Question about Borland Paradox 4.5 Full Version for PC
I am an old man. Couldn't get dos version 4.5 to work so I re installed it.THere is a place in pdox 4.5 where I can name a fixed directory and when it opens it always goes there. Working directory is not permanent I want it to open up in "tables". I think this is a simple thing to do. I just do not know where to enter the information. I will be forever greatful for the answer. Thanks EJ
C;\Documents and Settings\admin\My Documents\downloads\Silverlight.exe is not a valid win32 appplication
HI,
causes for these problems are:
1. File is corrupt, bad, or missing.
2. File is not designed for your version of Windows.
3. File is a virus, worm, or other malware file.
4. Hardware incompatibility.
Step 1: Verify that the program installation CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
Step 2: Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors.
Step 3: If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
· If the program is an older MS-DOS program or early Windows program you may get this error.
· If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Step 4: Run an online scan for any threat and try to fix them
http://onecare.live.com/site/en-Us/center/cleanup.htm
Thanks and regards
Nandy
Oct 26, 2010 | Microsoft Computers & Internet
Error in ms office
Rename and Reinstall the Vbe6.dll File
NOTE: You need your Office CD-ROM to complete this task.
  1. Quit all currently open programs.
  2. Start an MS-DOS prompt in a window by doing one of the following:
    • Microsoft Windows 95 or Windows 98: Click Start, point to Programs, and then click MS-DOS Prompt.
    • Microsoft Windows Millennium Edition (Me): Click Start, point to Programs, point to Accessories, and then click MS-DOS Prompt.
    • Microsoft Windows NT 4.0: Click Start, point to Programs, and then click Command Prompt.
    • Microsoft Windows 2000 or Microsoft Windows XP: Click Start, point to Programs, point to Accessories, and then click Command Prompt.
  3. To change the directory to the location of the Vbe6.dll file, type one of the following (including the quotation marks), and then press ENTER: CD "C:\Program Files\Common Files\Microsoft Shared\Vba\Vba6"-or- CD progra~1\Common~1\Micros~1\Vba\Vba6NOTE: This is the default directory for the Vbe6.dll file. If you installed Microsoft Office into another drive or directory, you must type its path.
  4. To unregister the Vbe6.dll file, type the following.
    In Windows 95, Windows 98, or Windows Me, type: C:\Windows\System\REGSVR32 /U VBE6.DLLIn Windows NT 4.0, Windows 2000, or Windows XP, type: REGSVR32 /U VBE6.DLL-or- C:\Winnt\System32\REGSVR32 /U VBE6.DLLNOTE: This is the default directory for the Windows System directory. If you installed Windows into another directory, you must type its path.
  5. In the MS-DOS prompt window, rename Vbe.dll to Vbe.old by typing the following and then pressing ENTER: rename vbe6.dll vbe6.old
  6. Quit the MS-DOS prompt window. To do this, do one of the following:
    • Type Exit at the command prompt, and then press ENTER. -or-
    • Click Close (the X in the upper-right corner of the window).
  7. Start Microsoft Word.
  8. On the Tools menu, point to Macro, and then click Macros.
    The Windows Installer detects that the Vbe6.dll file is missing on the system, installs the file from the Office CD, and registers it again.
Mar 23, 2010 | Microsoft Office Professional 2007 Full...
Dos commands in linux
go to http://www.pctechguide.com/articles/gettingDedicated12.htm you will find all the commands you need in there.
Jun 01, 2009 | Microsoft Computers & Internet
Bad command or file name
You need to navigate to the directory where the game was installed. When you open your DOS prompt you may be in the WINDOWS directory. You should be able to find the application and open it by double-clicking since you're using Windows 98. The instructions you're reading are for DOS.
Jan 08, 2009 | Blizzard Entertainment WarCraft: Orcs and...
Broaderbund Version 6 Family Tree Maker
Hi madelyn evan,
Version 6 Family Tree Maker is designed to be used with Windows 95 / 98 , therefore in order to use it in Vista you must run your program using Compatinity Mode --> Install your software--> Go to your Desktop --> Right click on the program icon--> properties-->Compatibility--> select one of the versions above
I hope this helps. If so, please take a moment to accept and rate my solution accordingly
Nov 14, 2008 | Broderbund Family Tree Maker 11 (382648)...
Just installed and fails to launch
I could not run this until I downloaded " d3drm dll " and installed it (I put it in the ' 3DHAD3 ' directory, or just put it in Windows directory). I forget where I found it, somewhere from Google.
Jun 04, 2008 | Broderbund 3D Home Architect Deluxe 6...
Save & save as
Save= you save the recent one on the one existing. Means, all you have changed will be applied on to the file you have had.
Save as= you can put a new name (in a new place/ folder/ directory), means you will have a new file while the old one would be still there unchanged. But if you put the same name & directory with the old one, it would be applied to the old/existing one.
May 23, 2008 | Microsoft Office Professional 2007 Full...
Printing from Dos Prompt
1. Save your text file (.txt).
2. On the command prompt navigate to that directory
3.Type "Lpr -S 192.168.1.200 -P lp text.txt"
Substitute 192.168.1.200 for your copier's ip
Substitute text.txt to filename.
Or you can: to print from MS-DOS apps.
1. Share the printer on a networked windows computer. Make sure you make the name MS-DOS compatible.
2. At a DOS prompt, type the following command:
"net use lpt1: \\servername\printer_share/persistent:yes"
NOTE Servername=computer name
printer_share=printers share name
Sep 28, 2007 | Office Equipment & Supplies
XP DOS PROBLEM
a space is given by a value as no value (mass is given by 0) but i will make no sence if i keep this up so here is a really well structured dos page to help you out: http://www.csulb.edu/~murdock/dosindex.html good luck.
Sep 25, 2007 | Microsoft Windows XP Professional With...
Spool locks
I had the same problem - to fix it, I disabled "Enable Bi-Directional Support" under the printer's properties (in windows, right click on the printer in "Printers and Faxes", go down to properties).
Worked like a charm.
Nov 08, 2005 | 3Com OfficeConnect Wireless...
Borland Paradox 4.5 Full Version for PC Logo
Top Borland Computers & Internet Experts
Tony
Yoav Shilon
Yoav Shilon
k24674
Are you a Borland Computer and Internet Expert? Answer questions, earn points and help others
