Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Copier is making tilted copies, when making copies.
    New Friend:
  • 38 Answers
You either have an obstruction in the paper path or a pick up roller needs replacing
Posted on Oct 11, 2013
While printing or photocopy the print in some copies is tilted in some copies it is straight.
check the paper guides in the casete . or clean the feeding rollers with alcohol
Apr 20, 2016 | Canon IR2870 COPIER FOR 220 VOLTS ONLY
What's your question?please how do I copy multiple copies with canoniR2000? mine copy's one n display incorrect paper size
Copying What You've Already Drawn ' SketchUp ...
https://help.sketchup.com/en/article/3000092
SketchUpWhen you copy and paste with the Move tool, you can make a single copy or createmultiple copies and tell SketchUp how to space them - if you know the ...
For Sale Canon IR2000 digital copier ' Facebook
https://www.facebook.com/media/set/?set=a.144875105642811...3
For Sale - Canon IR2000 digital copier Copy Speed 20 CPM First Copy ... Time 30 Sec Zoom 50-200% Duplexing Not supported Multiple Copies 1-99 Copier ...
Can I make multiple copies of the same DVD? - DVD-Cloner
www.dvd-cloner.com > DVD-Cloner Knowledge Base
Of course you can. Please use the option: "Number of copies" in the "Burn I/O" tab of the "Advanced setup" window. You can make multiple copies of the same ...
Canon Ir2000/2010/251/271Digital Copier - Buy and Sell Plus
www.buyandsellplus.com/.../Canon-Ir20002010251271Digital-Copier
Aug 28, 2012 - First Copy : Approx. 8.2 seconds. Max Copy / Orig. size : A3. Copying Resolution : 1200 x 600dpi. Multiple Copies : 1-99. Magnification Zoom ...
[PDF]iR2000/iR1600 Reference Guide - Canon
Dec 26, 2015 | Office Equipment & Supplies
The printhead is stuck in the tilted position, or is not able to tilt forward to the print position due to obstructions.
Has ink spilled around the printhead that is preventing it from moving? (you should be able to push the printhead from left to right) MAKE SURE THE PRINTER HAS BEEN OFF FOR 30 MINUTES BEFORE YOU TOUCH THE PRINTHEAD !!!
Is the printhead stuck to the Wiper Blade?
Check the process drive gears for damage and make sure they are aligned correctly.
Has ink spilled into the tilt gears assembly or on its drive train? (left side of printer)
Nov 12, 2013 | Xerox Phaser 8550DP Printer
Sharp AR 5320 Xerox machine is noisy now when am making copies more than 10.
Hi, noise means there is a problem with the copier mechanical parts however, yours appears to be a problem with copying area. This is caused by waste toner being full in its container and mostly machines also display triangle sign while making this noise.
Solution
  • Open front cover and pull-out the toner cartridge.
  • Carefully push open a notch with a spring on the side marked with green color and empty waste toner. If its hard to come out, use a flat screwdriver to scratch inside of waste toner compartment to loosen its grains then empty to the last dust. You can tilt the container upside down while holding the opening open and hitting gently on its side.
  • If not able, you can open the 6 screws supporting this holder and empty it. Note how it locks while replacing to avoid damaging the unit.
Dec 14, 2010 | Sharp AR-5320 Black and White Copier
When I copy - one side of whatever I copy doesn't copy. If I lay something face down on one side of the glass, it will copy. If I lay it down on the other side of the glass it won't copy.
make sure the copier is on level base and check the mirrors under the glass are not dirty or fogged up.. if you can assess the drum unit giver a few gentle rocks side to side and then try another copy the unit may be tilted and the toner going to one end. also there is probably a charge cleaner at the top of the unit you can pull in and out a few times.. I would look at the toner/drum side of things if it is faint on one side..
Jul 13, 2010 | Canon PC-940 Black and White Copier
When I turn on my Phaser 8400 I get an error message of 07,008.41:4825. What the problem. Thanks for your help.
7,008.4x: head tilt not engaged.
The printhead tilt is not engaged, so it didn't tilt back properly or the printhead is stuck in the tilted position by the tilt lock arms. The process motor gear train getting out of sync can also cause this error.
1. Try rebooting the printer.
2.make sure there is no ink melted under the printhead which can make it dificult for the printhead to work properly..
3. make sure that the printhead restraints are not broken.
4. Check for an obstruction or damage in the process gearbox.
Ensure the gears are correctly aligned and homed. If faulty replace the process gearbox assembly.
5. Run the Tilt Axis Drive test to test the headtilt.
6. Run the Head Maintenance Wiper Clutch test. If the test fails, replace the wiper drive clutch.
7. Run the Wiper Axis Drive test.
8. Replace the exit assembly.
good luck!
Nov 13, 2009 | Xerox Phaser 8400 Laser Printer
Top to Bottom gray line on left side of Copied Page
hello
does the grey line appear if you scan true the "upper" scanner.(set paper on top of printer and sscan it that way)? you should also clean the smal slim glass that is at the side of the big scanner glass.
also try to remove all cartridges and tilt them side to side several times. then put them back and test your printer.
Jul 02, 2009 | HP LaserJet 2840 Printer
Canon NP 6050 Paper Feeder won't feed
Seems the wheels on the left side of the feeder maybe slipped or something, I turned them 1/2 way over so the gray rubber part shows, then they were able to grip the paper and feed it into the copier. That worked for a little while, then it did it again, I turned them again and it worked. Maybe I just need to make sure they have a little traction to solve the problem. Thanks for your website.
Apr 01, 2009 | Canon NP 6050 Copier
Can't make copies
I had the same problem just yesterday. Turn off the printer for 10 seconds. Then turn back on. Turn back off again and unplug from the electrical outlet. Open the control panel and tilt it toward you. Close the control panel, plug machine back into the outlet and turn back on. I did this and it solved my problem.
Sep 10, 2008 | HP Laserjet M1319F Laser Multifunction...
2nd side crooked
I would have to say that there must be a same piece of paper touching the paper as it is being feed through the duplex ass'y. The best thing to do is to see if the copy gets tilted toward the front or rear of the copy/ copier. You will be able to find where the obstruction is in the dupex path.
Feb 23, 2008 | Canon D320 imageCLASS Digital Copier
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
27 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
