Question about Canon iPF700 InkJet Printer
If the service mode is deleted how can I take it back ?
    New Friend:
  • 38 Answers
Reload the drivers
Posted on Oct 11, 2013
How to set my sansui tv back to orig.factory? Cuz my tv dont adopt my remote control. & my tv screen hav a factory word that cant be deleted?
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. To enter the service mode, you should have its remote control. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Feb 01, 2016 | Televison & Video
With universal remote restore deleted channels
Do factory reset, and check. Then retune it. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 17, 2015 | Televison & Video
How to Delete all email on iPad 2, iOS7
Want to delete more than a single email message? You can easily delete multiple email messages from the iPad by using the Mail's edit feature. The button on the top right side of the inbox is the edit button. Touching this button will put your inbox into edit mode.
Once your inbox is in edit mode, you can select multiple messages by touching each message you want to delete. You then have the option to either delete them by pressing the delete button at the bottom of the screen or moving them to a specific folder by touching the move button.
Oct 12, 2013 | Computers & Internet
How do I reset the admin password for a Canon iPF605?
The least painful method. Approach the copier and view the operator control panel as we are going to go into service mode and delete the admin password. I am about to describe a "fluid 3 step keystroke " function which will put you into service mode. Before we start , locate the "ADDITIONAL FUNCTIONS" button located between the LCD screen and the 9 key pad. Now, press additional functions, then the numbers 2 and 8 simultaneously, then back to additionalfunctions in a smooth three step flow. The screen will change as you have entered service mode. Depending on the configuration of the device you will have several tabs in your display and copier will be at the top. Press copier. A new display appears with several tabs across the top. Press the function tab. New display again, and now press "clear". New display again. Look for "PWD-CLR". Once found, press it. It will be highlited,and then press the "OK" button in the lower right corner. The ok button will indicate you have touched it by beeping or highlighting or both (depends on the model). Then turn the main power off (the actual switch not the button on the op panel. If you are in doubt unplug the machine. After a few seconds re-energize the copier. If the previous administrator merely used a password then it is now deleted and you are home free. If not, then you will need to enter service mode again.......copier........function.......clear..... and then find MMI . Clearing this field will delete ALL customer inputs(IP address, favorites etc). If it is necessary press MMI and then ok. Usually you wont have to do this. But if you do you can have the fun of re-entering all your old settings as it will go back to factory settings.
Jun 29, 2012 | Canon Office Equipment & Supplies
How do I find the delete option on my hitachi camcorder?
Hi! The solution to your problem is Three fold.
First make sure that your Camcorder is in the Disc Navigation mode to be able delete your required scene. When the camcorder is in the play back mode the delete scene won't appear.
The second situation is to check if your scene is not locked because if it is locked you are not able to delete it.
Supposing that your scene is not locked then check what type of DVD disc you have. The discs labelled DVD Ram, DVD+RW, and the Card can be deleted. The DVD-RW can be deleted only when in VR mode and not the VF mode. Other types of discs like the DVD R can not be deleted.
Another way of deleting a scene after it has been recorded on a disc that's not deletable is to transfer the recorded scene to a computer disc and then edit it off.
Oct 08, 2011 | Hitachi DZBX35A DVD Camcorder
I deleted programs and i think I deleted a driver becuz when I restarted computer I got blank screen that read "cannot display this video mode". How can I fix it?
Hi there
bring your pc up in safe mode by pressing f8 untill you get the start up menu then select safe mode once the pc is up rght click on a blank area of the desktop .select properties ,settings, then advanced change the refresh rate down to 60hz then restart as normal your pc should now display
Regards Al "alstech"
May 26, 2009 | E-Machines eMachines Desktop PC
Can't delete unloaded email
switch to classic mode of yahoo mail,I hope it could help you
Good luck
Feb 20, 2009 | Yahoo Mail
HP PSC 1315 Printer frozen in "deleting" mode
First of all make sure the print spooler service is running. Uninstall and reinstall the printer. also make sure that there is enoght RAM in your computer. You can also change the virtual memory of your computer.
Thanks
Oct 12, 2008 | HP Photosmart C6180 All-In-One InkJet...
Deleting
If your listening to your mp3 player on the computer, then you can't delete any songs. Exit out of the music player and then delete all of your songs.
Dec 03, 2007 | RCA S1000 MP3 Player
Canon iPF700 InkJet Printer Logo
old marine
old marine
