Question about Fisher and Paykel Washing Machines
Replaced computer in fisher and pakel top loading washer and still does not work. what is wrong??
    Champion:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 240 Answers
Does it beep at you? is it dead? if some lights are on while it's beeping, they are an error code, can you relay them to me?
Posted on Nov 11, 2013
SOURCE: Black marks on clothes
I had a similar problem. We has placed the waste water hose into an old tub next the machine. The plug hole int he sink has become blocked with lint. When the washing maching was pumping water into the tub, the tub would fill with water, which would rise a level higher than the washing machine waste hose. What this appeared to do was cause the machine not to be able to properly pump out water, leaving this horrible back stuff in the wash which would end up all over the wash. Ensuring the plub hole in the tub was clear solved the problem immediately!
Posted on Jun 02, 2009
  • 41 Answers
SOURCE: THE WINGS ON THE AGITATOR ON MY FISHER PAYKEL
yes loosen the wing nut nd remove nd replace , u can order part from F&P direct 1800650590 ask for spares
Posted on Jan 31, 2010
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
TheMobilian
  • 8220 Answers
SOURCE: fisher pakel ecosmart washer rinse cycle into spin
Check for objects between tub and basket.
Posted on Mar 17, 2010
  • 343 Answers
SOURCE: what is error code 136 on a fisher & paykel IW...
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
Posted on May 24, 2010
Wont wash just flashes the wash light
most likely the controll board at the bottom has gotten wet due to accidentally overloading the washer.Remove the droor and dry out the board with a hair dryer.That is the most common cause of problems with the fisher pakel dish washers
Apr 06, 2014 | Fisher and Paykel GWL11 Top Load Washer
My fisher pakel washer is stuck in regular wash, low water level. It sounds like the motor is emptying but it never goes to spin. I tried unplugging it to reset the computer but it always goes back to the...
Hi just just read your posting,Now have you tried selecting a different cycle and water level?Could you please confirm the model number of your machine for me.Is the machine draining the water out of the bowl? Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Sep 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a Fisher Pakel washer GWL11 and it has developed a small leak under the washer. The cycle stops at rense and just quits. Any suggestions on what needs replacing?
Sounds like it could be overfilling Just a little and while it is agitating it will be splashing over, To fix this you will need to replace the MCU,
Jul 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Pakel dish drawer sends F1 alarm flashing. It usually happens when there is a drop or change in water pressure. Have had 3 repairs on this disappointing product. Only repair person for Fisher...
F1 is a flood fault ir happens when the machine detects water on the base of the unit, to clear this fault you can remove the bottom draw and use a towel to clean up the water this should clear the fault, But usually there is only water on the base if the lid is not closing properly, this can happen due to you putting long utensils in and the lid cannot pull down or you have faulty lid actuators witch is probably the case and they wont pull the lid down correctly, So if the lid wont come down properly water splashes over the top and floods the base. :)
Jul 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Squealing sound on spin cycle.........
Turn power off AT THE WALL,under the wash bowl Spray some wd40 on to the pump at both ends, while this may stop it for a while. Your pump may well be on its way out. you should replace for a new one. bad pumps can cause more problems problems .
Mar 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
When the washer is pumping water in it makes a noise like the pump is starving for water. I have checked water flow through the lines and the inlet filters ar not stoped up.
The only thing I've ever had to replace on that model washer is the pump, and they go out all the time. You have to order it from fischer and pakel directly, and it is extremely easy to replace (can do it with no tools at all) Remove the wires from the pump. Ther is a plastic tab that releases it so you can turn it. Turn it 1/4 turn and it will come out. To get a pump call 888-936-7872 (fischer and pakel customer care)
Nov 26, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher pakel water saver washer stopped early in cycle and is non stop beeping
www.ths.gardenweb.com/forum/laundry
try this website. I found answers to my questions on it that i did not find here.
repairman who came to my house yesterday said manuals are only available on dvd, not in paper anymore.
saw on the other website that you can order FP parts through Sears. have not tried, so don't know if that is reliable. maybe you can order a FP manual through Sears to tell you how to fix your issue.
Oct 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher n pakel won't drain
Pump Belt ?
Does The Timer Stop At Particular Position? If So, Timer Failure
Feb 20, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
