Question about Philips Magnavox MWR10D6 DVD Recorder
Timer rec button keeps flashing and won't stop and record
  • betty
    betty Oct 14, 2013
    After everything is set to record, the timer record just flashes,
  • betty
    betty Oct 14, 2013
    its suppose to stop flashing and start recording, but it won't??
The cst in light keeps blinking how to turn it off
Hello
I managed to find a PDF manual for your VCR Combo, However i couldnt find anything to indicate a reason for the Cst in light flashing. I did find however find that the TIMER REC Light flashes if T-SET is pressed for a timer recording, but there is no tape in the DVD/VCR. It also flashes when all timer recordings or One-Touch Recordings are finished. So possibly this could be the light you see flashing.
The PDF can be found Here
Hope this helps
Mar 06, 2011 | Symphonic WF803 DVD Player/VCR
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
press
to select:
1~31= one time, or
DAILY= MON~ FRI, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
press
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
press
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Or
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
Sony dvd timer record light flashing ? how do
Press the timer button on the remote control. This will bring the manual timer screen up. Use the arrow buttons to select "Cancel". You will now have a list of programmes that are scheduled to be recorded. If any have unresolved next to them, select them and use the arrow buttons to select "Erase". Hope this helps - Pete
Jun 28, 2009 | Sony RDR-GXD360 DVD Recorder
Set the clock on my Panasonic NV-J11 HQ VCR
Hey there - I've got the exact same model VCR; although I've lost the manual as well, I've been using it for so long that I
can usually remember it all from heart:
To set the clock
1. Open the flip-down lid, push [CLOCK] button.
For each of the steps below, use the white-labeled [+] and [-] tracking buttons to increase/decrease each number.
2. Two digits should be blinking - this is the year (last two digits only) - adjust and push [NEXT] when done.
3. Two digits, with a "D" next to them should now be flashing - this is the month (1=January thru 12=December), adjust and push [NEXT] when done.
4. Two digits, with a "M" next to them should now be flashing - this is the day-of-month (1..31), adjust and push [NEXT] when done.
5. The time should now be displayed, with hours flashing - adjust and push [NEXT] when done.
6. The minutes of the time should now be flashing - adjust. When you push [NEXT], this will complete the date-setting and start the seconds-of-the-minute off at zero - handy for synchronising to an external time source (I recommend using the
Teletext broadcast clock if available - you'll usually find your recordings will start right-on time when you do this, depending on your TV station).
7. If you make an error at any step above, push [CLOCK] to exit clock-setting mode and start again.
Depending on your model of VCR - the clock may either persist through power failures (backup battery) or may have to be reset next time power is lost. Mine doesn't seem to have a backup battery.
To program the VCR for timer-recording: There are two modes, Timer Record (start and finish recording at arbitrary times in the future), and OTR ("One Touch Recording", start recording right now and finish at a set time in the future).
*** Timer recording ***
There are eight programme slots (numbered 1-8 on the display), each programme slot has an individual channel and start/finish time associated with it. Programmes can be scheduled up to 1 month in the future.
Push [PROG/CHECK] to cycle through each slot (after the eighth slot, it will return back to normal operating mode).
When you want to set a programme, push [PROG/CHECK] until you find an empty slot (date/time will be all dashes). Then do the following:
1. Channel should be flashing - set this using white-labeled [+]/[-] tracking buttons and push [NEXT] when done.
2. Date should be flashing (defaults to today), use [+]/[-] to adjust starting date and push [NEXT] when done.
3. Set the starting time ("ON" should be lit next to time) (defaults to now), use [+]/[-] to adjust starting time and push [NEXT] when done.
4. Set the finishing time ("OFF" should be lit next to time) (defaults to starting time), use [+]/[-] to adjust and push [NEXT] to complete the setting of this programme. After this, you'll be returned to the start of setting the next programme (the unit will also beep five times to confirm you have a valid programme set).
If you make an error (or you need to clear a programme slot that already has a programme set), hold down the [-] and [+] buttons for three seconds until the starting time/date becomes all dashes.
When you're done with setting your programme(s), keep pressing [PROG/CHECK] until you exit into normal operating mode, then push the [TIMER REC] button to activate the timer; this will put the VCR into timer standby mode, and the orange clock icon should be lit solidly on the display. There should also be a number (1..8) lit for each programme that has been set, but is still yet to run. Make sure you have the tape inserted and positioned in the right place when you do this.
After timer standby mode is activated, you can then push [PROG/CHECK] to review the individual programme slots; each push of [PROG/CHECK] will cycle through each slot (the display will time out in 10-15 secs).
To get out of timer standby mode (either when after the programmes have run or if you've made an error), push [TIMER REC] again - this will return you to normal operating mode (where you can fix errors if need be). Programmes that have run to completion should be automatically be cleared.
*** OTR (One Touch Recording) ***
This will start the tape recording immediately (good for when you have an unexpected distraction or sudden change of plans) and have it stop at a later preset time. The OTR mode only has one programme slot, unlike timer record.
1. Insert tape, have it positioned where you want to record from. Set the channel to the one you want to record from.
2. Open the flip-down lid, look at the bottom-right corner of the array of buttons inside.
3. Push the green-labeled [OTR +] button; this will start the tape recording instantly (the red "OTR" indicator should be lit on the display).
4. The stop time should also be displayed - use the [OTR -] and [OTR +] to adjust the stop time. When you're done, that's all you need to do (you can adjust it any time later).
To abort OTR mode (ie. if you start it by mistake, or want to stop the recording early), push the main [VTR] button to stop the recording. Yes, that's right - turn the whole thing off, it'll leave you in standby mode.
Hope this helps!
-- Bryan R.
Nov 26, 2008 | Panasonic PV-7451 VHS VCR
Unable to record or playback on new DP 02
It sounds like either the inputs are not assigned or the tracks are not armed for recording (or both).
Here is a quick explanation of the procedure involved in recording with the DP-02 that I posted for another person who was asking for some basic instruction on how to record. You might be missing a step somewhere along the line as for instance you will still see the meters move even if you don't have the inputs assigned or don't have any tracks armed, but the DP-02 won't record anything until you do both.
To record you need to first assign your input to a track, then arm the track for recording, and then press play + record at the same time.
1. So you would patch your mixer output, mic or instrument into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
2. Then to assign that input to a track simply press and hold the 'input A' button and then press the 'rec' button of the track you with to record on. The 'rec' button will flash rapidly to indicate that the input is assigned to the track.
(To assign the input to a different track you have to clear the input assignment from the first track and assign the input to a new track. To clear an assignment press the input assign key, A in this case, and the track it's assigned to will flash its 'rec' button. Hold down the input assign key and then press the flashing 'rec' button. The button will stop flashing and the input can then be assigned to another track by following step 2 again).
3. Next, to arm the track for recording simply press the 'rec' button for that track. The 'rec' button with flash slowly.
4. To begin recording press play + record together in the transport section and the 'rec' light for the armed track will stop flashing and light steadily. Press 'stop' to end recording.
This should get you started. The operation of the DP02 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Hope this helped.
Cheers,
bd.
Nov 25, 2008 | Tascam 2488 Portastudio Multitrack...
Don't know how to actually record
1. So you would patch you mixer's output into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
This should get you started. The operation of the DP01 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Cheers,
bd.
Nov 20, 2008 | Tascam DP01 All-In-One Recording Package...
Doesn't record when timer is set.
I found the manual and helped me get familiar with the remote etc. Tech. support solved my problem i was pressing the otr rec button instead of the timer rec button. Ken.
Nov 03, 2008 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Just bought a DP-02 w/40gb hard drive
You'll first need to find some aux audio out jacks on your karaoke machine. You might need an adapter, but the basic idea will be to connect the aux out from the karaoke machine to an input on your Tascam DP-02.
Then on the DP-02 you need to assign whatever input your plugged into to one of the 8 tracks. Let's say you're using the left input (input A) and want to put the karaoke music on track 1. You'll press the 'Assign A' button on the DP-02 and while holding it then press the 'Rec' button of track 1. The 'Rec' button will flash rapidly to show its been assigned. (for reference: assigning an input is better described on page 23 of the manual). Then you'll want to arm track 1 to record. Press the 'rec' button for track 1 and it will start to flash slowly to show it has been armed for recording. Now you are ready to start recording. On the DP-02 press the large round play and record buttons on the lower right together to start recording and start your karioke machine playing. When the song is done press stop on the DP-02.
Now to record your vocals you'll need your mic to be plugged in (lets' say it's in input B). You'll need to assign this input to a free track (track 2). Press the 'Assign B' button and while holding it press the 'Rec' button for track 2 (rec button will flash rapidly). Then you'll want to un-arm track 1 and arm track 2 for recording. To do this press the 'rec' button for track 1 so that the light goes off and then press the 'rec' button for track 2 so that it flashes slowly.
So now when you press play and record together to record, you'll hear track 1 playing (the karaoke track you recorded earlier) and you'll be recording vox on track 2. Of course you'll also be recording whatever you hear in the room onto track 2 along with your singing, so in order to get a clean recording there (prevent bleed) you'll want to plug some headphones into the DP-02 and listen to those as you record.
That's pretty much all there is to it. Some variations if you wish to record the karioke in stereo vs mono (I gave you the instructions for mono here), and you may need to turn on phantom power if you have a non-powered mic, but the idea is basically the same.
Hope this helps.
Good luck.
bd.
Oct 24, 2008 | Tascam DP01 All-In-One Recording Package...
Weekly timer recording not working
Have you tried setting the clock to manual mode: Page 18 in the manual I think.
Jun 30, 2007 | LG DBRH197H DVD Player/HDD Recorder
Not Able to Record/Playback
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
THANK YOU
Jun 16, 2007 | Olympus VN-1000 Digital Voice Recorder
Philips Magnavox MWR10D6 DVD Recorder Logo
35 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
