Question about Oster 1.7 L Variable Temperature Electric Kettle
At 100deg. it does not shutoff automatically.
How do I set coffee maker to shut off in 2 hrs and how to use clean cycle
Not knowing which model you have, here are the instructions for my model. Perhaps yours is the same.
"The Automatic Shutoff
Time can be programmed anywhere from immediate shutoff after completion of the brew cycle up to four hours. When the coffeemaker shuts itself off, two tones will sound. Two hours is the default time. The 0:00 setting shuts the unit off immediately after brewing is complete.
To check the current setting, press and hold the On/Off button and the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the On/Off button until the red power light and LCD display begin to flash. This signals that you have entered the Set Automatic Shutoff mode.
Press the Hours and Min buttons to scroll forward through the digits until desired time appears. The first setting which appears is preset at 2:00. When it's at 4:00, the next press key of Hour will roll back to 0:00, since four hours is the maximum Automatic Shutoff setting. Pressing and holding either button will allow you to scroll continuously, slowly at first, and then to accelerate to the rate of about three digits per second. As the desired time setting approaches, release the button and then press repeatedly to advance one digit at a time. The Automatic Shutoff Time (ASO) may be 8 9 programmed either before or during coffee brewing. You may also re-program the ASO time when brewing has been completed. If you do so, the Grind & Brew™ will automatically account for any time that has already elapsed after brewing. For example, if you set the ASO for 40 minutes and 25 minutes have already elapsed, the Grind & Brew™ will shut off automatically after 15 minutes (40 minutes minus the 25 elapsed equals 15 minutes)."
Mine doesn't have a specific clean cycle, but to decalcify the unit, add 1/2 vinegar to 2/3 water in a full cafree and run it through. If it's really calcified, turn off about 1/2 way through and let it set for an hour. Then turn it on and finish, Remember to run a pot of clean water through the wash out the vinegar taste.
Jun 24, 2016 | Cuisinart Coffee Makers & Espresso...
TURNS ITSELF OFF
Sounds like the item may have OVERHEATED [will automatically switch off to protect itself from destruction]. Should re-set itself when the internal temperature returns to normal ... [My TOMTOM does the same] ... ok
OR you could have a FAULTY BATTERY or CHARGER. Both of these will cause most GPS units not to boot up or to rapidly shut down [low battery].
NB: Mobile GPS units of any kind should NOT be left mounted on windscreens in a locked car [particularly in direct sunlight] as the inside temperature can rapidly reach over 100deg AND possibly destroy your unit internally.
Nov 19, 2013 | GPS
The car is completely dead. No lights interior or exterior when you turn the key and I am wondering if there is an automatic shut off button that I may have hit by accident. If so, where is it located and...
It might be that you need to replace the battery because to my knowledge some cars are equipped with an automatic fuel shutoff but not an automatic shutoff.My advice to you would be to take your battery to be tested by autozone or advanced auto parts or a store like these. They can test your battery for free.
Feb 27, 2011 | Saturn SL Cars & Trucks
What is the fluid capacity for a 1986 monte carlo ss
Engine Coolant - Volume: 12.00QTS. ( 11.4L ) - [50/50 mixture of Ethylene Glycol Base Antifreeze and water] - 4.3L Eng - [GM Specification 1825-M.]
Engine Coolant - Volume: 16.30QTS. ( 15.4L ) - [50/50 mixture of Ethylene Glycol Base Antifreeze and water] - 5.0L Eng - [GM Specification 1825-M.]
Engine Oil - Volume: 4.00QTS. ( 3.8L ) - [SAE 5W-30 (Preferred) (Below -20Deg.F to Above 100Deg.F), 10W-30 (0Deg.F to Above 100Deg.F), 30 (40Deg.F to Above 100Deg.F)] - 4.3L Eng
Engine Oil - Volume: 4.00QTS. ( 3.8L ) - [SAE 5W-30 (Preferred) (Below -20Deg.F to Above 100Deg.F), 10W-30 (0Deg.F to Above 100Deg.F), 30 (40Deg.F to Above 100Deg.F)] - 5.0L Eng
Fuel Tank - Volume: 17.60GALS. ( 66.6L ) - 4.3L Eng
Fuel Tank - Volume: 18.10GALS. ( 68.5L ) - 5.0L Eng
Feb 07, 2011 | 1986 Chevrolet Monte Carlo
Kettle does not automatically shut off even when water is at above minimum level and boiling
I think that standards require an auto-shutoff on electric pots to keep the component from softening down. You could override the shutoff by either taping over the switch or utilizing an elastic band. You can check deep details on electric kettle review sites.
May 15, 2010 | Chef's Choice 677 Cordless Electric Kettle
No instructions on programming auto shut-off time (feature listed on box).
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
tones will sound.
NOTE: Automatic shutoff may be
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
elapsed, the unit will shut off automatically
-Tha Mp3 Doctor
Apr 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
How to clean the coffee maker & set warmer
In order:
1 and 2) Clean the coffeemaker by puring in 1/3 caraffe vinegar, and 2/3 caraffe water. Either use the self-clean light or brew it as if it were regular coffee - just press the on button and then press the self-clean button, and it will begin.
3)
The Automatic Shutoff Time can be programmed
two tones will sound. Four hours is the default
after brewing is complete. To check the
current setting, press the “On/Off” button and
“On/Off” button until the red “power” light
begins to flash. This signals that you have
entered the “Set Automatic Shutoff” mode.
Press the “Hours” and “Minutes” buttons
appears is preset at “4:00” and the next
display will be “0:00”, since four hours is the
do so, the Automatic Grind & Brew™ will automatically
-Tha Mp3 Doctor
Mar 27, 2009 | Cuisinart Coffee Makers & Espresso...
WARMING PLATE DGB 300
Feb 01, 2009 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
Please help
On the left side of the dash where you have the switch to make your dash lights brighter theres another switch below called a max sentinel something or other, make sure its all the way over to the left.
Oct 26, 2008 | 1991 Buick Park Avenue
Bypassing automatic shutoff
Hello y2ksmk Welcome to fixya.
I'm Huuum and happy to assist you,
What is the model number and the age of your range?
Huuum
I'm here AL night.
Sep 24, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oster 1.7 L Variable Temperature Electric Kettle Logo
52 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
