Question about Scotsman Cooled Modular Contour Cuber Air Condensed 975lbs
Red bulb for refrigeration comes on. When cycling manually, water enters the area where is should be made. Nothing is cold. Fan blades turn free by hand, but do not run during the manual cycle. Help please!!
    Novelist:
    Champion:
  • Scotsman Expert
  • 373 Answers
Has the CM3 controller been changed out? If so and it is the Universal service controller look on back to make sure the model- program selection switch on the side has been set to correct number.if so then unplug unit then plug back in push freeze tab let run and check all the refrigeration components. we know it is not a water problem or the water light would be lite up. If when you push freeze tab and nothing comes on and the water sump tray is full of water then replace Service controller.
Posted on Jul 03, 2014
Ice machince is going max freeze cycle shut down
1. Possible cause. Water leak. Check purge valve, water curtain, sump, sump hose.
2. Air filters clogged. Clean air filters.
3. Dirty condenser. Clean condenser.
4. Restricted location, intake air to hot. Have machine moved.
5. Ice thickness sensor dirty or disconnected. Check ice thickness sensor probe.
6. Water distributor dirty. Remove and clean water distributor.
7. Inlet water valve leaks through during freeze cycle. Check water inlet valve.
8. Connected to hot water. Check for bleed through from missing check valve in building water supply.
9. Incomplete harvest. Check harvest system.
10.High pressure cut out opened. Check fan motor pressure control, check fan motor, check controller using test mode.
11. Fan motor pressure control open. Check fan pressure control.
12. Fan motor not turning. Check fan motor, check fan blade,check controller using test mode.
13.Water pump not pumping. Check pump motor,check controller using test mode.
14. Pump hose disconnected. Check hose.
15. Compressor not operating. check compressor contactor, check controller using test mode.
Check compressor start components, check PTCR resistance and temperature, check compressor voltage, check compressor windings.
16. Low refrigerant charge. Add some refrigerant and restart unit. If cycle time imporves, look for a leak.
17. Hot gas valve leaks through during freeze. Check hot gas valve for hot outlet during freeze.
18. Thermostatic expansion valve bulb loose. Check bulb.
19. Thermostatic expansion valve producing very low or high superheat. Check evaporator superheat, Change TXV if incorrect.
20. Compressor inefficent. Check compressor amp draw, if low and all else is correcy, change compressor.
Sep 28, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Noise from condenser fan. I cleaned the blade and the surronding area. Put some w-d 40 but the noise is still there. It is cold. Should I replace the motor? how hard is it to do? kenmore coldspot...
Go to www.searspartsdirect.com enter your model number and select model number search.
Here you can see a diagram of the unit. The fan motor cost 95 dollars.
It depends on the type of noise it is making.
These motors when failing tend to hum when trying to start which is a sign of a dry bearing.
Rattling sounds or ting ting ting sounds are either a lose fan blade (check the cheap retaining clip on the front of the shaft .. it may have wiggled forward causing the blade to wobble) or a lose mounting screw.
Also I can't tell from the diagram how close the fan is to the drip tray(tray evaporator) These fans not only aid in removing heat from the condenser.. they help evaporate the water in the drip tray.
If you remove the motor.. have it tested before replacing it. At a hundred bucks it's worth a trip to a good electric motor shop.They generally will test it for free.
If you are able to determine the voltage and hook it up out of the cabinet you may save yourself a trip.
Chances are it's a lose mounting screw or that front blade retaining clip.
Best of luck!
Apr 30, 2011 | Kenmore 64254 / 64252 / 64259 Top Freezer...
The divider wall between the fridge and freezer stays very hot to the touch. Possibly the defrost mechanism is stuck??? Any ideas?
Check the fan which cools the compressor . Sometimes something gets caught in the blade . Also check that the coils at the front bottom are clean . If the motor is not turning and nothing obstructing the fan blade , replace the motor ( condensor motor )
Jun 16, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hi, Our refrigerator freezer has ice forming in the bottom and the fresh food side does not get cold enough.
theres a fan in freezer section check that it is not blocked or frozen turn stat in fridge to make colder & listen for fan to go on if no fan movement remove cover and check that there is nothing blocking and blade & is free to turn if or no blockage in housing and test fan for repair or replacement
Oct 16, 2009 | Magic Chef Refrigerators
Not Cole -- fan inside are blowing room temperature air
If after freeing the fan blade it still will not turn, you have a bad fan motor. (almost certainly due to it being restricted.)
That will cetrtainly cause it not to cool properly.
If the fan will not turn after freeing it, it will need to be replaced. If it does turn properly, unplug the fridge for about an hour to let the compressor cool down. Make sure all the coils vents etc are free of dust and dirt. Plug it back in, and if the fan is still operating properly, you should be back down to temp in a few hours max.
Aug 31, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Light on in fridge but no compressor sound or clicks or fan
That dude is probably stuck in the defrost mode.
OK try this:
1. Unplug refrigerator
2. Turn Cold Control to “off (Compressor is off)
3. Plug in refrigerator
The defrost cycle has now been initiated. The DTT has a bypass/test point for diagnosis. To terminate defrost manually:
1. Unplug the refrigerator
2. Turn the cold control “on” (Compressor is on)
3. Plug in the refrigerator
The defrost cycle is terminated and refrigeration cycle resumes.
Replace the dang adaptive defrost if you cannot get any response.
May 10, 2009 | Jenn-Air JCD2389G Side by Side...
Avanti compact Refrigerator NOT COOLING
I had this same problem. I did some troubleshooting and figured out that the fan was being bogged down by ice. It wouldn't spin because the ice was so heavy. I turned the power off completely and let the ice melt. Once the ice was removed from the fan, the fridge began working again!
Feb 16, 2007 | Avanti EC15W-2 Compact Refrigerator
Scotsman Cooled Modular Contour Cuber Air Condensed 975lbs Logo
70 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
