Question about Speed Ceiling Fan 3-speed Switch By Westinghouse 77021
I have a harbor breeze ceiling fan on a dimmer
I have a harbor breeze ceiling fan on a dimmer switch. the fan has 2 green, a blue, a black and a white wire. the ceiling has 2 copper, a black, a red and a white. when the fan blue is connected to ceiling red and black to black, the light works but not the fan. when the fan blue is connected to ceiling black , and ceiling red to fan black, the fan works but not the light? what do i need to do?
  • 44 Answers
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Posted on Oct 16, 2013
  • 34 Answers
SOURCE: Which terminal is the Power wire supposed to
IF YOU KNOW MAKE AND MODEL OF FAN,
LOOK IT UP ON INTERNET-THERE MAY BE A
WIRING DIAGRAM THERE ALSO.
Posted on Jun 21, 2009
SOURCE: changing the 3 speed switch on my westinghouse ceiling fan
De-coding the nonsense..........
Black = L = Power
Brown = 1 = Low Speed
Purple = 2 = Medium Speed
Gray = 3 = High Speed
Posted on Aug 18, 2009
  • 4090 Answers
SOURCE: I broke the chain for the fan on my ceiling fan
look at this diagram it has the L 123 configuration
just not the same color code other than RD and Blk
but you should be able to work it out anyway
http://www.hurontel.on.ca/~taitg/pages/cfan.html
Please rate our help++++Thyanks for using FIXYA
Posted on Oct 11, 2009
  • 157 Answers
SOURCE: I have a Hampton Bay
Hello. Yhe most common combination for this wire combination is: L - White, 1- Black, 2 - Blue, 3 - Yellow . However this is assuming your 77021 (the fan) has three speeds and the pullchain has four wires. Here's a link to some very good troubleshooting advice: http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php
and a link to Diagrams: http://www.hurontel.on.ca/~taitg/pages/cfan.html
Hope this helps, and don't forget to rate our help. Thank you.
Posted on Mar 19, 2011
SOURCE: i have a westinghuse fan with light it has four
Question posted under 3-speed switch
1) Are you replacing the 3-speed switch?
This is a field with much discussion because Westinghouse 4-wire fan switches vary.
Process of elimination is needed to find hot line. From there you test each wire to the hot line wire to determine which wire or combination of wires makes up low, medium, and high speed.
Open following links for some resources:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
http://www.atlantalightbulbs.com/ecart/catalog/westinghouse-6.html
2) Or are you looking at fan connection wiring at ceiling?
Green wire goes to bare ground.
Fan should have hot and neutral.
Hot line should be black.
Neutral should be white.
Red usually goes to light
Blue is normally not there.
Where is the white neutral wire?
Take multimeter set to read ohms and test black wire to each other wire.
Process of elimination should reveal correct wiring.
Posted on Aug 21, 2011
I am trying to install a ceiling fan and from the ceiling I have a copper white and black wire. Now from the fan itself there is a black blue and white wire. Not sure where to connect the copper wire.
Good question, proper wiring is a crucial virtue that needs to be one hundred percent accurate.
Three wires showing from the ceiling lamp fixture harness, positive, negative, and ground.
The negative wire is the white wire,
The Hot wire (positive) is the wire of brighter color than known negative,
220V AC (alternating current) home wiring to(" duplex outlet switch, GFI switch, single/dual pole light switch, lamp fixtures,") the Hot wire or lead, is normally Black, the lighter color, or White is neutral or neggative,
Neutral wire (completes circuit) allows current flow to continue through to other parts of house, Alternating current.
The Ground wire is usually wrapped in green color, or unmarked copper.
The copper wire from the ceiling will need to be grounded to the metal bracket on the new light fixture, a gold or silver screw, sometimes tagged with green, is the proper grounding location, Any place on Metal not attached to ceiling bracket, Ground should be attached to metal on fan,
White wire from Fan is neutral, Negative.
Black wire from Fan is Hot Wire, Positive,
If Blue wire from Fan is Not Manufacture spliced, Meaning no Copper is exposed, Wire is not used, Blue wire is NOT ground,
If Fan has a light, Voltage from Hot Black wire will supply both light and fan functions,
Safety First.
flip off breaker switch to the room fan is being installed.
Doubble Check
Black^Black wire connection is secure.
White^White neutral wire connection is secure.
Ground is fastened securely to metal or wrapped under a screw.
Using splice caps is recomended, The plastic shell encloses the wire connection ensuring No stray copper is exposed, limits possibility of cross wiring.
Google the brand of fan being installed, and Check wire color code, and wiring diagram, Info good to have, and checking twice will only guarantee Lamp Fixture Install Well Done.
(Blue wire may be there for installing multiple ceiling fixtures in a loop circuit, so all controlled by same light switch.)
Enjoy Your New Fan,
Jos
Thoughts&Comments, encouraged jtobias1020@gmail.com
Mar 26, 2017 | Dryers
Ceiling fan wiring diagrams
Most usually you will have four wires. One raw copper, one white. One blue and one black. The raw copper would mount to the casing (usually to a green screw) this will be what is called an earth ground. It will divert any stray voltage to the outside ground rod. The white wire is called a neutral ground wire. It goes to the white wire in your casing of the fan/light. This wire goes to your breaker box ground terminal. The blame wire will be your positive (hot) wire to your light section. Connect it to the black wire coming from the ceiling box. Do not put your wire nut and or tape on yet. Connect the blue wire to the black wire connection. The black wire that is in the ceiling box is the positive (hot) wire from your wall switch which comes from your breaker box. Occasionally you may find two switches on the wall, one for the light and the other for the fan. In this event you will have two sets of wires in the ceiling box. Use the black one on one of the black fan/light wire and the other black wire in the ceiling box connect it to the blue wire. If there is another white wire, connect it to the other white wire. Do the same with the raw copper wire. NEVER CONNECT A WHITE WIRE TO A BLACK WIRE. OR A RAW COPPER WIRE TO A BLACK WIRE. THIS WOULD CREATE A DIRECT SHORT AND ELECTROCUTION COULD OCCURE. Turn your power back on when you have completed your job and check each switch. If the switches are not in the location you prefer, turn you power back off and either reverse the location of the switches in the wall box or you can reverse the blue and black wires in the ceiling box.
Aug 06, 2014 | Canarm Ltd HLW-HL50-09 2" Insulated...
Wiring instructions for harbor breeze ceiling fan model wsc52wb5c
Since that is a low-end store brand(Lowes) I can only guess the usual. Black to black,white to white,green to green or copper wire,blue to red.If no red wire in ceiling then put blue & black from fan to black in ceiling.
Mar 27, 2013 | Dryers
Wiring diagram for harbor breeze celing fan
The colors of the wires in the Harbor Breeze ceiling fan kits tell you what their functions are. The black wire is hot for the fan, the white is a common wire for both the fan and the light kit, green is ground and blue is hot for the light kit. locate the black and blue wires from the ceiling fan and connect them to the black wire inside the electrical junction box by twisting an orange wire connector onto all three wires. Locate the white wire from the ceiling fan and the white wire from the junction box and attach the two wires together with a wire connector. Connect the bare copper wire onto the green wire from the ceiling fan mounting bracket by twisting an orange wire connector onto the two wires. Push all wiring inside the electrical box. good-day !
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
I need to connect a bathroom pull light
well most home are basic white black green and or red following black to black hot wire white to white neutral copper is your ground your red or blue is low volts older homes can be yellow or red that is for your blue red wire turn off circuit breaker to outlet or light fixure you or working on first and formost
Apr 05, 2010 | Solar 2-wire Pull Chain Light Switch For...
Does the blue wires connect to the black or white wires? I cannot find the instruction booklet. Thanks
Hi, At the fan you'll have a black wire, blue wire, green wire and white wire.
In the ceiling you'll have a black wire, a white wire, and a bare copper wire. If you are using the same wall switch to turn on all of the power to the fan AND the light, connect as follows:
White at ceiling to white from fan
Black at ceiling to black and blue together from fan.
Bare copper wire at ceiling to green wire from fan.
When connected like this, the main power is from the switch, and the fan and light may be set by the pull switches on the fan.
Best regards, --W/D-- Please feel free to rate this solution... thanx!
Aug 03, 2009 | Casa Vieja Endeavor Cherry Ceiling Fan
I cut the plastic wiring connector, fan motor to to light kit, from a Harbor Breeze paddle fan. This connector had a short in it, and I wanted to hard wire around this connector. I reconnected all of the...
The top wires, black, white, and green are the ones to hook to just run the fan. The blue wire is wired with the black at the top if you want the lights to work. At the light kit, the blue and white wires power the lights.
Apr 21, 2009 | Electrical Supplies
2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Jan 15, 2008 | Hampton Bay 46056 Callaway II Ceiling Fan
Hampton bay Windward III
Green and copper are the ground wires and I believe you can connect both these to the green wire from the fan (I only have the copper wire in the actual ceiling box). Black and Red can be treated as both black and both can be connected to the black wire from the fan (this is what I did in all my fans and it worked). White is the neutral wire and can be connected to the white wire from the fan (this is what I did in all my fans and it worked).
My ceiling box has the copper, red, black, and white wires. The ceiling plate for the fan I bought had a green wire. I connected the green wire from the ceiling plate and the copper wire from the ceiling box to the green wire from the fan.
Dec 29, 2007 | Hampton Bay 52 In. Black Huntington III...
Installation of wall remote for harbor breeze ceiling fans
One black wire on the switch hooked to the black sources wire. The other black wire on the switch hooked black up to the fan. The green on the switch wire goes to the bare wire. If there is bare wire you can use the white wire.
Nov 17, 2007 | Dryers
Open Questions:
See all Speed Ceiling Fan 3-speed Switch By Westinghouse Questions
Speed Ceiling Fan 3-speed Switch By Westinghouse 77021 Logo
441 people viewed this question
Top Speed Electrical Supplies Experts
epangan29
 Generator Guru...
Generator Guru...
Are you a Speed Electrical Supply Expert? Answer questions, earn points and help others
