Question about Sharp AL 1631 Copier
Copy button not making contact unless I push and move it around at the same time
    Habit-Forming:
  • Sharp Expert
  • 190 Answers
Replace copy switch.
Posted on Jan 07, 2014
My horn isn't working quite right. It only blows if you push the button in a certain place and that certain place moves around all the time. But even when it does blow, it stutters. I don't think...
if it was a fuse problem the horn wouldn`t make a noise.it sounds like the horn contacts that touch when you push on the button are not making proper contact each time.if you remove the horn button and look at the contact spots you may see the problem(uneven contact surfaces).if you move/bend the contact surfaces closer to each other of straighten this may help the problem.you may even have a horn that needs to be replaced as you said when it does work it stutters and not blow.the diaphragm in the horn can dry out and not vibrate like it should.try tapping on the horn when someone tries to blow the horn if it stops or gets louder then the diaphragm is no good.you could also check the connection at the horn itself it may have a bad connection due to corrosion and just need cleaning.
Aug 10, 2011 | 1992 Jeep Wrangler
Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Apr 21, 2010 | Watches
The receiver button is stuck and cant get a dial tone
try a little rubbing alcohol on a q-tip, not too soggy- run it around the edges of the button. push on the button, until it seems looser- apply a little more alcohol around it- push the button a few more times, if it starts to move- run a clean q-tip around it to soak up any gunk- try repeating the alcohol- push- clean until it moves freely! then, if you have it, a little wd-40 on a q-tip applied around the edges of the button should free it up!!
try not to spill anymore 'red-bull' on it! or you have young children! 'little spillers'!
good luck!
Oct 29, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Problem starting computer
Intermitten problems such as this are usually caused by loose connections or cables and/or components unless the component/s are intermittenly faulty. Components may not make proper electrical contact with the motherboard, especially RAM modules and may require removing build up of dust on connectors.
I suggest removing all components, clean and remove dust and reseat the RAM, the PCI & AGP cards, all the cables to the drives and the motherboard.
If all goes well you will have a stable computer that you can move around.
Sep 23, 2009 | Dell Latitude D600 Notebook
Hi, The dryer drum does not start when the start button is pushed unless I rotate the drum to a specific position.
When we had this problem the solution was to replace the motor, the electric coil in the motor had a flat spot which would not make contact and let the motor start. By moving the drum you are advancing the motor away from the flat spot. Hope this helps.
Jul 12, 2009 | Asko T721 Electric Dryer
Copying contacts from Phone to Sim Card
1 take you to the main menu.
8 gets you to your contacts.
Very top left button with three dots gets you to options.
Then you have to hit the down button 12 times, to get to 'Copy to sim'.
Then hit 2, to select multiple.
Then hit the middle button to select all.
Then hit the very top left button again to copy.
And it will ask you to continue, and hit the very top left button one more time.
Then wait until it has copied them all.
But since you have no screen, you probably won't know when that is, unless it makes the noise it makes when it is done with something. Or just wait a few minutes until you think it is done copying.
Hope this helped.
Mar 31, 2009 | Samsung SGH-A707 Cellular Phone
Door won't close unless i push button on wall several times
You probably have a stripped gear inside opener. Take off cover and the bottom will be filled with white flakes from stripped gear
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
My sony ericsson has no screen
Ok, I figured it out. To save contacts on a z310a that has a broken screen, do the following: 1.From standby, (make sure the backlight is lit up) press the center button once 2. Press down once to go to address book 3. Press center button to enter address book 4. Press RIGHT select button (upper right button with line through it) to select options. 5. Press down FIVE (5) times to go to Advanced 6. Press center button to go into Advanced 7. Press down FIVE (5) times to go to Copy To SmartChip 8. Press LEFT select button to enter 9. Press LEFT select button to select "Copy All" 10. Press LEFT select button to confirm. Wait a couple of minutes to make sure all your contacts were transferred.
Jan 04, 2009 | Sony Ericsson K800i Cellular Phone
Keyboard buttons
Just try in DOS mode (NOT FROM COMAND PROMPT UNDER WINDOWS), if it's work normally probably cause from your Windows, try change keyboard setting from control panel or reinstall u're Windows
Aug 19, 2008 | Acer Aspire 4520-5582 Notebook
Viceroy sapphire ladies watch instructions
Looking at this watch I believe the lower right button changes the watch between chrono & time. Push that button until the hand in the bottom dial is on time. Then see if the bottom right button pulls out. If it does then this will put the watch in time setting mode. Now push the top right button. This should move the hands around so you can set the time. I hope this works I'm trying to go by what the watch looks like.
Mar 07, 2008 | Watches
Sharp AL 1631 Copier Logo
19 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
