Question about Cell Phones
Charged earpiece doesn't communicate with cell phone
I am using a Jabra BT200 "jawbone" earpiece with my Samsung cell phone. For the past 2 days it doesn't seem to communicate with the cell. It is fully charged, and the blue light blinks, but when my phone rings, the signal doesn't go to the Jabra. Any ideas? This piece was given to me and I think it's probably several years old. Do they wear out from age?
  • 122 Answers
My advice would be to re-pair the two devices. In the Bluetooth menu on you phone find 'paired devices' and delete the headset from the list. Next you will need to put the Bluetooth headset into pairing mode. Make sure it is switched off and then press and hold the power button on the headset and keep pressing it ( some headsets need to also have the up volume button pressed at the same time). What should happen is either a solid blue light of alternate flashing of two colours. (pairing mode varies on different headsets and you made need instructions or call Jabra) At this point on the phone in the Bluetooth menu search new devices. It should find your headset and request pairing code. Code should be '0000' or some headsets use '1234'. This should now set up a fresh pairing and work again. Hope that helps.
Posted on Apr 23, 2009
How do i allow jabra to voice dial my cellphone
You have to have a phone that allows full voice control. I know that iPhones do via 'Siri', not sure about Samsung.
I use a Motorola Bluetooth earpiece which is paired to my iPhone 6. I just press the main button on the earpiece and after a second, I hear a 'ding ding' sound and give the voice control 'phone home' or whatever. The Contact 'Home' needs to be assigned a number in Contacts.
Jan 03, 2016 | Samsung Cell Phones
My samsung moment phone will not pick up my jawbone earpiece when i search for bluetooth. What im i doing wrong
power off the phone than power back up go to settings select bluetooth go to discover for 3 minutes and wiat about 30 seconds . now on the bluetooth hold down the middle button which is the answering key till it blinks blue and red than go the the phone again select search and that should show jawbone bluetooth press pair and insert 4 zeros for the password and that should solve the problem for you good luck ......rymi1982
Jun 17, 2010 | Cell Phones
Can't hear voice calls on my Samsung Tocco Ultra
The problem with your phone is that the earpiece of your phone is bad, that is why you cannot hear anything while you call or if you are called.
All you need to do is to change the earpiece of your phone and you will see that after changing it, you can hear when people call or when you are called.
Replace the earpiece as said and you will see that your communication with other people on the phone will move smoothly.
Take care.
May 06, 2010 | Samsung Tocco Ultra Cell Phone
Jawbone earpeice broken
I had the same problem. I used a tiny jeweler's screwdriver to push it out from the bottom hole.
Dec 01, 2009 | Jabra Cell Phones
Samsung alias earpiece speaker
Possible the earpiece has gone bad. Can you test with another earpiece?
Remove battery and examine metal contact points for dirt. Can clean with a pencil eraser.
Jul 19, 2009 | Verizon Communications Samsung Alias Cell...
My motorokr will not find my jawbone 2
I reccomend a motorola bluetooth because most jawbone headsets do not work
Jun 18, 2009 | Samsung SPH-m520 Cell Phone
Jabra bt200 passcode
you mean the one you type in to get recognized? i don't know this model precisely, but all the jabras I've seen take 0000, four zeros.
Apr 23, 2009 | British Telecom Jabra BT200/BT250/BT250V...
How do I put a Jabra VBT 2050 into discovery mode?
OK, this is what you do: 1. Make sure your Jabra VBT 2050 is fully charged. 2. Enable bluetooth on your phone. 3. Turn on your VBT 2050 with the little button on the side (the white light between the keys should flash). 4. Initiate a search from your phone while holding down the center button on the VBT 2050 (middle, under the + and -). 5. You might need to do another bluetooth search using your phone (it took me about 4 times befor my Blackberry Storm picked up the signal. 6. When your phone asks for a code, type in 0000 (the default number).
Jan 10, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
Cell Phones Logo
221 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
