Question about Homelite Garden
I would like to know the ohms of resistance in the primary and secondary sides of the coil on my homelite XL2, and the scale you take the readings on, Basically, how to properly bench test this coil with a didgetal multimeter
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
3 Suggested Answers
  • 571 Answers
SOURCE: Homelite XL2 Auto - Proper Oil Line Hookup
Go to m-and-d.com then parts diagram, then illustrated parts online, then parts look up then select oem type select homelite then type in the model no. The parts diagram should show correct hook up.
Posted on Apr 07, 2009
  • 252 Answers
SOURCE: echo cs-3400 wont start .
if you have no spark
check for faulty plug 1st, then pull kill wire off at kill switch, then check for grounding ht lead ,
then pull kill wire off at armature , if still no spark most likley faulty ignition armature
i suspect the part number you need if its type 1 is 15662639130
replace it and set air gap and reassemble and test
here is web site for parts
http://www.ereplacementparts.com/echo-cs3400-type-chainsaw-parts-c-35043_35970_36021.html
or you could try www.partstree.com , go to echo saws , then find your model
cheers hope it helps
pauly 46
Posted on Jan 29, 2011
I have a 2001 roadking it has no spark
Remove the plugs and visually check the condition of the plugs and then reinstall them and leaving both plugs installed remove the spark plug cable from one of the spark plugs and THEN attach the HT cable to a SPARK TESTER and clip the tester to the cylinder head bolt and crank the engine over looking for spark and repeat the procedure on the other cylinder also. Be aware that the Engine will not spark with both spark plugs removed, so when checking for spark, use a SPARK TESTER with both plugs installed.
If you have no spark test the coil first. There should be power to the coil primary all the time the run switch and ignition switches are ON. If not check all switches, relays and fuses.
If the CKP is defective you will also get no spark so check it last.
Test the primary coil resistance on your coil. Disconnect all the wires going to the small terminals (primary) on your coil. Using a good ohmmeter on Rx1 setting, test the resistance between the two small terminals. You should read somewhere between 2 and 3 ohms. If you read more, the coil is bad. Before you do this test short out both leads of the ohmmeter and if the reading is not zero you will need to write down or otherwise remember the number and subtract it from the reading you get from the primary circuit test or you will have an incorrect resistance reading for the primary wires because you will also be reading the ohmmeter internal resistance and/or the wire and lead resistance added to the primary wiring resistance.
You can also test the coil by leaving the "hot" wire on the coil and replacing the other side (ground side) with a short piece of wire. Turn the ignition on and temporarily ground the short piece of wire you put on the "out" (ground) side. When you take the wire away from the ground, (which will collapse the primary current into the secondary) you should see a spark at the plugs if it is a wasted spark system or at one of the plugs if it is not a wasted spark system. If you have current to both sides of the primary of a two part coil both plugs should get a spark whether wasted spark system or not as you are energizing both sides of the primary and collapsing both into both secondaries at the same time when you remove the ground wire from the cylinder head ground.
MORE:
Ignition Coil Primary Circuit Test
Remove the coil. THEN set your ohmmeter scale to RX1 and place ohmmeter leads on the primary coil windings A (front of coil) to B (middle of coil), B to C (front of coil) and check for primary coil winding resistance which normal resistance range is 0.5-0.7 ohms. If primary resistance is not within this range check out test results below.
Ignition Coil Secondary Circuit Test
With the ignition coil removed from the motorcycle and the ohmmeter set to the RX1K scale place the ohmmeter leads on the secondary coil windings B (middle terminal) to
R (rear secondary terminal/socket), B to F (front secondary terminal/socket) and check for secondary coil winding resistance which normal resistance range will be 5.5-7.5K ohms. If secondary resistance is not within this range check out test results below.
Test Results
A low resistance value indicates a short in the coil winding which requires coil replacement.
A high resistance value might indicate that there is some corrosion/oxidation of the coil terminals requiring the coil terminals to be cleaned and the resistance test then repeated and if after the test is repeated the resistance is still high after the terminals were cleaned the coil must be replaced.
If there is an infinite ohms or no continuity) resistance value the coil is open and must be replaced.
Sep 29, 2014 | Harley Davidson Motorcycles
How do I check the ignition coil
Remove the coil. THEN set your ohmmeter scale to RX1 and place ohmmeter leads on the primary coil windings A (front of coil) to B (middle of coil), B to C (front of coil) and check for primary coil winding resistance which normal resistance range is zero point five and zero point seven ohms. If primary resistance is not within this range check out test results below.
Test Results
Jul 30, 2014 | 2003 Harley Davidson FLHTC Electra Glide...
Bike has no spark
Check your pick-up sensor located inside the timing cover, behind the adjustor plate. If the filament is not intact you will have no spark.
A defective coil, cam position sensor, or stator will also cause a no spark condition.
Test Results
May 09, 2014 | 2002 Harley Davidson XL Sportster 883
How to check for spark, harley springer
Test Results
May 03, 2014 | 2003 Harley Davidson FLSTS Heritage...
Throttle cable install
What year????
For some models and years, but do not know if it fits yours as I do not know what year you have:
Test Results
May 03, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
I shut of my 2000 Fat Boy and 20 mins later tried to start it but no fire. Turns over but no spark?
Test Results
If you have spark, it sounds like either the sensor in the timing cavity of the engine is bad or the electronic ignition unit is bad.
Apr 30, 2014 | 2000 Harley Davidson FLSTF Fat boy
I have an 05 softail duece with manual choke, engine will turn over fine but I have no fire at the plugs, installed new plugs, still no fire
Test Results
Apr 28, 2014 | 2005 Harley Davidson FXSTD - FXSTDI...
IGNITION COIL TESTING DODGE 2.7 INTREPID 2004
to check ignition coil, you need a digital volt meter put it on the ohms scale check primary resistance across primary coil positive terminal to secondary high voltage terminal. primary resistance should be 0.6 to 0.9 ohms and secondary resistance should be 6 to 9 kilo ohms. if you see zero ohms more likely ignition coil has open circuit.
Aug 26, 2012 | Dodge Cars & Trucks
I have power to the HEI distributor, but nothing down the plug wires. I would like a test to see if the internal(removable) coil is good, maybe a resistance value
Below is a generic proceedure for checking your ignition coil.
Ignition Coil Resistance
  • With the key off and the battery lead to the ignition coil disconnected, use an ohmmeter to measure the primary and secondary winding resistance of the ignition coil. when checking the resistance across the windings, pay particular attention to the meter reading. if the reading is out of specifications, even if it is only slightly out, the coil or coil assembly should be replaced.
  • To check the primary windings, calibrate an ohmmeter on the X1 scale and connect the meter leads to the primary coil terminals to test the winding.
f22-39.gif Ohmmeter connected to primary coil terminals.
  • An infinite ohmmeter reading indicates an open winding. The winding is shorted if the meter reading is below the specified resistance. Most primary windings have a resistance of 0.5 to 2 ohms, but the exact manufacturer's specifications must be compared to the meter readings.
  • To check the secondary winding, calibrate the meter on the X1,000 scale and connect it from the coil's secondary terminal to one of the primary terminals.
Oct 30, 2009 | Chevrolet Impala Cars & Trucks
P1370 and p1350 trouble codes
P1370 Ignition Control (IC) Module 4x Reference too many pulses
P1350 Ignition Control System
Ok, these codes are signaling a malfunction within the Ignition control module. it is sending way to many signals to the coil. i recommend testing the coil for damage and irregular resistance. i will explain how to do this below. i would replace the module as well. The control moduel is Located Under hood, center, rear engine area, above valve cover, mounted in base of ignition coil pack
Ignition Coil Test Procedures__
* with the key off and the battery lead to the ignition coil disconnected, use an Ohmmeter to measure the primary and secondary winding resistance of the ignition coil. when checking the resistance across the windings, pay particular attention to the meter reading. if the reading is out of specifications, even if it is only slightly out, the coil or coil assembly should be replaced.
* To check the primary windings, calibrate an ohmmeter on the X1 scale and connect the meter leads to the primary coil terminals to test the winding.
* An infinite ohmmeter reading indicates an open winding. The winding is shorted if the meter reading is below the specified resistance. Most primary windings have a resistance of 0.5 to 2 ohms, but the exact manufacturer's specifications must be compared to the meter readings.
* To check the secondary winding, calibrate the meter on the X1,000 scale and connect it from the coil's secondary terminal to one of the primary terminals.
# A meter reading below the specified resistance indicates a shorted secondary winding. An infinite meter reading proves that the winding is open.
# In some coils, the secondary winding is connected from the secondary terminal to the coil frame. When the secondary winding is tested in these coils, the ohmmeter must be connected from the secondary coil terminal to the coil frame or to the ground wire terminal extending from the coil frame. Many secondary windings have 8,000 to 20,000 ohms resistance, but the meter readings must be compared to the manufacturer's specifications. The ohmmeter tests do not indicate such defects as defective insulation around the coil windings, which causes high-voltage leaks.
May 17, 2009 | 1997 Cadillac DeVille
Garden Logo
192 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
