Question about Liebherr CS-1660 30" Freestanding Cabinet Depth Refrigerator
Ice tray became disconnected. How do you put it back
    Master:
  • 492 Answers
There is a release button on the side usually. You ae to push it in to realign try.
Posted on Oct 18, 2013
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
The ice level arm catches on the ice bucket when trying to pull out the top freezer tray
Hello Danny;
My name is Peter. I am a retired field service refrigeration technician.
This is just a bad design.
The only thing you can do is raise the lever arm to the shut off position.
Or, you can reform the lever arm so it clears the bucket. In this case you have to manually control the ice maker otherwise the ice bucket will over fill.
Your ice maker will harvest ice cubes 8 to 10 times within a 24 hour period.
Nov 30, 2014 | Freezers
I have a Sub-Zero 501 F upright freezer. I have never hooked up the ice-cube maker. There is a problem with ice build up in the drain tray and it overflows into the ice-maker. I had a tech in and he put...
sounds like the mullion heater (drain tube heater is open). take back off (after removing all shelves, including the glass tray (remove 4 screws). Pull back out, careful not to pull wires off T'stat. Run the new wires on heater behind evaperator, placing heater down in drain hole. Good Luck
Joe
Aug 09, 2010 | Sub-Zero Freezers
I have a Jenn-Air Refig with the freezer on the bottom. The ICE maker is not working and I think it might be frozen. How do I disconnect the ice maker so i can thaw it out?
Why not do a quick thaw and move the frozen goods over to the firdge for a few minutes and grab a blow dryer. This should give a temporary fix until you can pin point the problem. Be kind to me please with a Thumbs up. I am a long ways away and can only help a little. Raz
Apr 09, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker is making ice cubes AND pouring water
the apparatus that distributes the water into the tray had been knocked out of balance when taking the tray out. We pulled the ice maker and replaced the apparatus back in it's proper location .
Aug 07, 2009 | Freezers
FRS24ZGE is not making ice had a water leak a while ago so the water was shut off fixed leak and it is not making ice rod for ice tray has been done for a while when the water was shut off door has...
Hi Jeff, Had same problem. Turned out that the fill tube for the ice cube tray had filled with ice. I solved the problem by removing the tube from the back and letting warm water thaw the ice. Reinstalled and it works fine. You may also want to try a blow dryer while still in the freezer, but that may take some time. Good luck, Jim
Jul 28, 2009 | Frigidaire Freezers
Frigidaire side by side: water fills up in bottom of freezer
You have a blockage in your drain tube, at the bottom of the metal tray there is a hole which is connected to a tube which runs down the back of your refridge to a pan next to the compressor. It is an easy fix have done this 1000's times. Remove back panel in freezer, grab a heat gun or hair dryer and melt the ice it the bottom of tray. Clean the water in the tray with some paper towel next get some hot water in a measuring jug and pour into the pan(hot water will help melt ice in tube) repeat this process a couple of times and then get a curtain wire or something flexible to push down the pipe to clean the blockage...you will know when the blockage is clear because the water in the pan will suddenly drain off....put cover back on...make sure to unplug appliance before servicing...hope this helps :)
Jun 22, 2009 | Frigidaire 17.8 cu. ft. / 504 liter...
Ice cube tray will not release ice cubes
Simply buy a replacement tray. The flexability of the old tray is gone and so no flex means cubes stay put. Aggrevating. A new flex tray is around 20 bucks and very easy to replace. 59688-1 is the part number.bca6e53.jpg
May 22, 2009 | Freezers
BEKO AB910 Frost Free Fridge/Freezer Ice build up
I have the same model + problem. You should not need to defrost this model manually if it's working correctly, but the ice build up you describe is probably due to a blocked pipe in the auto-defrost system at the back. You need to defrost properly to prevent recurrence.
Behind the upper freezer drawer there's an aluminium tray behind a plastic grille. Every few days this tray warms up to melt any accumulated ice behind this plastic grille (full height of the freezer). A pipe should take the meltwater down to a plastic tray below (pipe + plastic tray are visible if you take the lower panel off the back). Your problem is too much ice blocking that pipe: the heater can't cope and it doesn't melt, so the ice 'cascades' down the back behind the bottom drawer.
When you manually defrost, you must ensure that this pipe is clear, otherwise the auto-defrost won't work, and you may have to defrost manually again within days.
I have found that the best way to defrost the pipe is to remove the lower back panel, disconnect the corrugated flexible plastic pipe from the stub that comes from the bottom of the freezer, + pump steam into the stub (gently) using a hand-held steamer (with tube + nozzle). You don't have to empty the freezer or move your food as the door stays closed, and no steam gets into the freezer until the pipe is unblocked. Be sure to unplug the freezer before taking the back off! [There is a fan in this area that could start up without warning]
Check how much of the pipe is blocked by gentle probing with a pencil: the aluminium tray is about 105mm above the bottom of the stub. This measurement is important…
When the pipe is clear, there may still be too much ice in the aluminium tray above (not sure how much is 'too much') if you only created a narrow 'chimney' though the block of ice (likely to get blocked again). You need to widen that chimney by melting more of the ice in the aluminium tray. I use a simple steam nozzle made from an old-fashioned Bic pen with a couple of 1mm holes drilled just below the coloured bung at the end. This directs steam onto the walls of the 'chimney' rather than upwards.
There's no point steaming the walls of the plastic 'stub' pipe, so only use the home-made nozzle when your probe reaches 105mm (i.e. when you have melted all the ice in the plastic stub tube but before your 'chimney' has broken through the block of ice in the aluminium tray). If you judge this right, you'll melt almost all of the ice under a still-frozen top surface: no steam will get into the freezer and your food will stay frozen. With a probe it will be clear when you've broken through the top surface of the ice. When you have done so, it's time to look inside the freezer to see how well you have cleared the aluminium tray.
It's perfectly feasible to get all this done in 30 minutes.
Don't forget to replace the corrugated plastic pipe + valve at the bottom. It stops humid air from going into the freezer and icing up in exactly the area we've just been defrosting.
Take a lot of care with steam jets as they can burn you badly. You should check a first aid website so you know what to do BEFORE it happens.
Some of these tips may be helpful: (1) run the freezer at -18 degrees (the 'warmest' setting) so it's not working so hard. (2) Leave a big gap (>100mm) between the back of the freezer and the wall. (3) Clean the matrix of delicate tubes to the left of the fan whilst you have the back off [a small bottle brush is ideal; remove the fan for better access]. (4) Put something between the middle of the freezer and the wall to prevent the warm air that's being blown out behind the fridge from being sucked into the air intake behind the freezer (there is a baffle built in underneath, but nothing behind. (5) Mount the fan on spacers (with longer screws) so that it's closer to the heat exchanger… this means that a larger area of grille can act as an air intake. (6) Raise the unit off the floor a little to free up the air intake path beneath the freezer.
Apr 23, 2009 | Freezers
Liebherr CS-1660 30" Freestanding Cabinet Depth Refrigerator Logo
118 people viewed this question
Top Liebherr Freezers Experts
richie46
ray gallant
Tom Chichester
Are you a Liebherr Freezer Expert? Answer questions, earn points and help others
