Question about Karcher K2.26 Electric Power Washer
Karcher k5.700 cuts on and off when using - Karcher K2.26 Electric Power Washer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
I fixed mine works good easy too watch my video step by step i put it on youtube
http://www.youtube.com/watch?v=UFXSLOBL0Mg
Posted on Oct 17, 2013
Why does my karcher powerwasher starts and dies after 2 minutes
dirty carb , clean carb, install a fuel cut off valve ( or start using it if you already have one) when you are done washing, turn off the fuel valve and continue spraying water until the engine stops. That will empty the carburetor bowl and the carb will stay clean until you want to use it again.
Sep 07, 2014 | Karcher 2500 PSI Pressure Washer
KARCHERS HDS750 PUMP CUTS IN AND OUT
I fixed mine works good too, watch my video step by step i put it on youtube
Jan 19, 2013 | Karcher Pump Kaercher KH 5050/L
Ihave a karcher 630m which keeps cutting out please can you help
OIL LEVEL LOW?, CARB NEEDS CLEANED, DRAIN CARB FUEL BOWL CHECK COLOR OF GAS , MAY HAVE WATER OR OLD GAS IN BOWL AS WELL,
Mar 25, 2011 | Karcher Garden
Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Apr 16, 2010 | Karcher Garden
Karcher k1 leaking from inside casing.
The most likely issue, which seems to occur alot with karcher, is a cracked water pump. What happens is that as you release the trigger on the handle, the rise in pressure should cut off the motor, but as it also cuts off the water flow at the wand end and the motor spins a few more revs until it stops, then there is a huge pressure glitch which blows apart the weak plastic pumps that they use. Since the plastic cracks it is very difficult to repair and the only option is to go and buy another. BUT...this time tape up the trigger on the handle so it is always on and then it won't blow itself up. Just use the unit on/off switch to turn the motor on and off.
Apr 11, 2010 | Karcher Garden
I have a karcher 495, it is puslating when it is
It sounds like there may be a pressure leak somewhere in the system. The machine cuts off when there is no flow of water past it. If it is leaking then there is intermittent flow. Which would make the machine run then stop continuously.
Nov 15, 2009 | Karcher K 5.85 M Electric Pressure Washer
Where is fuel filTER
Hi:
There is only one line (tube) that goes from the gas tank to the carb. If there is a fuel filter it will be on that line. To check if it is plugged just pull the line off where it attaches to the carb. If you spill gas, that is not the problem. Replace the line and be sure to clean up the gas. Sounds to me like a carburetor problem, though.
Jun 30, 2009 | Karcher Quick Connect Nozzle Set
Karcher K2.26 Electric Power Washer Logo
89 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
