?
I am not familiar with the brand but cushioned vinyl can be laid under just about anything as long as you accept the downside - permanent pressure on the vinyl will cause sinkage over time until the deformation becomes permanent so should the fridge or washer, for instance needs moving at some future time, will be so deeply embedded they will need lifting out of the indentations as attempting to slide or roll them out would likely need a great deal of force and result in severe damage to the vinyl.
The vinyl could be laid under kitchen counters but again the counters would continue moving downwards over time until the compression of the foam is complete; making precision fitting difficult.
If I was facing the problem I would begin by laying some sort of base for the fridge, washer, etc. to stand on and provide a neat edge for the cushioned vinyl in approximate line with the kitchen counters. Marine ply or tiles for a base perhaps.
hilldale bar stool that is the \\s the Cottage model needs the black vinyl seat cushion replaced because it is ripped
