Question about Coleman (5040B750) Patio Heater
Need manifold wiring diag. for the williams mod.35G-C-5 wall heater
    Top Expert:
  • Coleman Master
  • 45,139 Answers
Williams might be able to supply a manual
Posted on Oct 11, 2013
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
Wiring diag. for a williams mod#35GV-c-5 thermocoupler
I have never seen a thermocouple needing wires hooked up on it
Oct 11, 2013 | Coleman (5040B750) Patio Heater
Where is the orifice on a williams wall gas heater 290622
Where the pilot is unscrew pilot tube from pilot assembly and inside there it is
Feb 26, 2013 | Williams (5009622) Ceramic Gas Wall...
Hello i have a williams wall Furnace model#25-35-50. I need to know if its a base board heat and also if you could tell me which wires are which. 1 red and 1 white
What you have is a Direct Vent, Gas WALL Heater. It is normally mounted about 6" off the floor on an exterior wall (since it has to be direct vented out). Not sure what the red and white wires are for, but suspect it's for the optional thermostatically controlled blower connection.
In any event, to help you install this heater properly, I have included a link to the Owner/Installation Manual, which should provide all the information you need to complete the installation correctly.
http://shopfnc.com/pdffiles/williams2man.pdf
You can download and print the manual for future reference.
Feb 26, 2011 | Williams 3003622 Ceramic Wall Mounted...
One of the thermastat wires attaching to the williams heating on the wall became loose from the screw and didn't seem to be making little of no solid contact like a car battery might due. i tightened the...
If it touched a grounded metal surface, it is possible, leave the wires hooked up at the furnace, pull the thermostat off of the wall, disconnect the 2 thermostat wires, and then twist them together, the furnace should fire, if it does, then the thermostat is shot. Replace the thermostat, usually when there is a short, it burns out the heat anticipator on the thermostat.
Good Luck,
Paul Gibson
Apr 03, 2010 | Williams 1403622 Gas Compact Heater
I have a Williams Ceramic Gas Wall Mounted Panel Heater, the pilot is on but the furnance is not working
Jump the two wires going to the thermostat, if it starts , you have either a bad thermostat or a broken thermostat wire. If it does not fire up, you will need to check for 24 volts AC going to the gas valve from the transformer. If you have voltage, you have a gas valve issue. If no voltage, check for a limit switch that may have overheated with an Ohm meter. If they all test good, replace the transformer.
Jan 22, 2010 | Williams 2509612 Ceramic Mid-Size Heater
We have a Williams wall heater that was gas/ converted to propane that is newly installed. The thermostat does not work. Any suggestions?
Assuming the pilot is lit, try jumping out the thermostat wires where they come into the valve. A paper clip would work. If it works, the problem is in the t-stat circuit.
Dec 30, 2009 | Williams 3003622 Ceramic Wall Mounted...
Williams wall furnace no longer adequately heats home
A couple thoughts. On some of the wall furnace gas valves there's a knob that you can set for low fire or high fire. If your valve has this make sure it is in the high fire setting. Is the wall furnace controlled by a wall thermostat or a knob on the heater? With the thermostat turned all the way up like to 90, does the burner and fan continue to run or is the burner short cycling. Is the fan clean and running up to speed. Some of the Williams wall furnace had a two speed fan motor so when the fan came on at first it would run on low speed. As the heat exchanger got hotter the internal fan switch would switch it to high speed. Outside of that you would need a monometer to check the manifold gas pressure.
Aug 31, 2017 | Heating & Cooling
Coleman (5040B750) Patio Heater Logo
82 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
