Question about HP PSC 2410 All-In-One InkJet Printer
Please the soft ware to install the printer
It is actualy not picking the paper.but the yellow light keep blinking anytime.please help solve this problem thanks
  • 700 Answers
Is it normal then the yellow light is blinking? If not seems to be your having fault. Could be its not detecting ink---clean the connector or the cartridge connector with clean cloth. Or it detects paper jam, cover not closed.
Or you actually still did not install its driver.
Posted on Apr 28, 2009
Ready and alarm lights keep blinking. will not print
Service manual: ready and alarm blinking :
Paper Jam
Clear the paper jam and press the panel button if the printer
does not automatically resume printing.
Misfeed:
Re-install the paper and press the panel button.
Clear the jammed paper inside the printer. Press the panel button
if the printer does not automatically resume printing.
check the sensors:
1) Turn off the printer power switch, open the front cover, and remove the drum unit.
2) Turn on the printer while pressing the control panel button. The Drum LED comes ON.
3) Lightly press the panel button again.
Alarm LED is ON = Front registration sensor is turned ON.
4) Press and release the panel button again.
Drum LED is ON = Paper eject sensor is turned ON.
If sensors are On, paper is being detected, Off- no paper
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 21, 2011 | Brother HL 1240 Printer
Canon Pixma IP 4300 printer - 3 blinking panel lights indicate paper jam, however no paper jam is present. I turned off machine, pulled power plug, waited for 5 minutes, turned on printer, but problem did...
It is possible that the printer is having an error due to either a sensor fault ( optocoupler) in the paper detect section or a possible software issue.
So disconnecct printter, and uninstall the soft ware , the reinstall and then connecct printer to be detected and installed.
If the fault stays then the sensor must be checked.
Sep 11, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Samsung CLP-300 picking up too many pages
Hi
Thanks for using FixYa. Paper jam is a very common problem with the printers.
First of all clean off the rubber piece that pulls the paper into the printer from the tray with rubbing alcohol, and also take a knife to the rubber piece to rough it up to create more traction.
To clear the paper jam problem you need to remove the back roller mechanism to get at paper. If still the problem persists, then check the following to resolve the issue--
1. Please check all interlocks, electrical and signal connections are seated properly.
2. Front cover, back cover and lid are closed properly.
3. Power plug and USB cable are connected.
4. Printer is turned on with switch on the back.
5. Toner signal lights sequenced, with yellow overall led on.
6. There is some noise of paper roller movement.
7. Toner signal lights all out, overall status light turned to red
8. No visible paper in paper tray or anywhere else.
9. No paper in tray---added paper
10. Waste toner container is full or not installed ---empty, installed properly.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Samsung CLP 300 Laser Printer
Installation for my webcam i don't have the soft ware
I had lost my driver CD.
My product serial number is Veo-FC 650VS21X 009511
Pls send the driver soft ware
Mar 10, 2009 | Veo Mobile Connect Webcam
Paper jammed. pulled out. now yellow light flashes. runs, but no print
check the paper path, specially where the paper is being pickup. it might still have a small peice of paper stuck in the path. pull out the paper tray. can check the paper path in the front of the printer.
use a flash light if you can not see inside.
unplug it printer after you finished. wait 10 sec and plug it back in. that will clear the printer of any remaining print job, and rest the printer.
if this solve your problem, please rate the answer.
thank you
Oct 14, 2008 | HP DeskJet 5550 InkJet Printer
Various problems issues with my laptop soft ware hard ware
hey there,
1. you cant delete something that is from a read only file. it is impossable to do.
2. you have 2 do a degrag every week to make sure you have enough space.
3. you need 2 go into add or remove programs to uninstall your printer software. putting the disk back into the laptop is trying to tell the laptop that you want to install it but it already knows that you have that program in your system already.
Jul 28, 2008 | HP Pavilion dv1000 Notebook
Paper jam
There could be a tiny piece of paper blocking the paper path or sensor. See if you can find any.
Jun 30, 2008 | HP LaserJet 1200 Printer
Want installation software of hp scanjet 3970
we want officejet 4355 all in one printer instll our pc
May 04, 2008 | HP Officejet 4355 All-In-One InkJet...
Cannot remove yellow blinking light
does the printer cycle?
unplug the power from the outlet and plug back in.
Can you look and see any paper inside?
when you lift the cover does the cartridges move?
Dec 06, 2007 | HP DeskJet 690c InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
