Question about Yaris Relay
My fogs nt wrkin is there a relay for - Yaris Relay
  • 34 Answers
Believe it or not, some Toyota dealer's service depts. will assist you with minor glitches like this, and even print out the page in the service manual to help guide you through the fix. My guess on your inop fog lites would be yes. Check the fuse first. It could be the bulbs too. Do you use them a lot? An ohm meter can tell you if the bulbs are burned out. A cheap VOM from Harbor Freight can check most anything in automotive electricals. $5.00!
Posted on Oct 12, 2013
Fog lights 03 gmc envoy slt not working. How can i located fuse without
There is also a relay ! FOG LP fuse # 11 10 amp location , under hood in the engine bay fuse / relay box . FOG LP relay #39 .
RR FOG LP relay #45 , RR FOG fuse #5 10 amp , location rear fuse box .
The fog lamp relays are computer controlled , by BCM
Mar 27, 2017 | 2003 GMC Envoy
Names & locations of the relays in the auxiliary relay box 1 on a 2003 ford explorer sport trac
There are two relay's for the fog lamps in that relay box . fog lamp isolation an fog lamp relay . You can find a diagram here http://www.bbbind.com/free_tsb.html Enter your vehicle info. year , make , model , engine size . Under system click on electrical distribution , then under sub system click on relay . Hit the search button , then click on the link . Good luck !
Mar 21, 2017 | 2003 Ford Explorer Sport Trac
Clicking sound coming from the relay fuse box
Go back to the changes, eliminate one by one until you find the faulty wire.
Aug 28, 2015 | 2006 Hummer H3
Volume permanently got decreased in dell
Sounds like your driver might be corrupted or has issues. Try downloading and reinstalling the Audio driver.
Get onlineand got to www.google.com In the google search box type: "DellSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Audio drivers.
Jun 05, 2012 | Dell Inspiron 15R Notebook
My fog lights won't turn on Nissan sentra GEX 2002
There are several things that can cause your fog lamps to not work. The fog lamp circuits need to be diagnosed. Your entire fog lamp circuit can be tested at the plug for the fog lamp relay located n the relay box.
PIN 5 on the relay should have battery power at all times. This power comes from Fuse #43 (15 Amp) in the fuse and fusible link box in the engine compartment. If there is power at this pin, the fuse and the circuit between the fuse and the relay is good.
PIN 3 on the relay goes to the fog lamp bulbs. There should be continuity to ground through the bulbs on this pin. If you have continuity to ground, connecting a jumper wire between PIN 5 and PIN 3 should make the fog lamps come on unless there is a short circuit to ground, which will cause Fuse #43 to blow. If there is no continuity to ground on this pin, the problem is either that BOTH fog lamp bulbs are burned out or there is a break in the wire between the relay and the bulbs.
PIN 1 Is the battery power for the primary coil in the relay. This power comes from the headlamp switch and power is only supposed to be present here when the headlamps are on and the dimmer switch is on LOW BEAM. If power is not present at this pin, the problem is a bad headlamp switch or an open circuit between the headlamp switch and the relay.
PIN 2 Is the control circuit for the primary relay coil. The control circuit should have continuity to ground when the fog lamp switch is set to the ON position. If there is no continuity to ground with the fog lamp switch on, the problem is a faulty fog lamp switch, an open between the relay and the fog lamp switch, or an open between the fog lamp switch and ground E37 (right front of engine compartment) and ground F7 (left rear of engine compartment) Please note: This circuit has redundant grounds....if one ground is not making good contact, the other ground can still make the circuit work.
PIN 4 on the relay is not used.
If all of the circuits/pins are working as described above, replace the relay.
That is pretty much it... That is all you really need to know to get your fog lamp circuits diagnosed. Let me know if you need further assistance.
May 13, 2012 | 2002 Nissan Sentra
Fog lamps dont work i check fuses and relay the switch shows the fog lamps are on
If you have not replaced the headlamp with HID, the next thing, are the high beams on ?
If you turn the high beams on, the indicator lamp on the main headlamp switch should go out.
Next thing would be to check the fog lamp relay in the fuse panel ( passenger side kick panel by the fuel inertia switch ).
The fog lamp relay is a half size ISO relay, you should be able to swap with the trailer tow parking lamp relay ( R201 ), to test with.
The fuse you checked is the F17, the fog lamp fuse for Relay R202, correct ?
Nov 26, 2009 | 2006 Ford F-150
Webcam stopped
Have tried updating the webcam driver? Check the manufacturers websites for the latest update for your system. I also notice that your using windows vista, so you may better look for the webcam driver that is vista compatible.
Jun 25, 2009 | Lenovo 3000 Y410 Laptop
Dodge dakota selector switch and relay switch
A selector switch is what you use to turn on or off a circuit such as the lights or wipers. A relay switch is used by a circuit that has a large current draw and a relay uses a small source of current to control a large usage of current. Most fog lights use a relay to control the fog lights. You turn the fog light switch on (that is a selector switch) and the current from that circuit then activates a relay switch to let the larger current draw that the fog lights use go to the fog lights and you have light. A relay also controls if the fog lights are on when the bright lights are on. (on most cars if you turn the bright headlights on the fog lights will go out until you go back to the regular lights)
Hope that helps.
Good Luck
Jan 08, 2009 | 2001 Dodge Dakota
Printer is nt connected to laptop,driver is installed bt nt wrkin
Here is the HP website for your product. Start with the version of windows that you have and download the latest software and drivers based upon that version. I am fairly sure that may be the problem.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441125&lc=en&cc=us&dlc=en&submit.y=1&submit.x=4&cc=us〈=en
Dec 29, 2008 | HP Officejet 5610 All-In-One InkJet...
DV mp4 mp3 player problem(1gb)
hii
i dnt knw y ma DV MP4 MP3 PLAYER nt wrkin!
erm to use this player do i need SD CARD??
cn ani1 helpp me?
nn what elez do i need to fix dis item?
Jul 07, 2008 | Creative Labs Zen Digital Media Player
Yaris Relay Logo
60 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
