Question about Baumatic Refrigerators
How to align the door on my fridge - Baumatic Refrigerators
    Top Expert:
  • Baumatic Master
  • 34,733 Answers
The usual alignment procedure consists of loosening the attaching hardware, making the necessary adjustment, and tightening the attaching hardware
Posted on Oct 11, 2013
The fridge keeps on producing water. It comes from the drain area at the back. How can I rectify this ?
Water production is normal. The process of cooling caused condensation and de-humidification. Refrigerators have drain lines that flow to a tray in the bottom for this purpose. The heat from the compressor and fan then evaporate that water. Most of the time the user is unaware of the process. If there is major air leakage into the unit, then there can be issues of excessive water and tray overflow issues. Check door seals and door alignment to ensure that when closed, the fridge is airtight. Newer fridges have many bins in the doors which can add weight to them and make them lose alignment.
Jun 18, 2015 | Refrigerators
What is the plastic knob under the door hinge used for on kenmore model 7803 refrigerator?
Most modern fridges have these small plastic knobs [usually both top and bottom]. They are usually only COVERS for threaded mounting holes so that the fridge/freezer doors can be mounted for either left OR right opening ... ok They are generally around 1/2" [13mm] in diameter x 1/8" [3mm] in height.
They also help support the door [when it is closed] and prevent any "sagging" and/or mis-alignment or distortion of the fridge door which [these days] can be quite heavy when fully loaded.
Oct 20, 2014 | Kenmore Refrigerators
What would make our maytag side by side drip water up top near the freezer side. I just noticed today that the door on frig side doesn't seem to be closing tight. Anything we can do?
not sure what is blocking your door from closing tight. there are adjustment screws on the top of the door hinges under the plastic caps that align the doors.(they are there on my maytag side by side). the water could be from some ice buildup in side the housing at the top of the inside of your fridge where the flap opens up to send cold air from the freezer to the fridge, especially if your door has not been closing properly that will ice up trying to keep the fridge cold. remove everything from your fridge, unplug it and take a blow dryer to that housing to remove any ice buildup on the flap then plug it back in. there are also diagnostic checks you can do using the temperature control buttons to test if the flap is working properly as well. they are in your owners manual.
Jul 04, 2014 | Maytag MSD2454G Side by Side Refrigerator
Fridge door squeaks, freezer door bumps
Slacken the three screws, align the door and tighten the screws up again. Try not to lean on the door when it's open.
Apr 21, 2012 | Refrigerators
Viking fridge is not cold - what to do
Have a tech come out and re-align the door and perform a service check on the system. It's possible the mis-aligned door is your problem. Hope this helps. Ella
Aug 18, 2009 | Refrigerators
Fridge door will not stay shut
Glenn,
Easy... The door alignment adjustment is done at the top hinge. Pull up a step-stool, then remove the hinge cover. Under there you'll see three screws, I think they're 5/16". Loosen these (since your door has dropped, they're probably already loose), then lift up on the door handle to align it with the other door... while keeping the door aligned, tighten the hinge screws (and put alot of torque on 'em to keep 'em from loosening in the future). Now just replace the hinge cover and your done!
SG
May 26, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
On my GE Profile side by side the Fridge side the door will close and then pop open. The door has been making a clicking sound when opened. When it pops open it does not close again.
This can happen if the door gasket is not seating properly. If it is deformed you can correct this by pouring boiling water along the deformed area, then closing the door and keeping it closed while the gasket cools and sets. Please check first that it has been correctly installed, there are screws and a bracket behind the gasket. Another problem could be the alignment of the door. It is possible to adjust alignment on the hinges. One other thing is to raise the front "feet" so that the fridge slightly leans backwards.
Mar 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Door will not shut tight
Could be the following
Fridge not level to floor - adjust or chock untill level
Seal old or deteriated - replace with new seal
Door out of alignment with frame - adjust hinge assembly if possible
Damaged door - Replace
Obstruction from inside fridge- Check and clear if possible
May 11, 2008 | Refrigerators
Refrigerators Logo
Top Baumatic Refrigerators Experts
Sal DeAngelo
Colin Stickland
Colin Stickland
Electric Dime
Electric Dime
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
