Question about Zyxel U 336S Modem
Quick myfi stc 38f9 - Zyxel U 336S Modem
My stc usb quick net is not working
My stc quick net not working in 1month before what can i do please advise me
Dec 28, 2012 | Cell Phones
I have stc quick net modem with ime no.867597003545818...pls give idea about how to unloack this
i have stc net work setter.i insert sim and connect to computer.but not asking any cod.net work provider name showing.i have nck,nsk.....cod.what i do pls.give me replay....
Jul 30, 2012 | Computers & Internet
How To Unlock STC USB Modem?
Modem name :
Quick net
Firmware version :
IX1B4700XX
IMEI :
867597002499017
Unlock code please.
Thanks.
rajayasiraziz@gmail.com
Feb 02, 2012 | Cell Phones
I have a volvo s80, a light on the dashboard has a photo of a car that is leaning inside of a triangle,what does that light mean
The "leaning triangle" light is the light signifying there is a fault with the traction system (STC) a quick scan with a scan tool will tell you exactly what the fault is.
The only other triangle light on these cars is the triangle with the circle and the exclamation point. Which is either Orange or Red depending on the severity of the issue. And what you described sounds like the STC light to me.
Hope this helps.
Sep 18, 2011 | 2001 Volvo S80
Qucknet stc modem from Saudi Arabia model TCT mobile CE0700 can it be unlocked Pls help details TCT mobile ltd Model HSDPA Rev T11A1000xx IME13562370303176653
Your cell phone may be locked to a particular cell phoneprovider and in this case it needs to be unlocked to use with a different cellphone service provider. To get the security code/restriction code to unlock thecell phone from the current cell phone provider so you can use the SIM cardwith a different phone provider, Please click on this link and follow myinstructions :- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then this WEB siteit provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw Try this WEB site also - UnlockFree http://www.unlock-free.com
Dec 31, 2010 | Computers & Internet
MYFI XM2GO WILL NOT TURN ON. ALSO WHEN I PUT IN CRADLE WILL NOT SHOW CHARGING
I had the same problem. This procedure from the "Technical Questions" section of http://shopdelphi.com/consumers/support/faqs/myfi/ worked for me:
"My MyFi won't power up, how do I reset it?
To reset your MyFi, start by turning the receiver off and removing it from its (car, home, audio system) cradle. Then remove the back cover and battery. Using a small paperclip, press the reset button located on the top left corner of the battery compartment. Now plug the AC power adapter into a wall outlet and plug the power port directly into the bottom of the MyFi (battery stays removed). Wait 10 seconds and listen for a beep. After you hear the beep the message "insert battery" will appear. Cycle the MyFi to ensure it powers up and powers down. If the power cycle is normal, then turn off the MyFi, unplug the power adapter, and reinstall the battery. Re-plug the AC power adapter directly into the bottom of the MyFi. Wait 10 seconds and listen for a beep. After the beep you will see the message "battery charging". Leave the MyFi plugged in until it's fully charged. You will see the message "charging complete" displayed. After the MyFi is fully charged, turn it on and reset to the factory defaults. Unplug the MyFi from the AC power adapter and using the battery power leave it on until it fully discharges (approximately 2-5 hours). Plug the MyFi in using the AC power adapter to recharge the unit and resume normal use. If you need help at any point during this process contact us at 1-877-463-3574 for technical support."
I hope it works for you too.
Sep 27, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Bought new battery about a month ago, everything until last week. Now my MyFi will not power up. What can I do?
Pull the MyFi from the base and plug the power cable directly into the bottom of the SkyFi radio - you should be able to power up with it plugged in directly, even without any battery. Give it a try and let me know.
May 18, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
My delphi myfi xm2go will not recharge. What do I
New battery - make sure it's WHITE and not a black one as the black ones were recalled.
Nov 21, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
MyFi remote control has stopped working
ok take the battery out of the radio then put it back in and it should work mine did the same thing to me
Nov 24, 2007 | Delphi MyFi SA10113 XM Radio Receiver with...
Zyxel U 336S Modem Logo
59 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
