Question about Cisco NSS 324 Smart Storage Network Storage Server NSS 324
When I boot up my NSS324 it takes forever to Boot and Load the drivers and then it won't configure the Raids. How do I resolve this?
  • 120 Answers
Please update the IOS
Posted on Oct 18, 2013
Takes forever to load the OS
Sometimes windows is installing or configuring updates that takes windows a long time to boot. WebRepOverall ratingThis site has no rating(not enough votes)
If its not due to installation of a program or configuring updates then the only reason left is windows internal errors.
Perform the following tasks to fix this problem:
  • Fix Damaged or corrupted registry
  • Fix Missing or damaged DLL files
  • Scan with Anti-virus
  • scan with Anti-Spyware
  • Delete Temporary internet files
To fix this problem instantly use Intel Software Partner Reginout.
Dec 13, 2012 | Toshiba Satellite L775d-s7206 1.40ghz Amd...
Tip
Clean Boot in Vista
Removing the software and reinstalling it using a clean boot may resolve the symptoms you are experiencing. The following instructions will walk you through this process.
  1. Remove the older software.
a. Unplug the device from the computer. Later you will be prompted by the software to plug in the device; do so at that time only.
b. Open the Windows Control Panel.
c. Open the Add / Remove Programs window.
d. Locate the listing for the device software/driver and remove it. When prompted to remove the device files, click Yes.
e. Locate any other device software/driver and remove it as well.
To Boot Clean in Windows Vista
Accessing the System Configuration Utility
1. Click Start and select Control Panel
2. Click System and Mantience
3. Click Administrative Tools
4. Double Click System Configuration
Configure Selective Startup options
1. On the General tab, choose Selective Startup
2. Uncheck Load Startup Items
3. Select the Services tab
4. Check Hide all Microsoft services
5. Click Disable all
6. Click on OK
7. Click Restart.
Install the downloaded device driver/software. After performing the necessary steps, restore your system by doing the following:
4. Double click System Configuration
5. On the General tab, choose Normal Startup
6. Click Ok
7. Click Yes, when asked to restart your computer
on Jun 03, 2008 | Logitech QuickCam Communicate STX Personal...
Windows won't load says configuring updates
if u leave ur pc running for a few hours and u still see the same screen do a hard power down then reboot ur pc into to safe mode by press F8 as the manufacture logo disappear now after u boot into safe mode windows will finish the update r do a roll back automatically. if u weren't able to boot into to safe mode enter recovery mode and use a system restore to get back into ur system.
Jun 21, 2012 | HP Pavilion dv6000z Notebook
My hp pavilion a820n computer will turn on but won't start up
As the computer is starting up keep hitting F8 until you come to the boot options screen. Once in the boot options select "Last Known Good Configuration" and see if it will start. If it still will not start then try and see if the computer will boot in safe mode (Do the F8 thing again until you reach the boot options screen again and click on "Safe Mode").
If it will not load into safe mode then you may need a Windows O/S Reinstall.
Jul 12, 2011 | HP Computers & Internet
Error: GetFileText. BrowseIt. Permission Denied is popping up constantly
Let's put the computer in clean boot state and check if any third-party program is causing this issue.
Putting your system in clean boot state helps in identifying if any third party applications or startup items are causing the issue. If yes, you may have to contact the program manufacturer for any updates or uninstall and re-install the program.
Here's the article you may refer to for steps with reference to the same.
Use this link if you are using Windows XP:
How to configure Windows XP to start in a "clean boot" state
Note: After troubleshooting, make sure to put the computer to start as usual as mentioned here:
To configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows XP to start normally.
a. Click Start, and then click Run.
b. Type msconfig, and then click OK. The System Configuration Utility dialog box is displayed.
c. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
d. When you are prompted, click Restart to restart the computer.
Apr 15, 2011 | Microsoft Windows XP Home Edition
PoweReadACValue error
Probably it is cause due to power management system corruption
Try following steps
Perform a Clean Boot
If your computer is not starting normally, or if you receive errors when you start your computer that you cannot identify, you could consider performing a "clean boot." This operation starts the computer by using a minimal set of drivers and startup programs. This can help you troubleshoot the problem.
Method :Perform a Clean Boot
Step 1: Start the System Configuration Utility
1. Click Start, click Run, type msconfig, and then click OK.
2. The System Configuration Utility dialog box is displayed.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked. 5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, and then click OK.
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. If you are prompted, log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK.
Note: Start Windows in Normal State
Steps to configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows to start normally.
1. Click Start, and then click Run.
2. Type msconfig, and then click OK.
3. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
4. When you are prompted, click Restart to restart the computer.
Sep 04, 2010 | HP Pavilion dv7-1130us laptop
XP wont load in safe mode
MAY BE DUE TO LOT OF VIRUSES. DISMOUNT YOUR HARDDISK FROM YOUR SYSTEM AND SCAN IT FOR VIRUSES IN ANOTHER SYSTEM WHICH HAS THE LATEST UPDATE OF A POWERFULL ANTIVIRUS SUCH AS KASPERSKY....
Sep 23, 2009 | Microsoft Windows XP Professional With...
P4800pro installer problem
sounds like you need to install chipset / Sata / IDE drivers.
I have found that if your system locks up when tring to configure devices (and it makes it so you cannot use CD drive) booting into safe mode using f8 on boot and deleting the IDE drivers in device manager will force the system load some basic drivers for the next boot, and will allow you to temorarily use the CD drive, however you need to find the correct IDE / SATA drivers for this problem to be completely resolved as this is only a temporary workaround
Apr 24, 2009 | Intel Motherboard
Computer won`t boot
u will have to reformat the hard drive and load win 98 or win xp whichever u want to fix this
you can have more detailed info at
http://www.computerhope.com/issues/ch000474.htm
Jan 31, 2008 | Computers & Internet
Cisco NSS 324 Smart Storage Network Storage Server NSS 324 Logo
119 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
