Question about Microwave Ovens
How do I get amana tech support - Microwave Ovens
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
I have Amana microwave hdc182 displaying f3 code what dose this mean?
According to the tech info manual, when you get a code F3 you need to replace the HV/LV board. Here is a link to the manual for your reference.
Jul 02, 2015 | Amana Microwave Ovens
Call service error
There is a fault in the magnetron circuit somewhere. Do not mess with this yourself because there is lethal high voltage present even when the microwave is unplugged. Call a service tech.
May 23, 2014 | Amana Microwave Ovens
Button programming
Call Amana tech support @ 866.426.2621
Nov 15, 2013 | Amana HDC21 Microwave Oven
Fan is barely running. during cook, fan runs weak and vent fan does not run. tech said maybe a control panel? i can do the work but need a parts and service manual. are these available? does the weak...
probably a defective motor or slipping blade. i'm not sure how old your amana is. if it's the real old chrome metal '70's or early '80's vintage models, the part may not be available anymore.. they were very common to fail.
May 16, 2011 | Amana Radarange Microwave Oven
I have an amana convection/microwave model acm1580as that needs a lamp replaces. I bought replacement lamp and after practically tearing appliance apart I located burnt out lamp. Now I don,t know how to...
Hi, since you have located the burnt lamp, all you need to do is to unscrew the burnt lamp and replace the new one by screwing it in.....
You only need to unscrew to remove the lamp and if you cannot remove by unscrewing because it is stuck in, then you need the assistance of an electrical tech to help remove with his pliers....
Mar 26, 2011 | Amana ACM1580 Convection Microwave Oven
Amana microwave M#rcs10mpsa that had a loud hum that sounds like it was coming from the transformer or capacitor and then it blows the two control fuses. i replaced the magnatron but it is doing the same...
you need a meter than has the ability to check capacitors. These meters are generally more expensive like 150 bucks and mostly sold for HVAC techs. You disconnect all wires to the cap and connect your test leads. The hum is usually the transformer getting ready to die. Just keep using it until so. The transformer will run you about 130 bucks I think.
Oct 14, 2010 | Amana RFS12MPS Microwave Oven
Everything is working fine on the microwave, except that it is not heating the food.
this a problem with your magnetron.some units have a five to ten year warranty.they need to be replaced by a service tech
Feb 23, 2010 | Amana Radarange Microwave Oven
Microwave will not stop cooking unless I open door
you have a bad door switch call a tech these things can kill you even if they are unplugged.
Jan 07, 2010 | Amana MVH210W Microwave Oven
Amana microwave appears to be losing power
It's likely the magnetron is failing but you don't touch anything inside till you discharge the energy in the capacitor. Appliance repair isn't the same as electronic repair. The biggest problem there is static electricity and that only damages the electronics. Please consider getting some local tech help. Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Amana Microwave Ovens
C5 error on amana dq22hs
A CS error means oven senses to much current or not enough. The problem could be a burnt wire on the door switch, or mag themals. It could also be a ploblem with one of the HV compents. You should have a tech check it out due the the dangerous HV system.
May 01, 2009 | Amana ACE208 Convection/Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
