Question about Microsoft Office Excel 2007
Spreadsheet highlights When I try to highlight data on spreadsheets, it does not show on the screen. When I print the document, it just shows a grey color where it was highlighted, but not the color.
  • sfillat Apr 23, 2009
    I've tried resetting the palet, but that does not work. Since I did not see any option for "default" settings, I may not have reset it correctly.
    How exactly should I reset it?
  • sfillat Apr 24, 2009
    The latest suggestion did not work either. Do you have any other suggestions? Is there an online manual that I can look at?
  • 122 Answers
You may have to reset your color palet, some program have black/white set as the default
Posted on Apr 23, 2009
  • Linda Goldsmith
    Linda Goldsmith Apr 23, 2009
    try tools/options and then pick colors try to edit and apply
How to add comma in spreadsheet? thanks
To add commas to your spreadsheet you need the format the numbers. If you want your whole spreadsheet to use commas, click on the area to the left of column A and above number 1. This should highlight the whole spreadsheet. Click on the "," icon in the "number" area, and your spreadsheet will be formatted to put commas in.
Good luck,
Paul
May 06, 2016 | Casio Office Equipment & Supplies
How do I fix how my percentage shows on the excel spreadsheet?
On the home toolbar, there is a section titled "Number". That would be where you would change the format to whatever you want it to. Even Red..
So, all you have to do is enter in the number you want and Excel puts in the decimal point, or the dollar sign, or the percent sign for you. And you can even change the amount of decimal places you want it to go as well..
Highlight the cells/numbers you want to format, then go to the number section on the toolbar (edit), and select the format that you want.
May 15, 2014 | Microsoft Corporation Microsoft EXCEL 97...
Error code 20
The issue is typically caused if the printer is either not configured correctly, or your system tries to send an erroneous command to it. This error will typically show when you try and print a document / spreadsheet or another piece of data from your system, and will stop the print-out from proceeding. In order to fix this, it's advisable that you follow the steps outlined in this tutorial.
Aug 11, 2010 | HP Photosmart 2575 All-In-One InkJet...
Arrow keys moving whole page instead of cells
highlight a cell then try using the arrows
Dec 30, 2009 | Logitech 967437-0403 Keyboard
Change Font color in an excel spreadsheet and it prints correct color but will only show as black on screen.
Make sure you have highlighted yhe area you want to change the color on then click on the color you want and it should change for the screen as well as the printing phase of the program.
Dec 14, 2009 | Microsoft Office Excel 2003 for PC
Transforming birthdates into year codes
Here is a solution that might work for you. Please be mindful that there are several different solutions that will achieve the same thing in Excel (I am assuming Excel is your software).
1) Make sure each column in your spreadsheet has a heading.
2) Highlight (select) the column of birthdays.
3) Choose Format from the menu bar.
4) Choose Cells... from the drop-down menu.
5) For the "category", choose Custom.
6) In the "type" box, type yyyy
7) Click OK and when you return to your spreadsheet, you will see only the years displayed. However, when you try to edit a cell, you will see that the entire birth date is stored and preserved.
8) Now, highlight the entire table
9) Then, choose Data from the menu bar
10) Choose Subtotals... from the drop-down menu
11) In the "At each change in" box, choose the name of the column with the birth dates
12) In the "Use function" box, choose Count
13) Leave all other choices at their defaults
14) Click OK, and you are done.
Using this method, you can continue to enter the data as you always have. In that way, the birth date info is never actually destroyed or converted. What you are doing is simply deciding what is displayed.
I hope this helps.
Aug 02, 2009 | Microsoft Office Excel 2007
I'm trying to print compact size directly from excel/word. What are the margins?
Step 1 Start Microsoft Excel and open an existing spreadsheet on which you would like to set the margins.
  • Step 2 Choose the "File" menu and click "Page Setup" to open the "Page Setup" dialog box. The "Page Setup" dialog box can be used to set up your page just how you would like it to appear.
  • Step 3 Click on the "Margins" tab at the top of the "Page Setup" dialog box to show the margins for the spreadsheet that you currently have option.
  • Step 4 Set the "Left," "Top," "Right," "Bottom," "Header" and "Footer" margins by clicking within the text box underneath each option to highlight the current margin setting.
  • Step 5 Type a new measurement for whichever margins you would like to change or use the arrows to move up and down throughout the measurements you can select for each option.
  • Step 6 Notice as you update each margin the preview in the center of the screen will change to reflect your new margin settings.
  • Step 7 Use your mouse to click the "OK" button to close the "Page Setup" dialog box and set the margins you have chosen for your current
  • Jul 07, 2009 | Computers & Internet
    Printing a spreadsheet
    You should tell us your "Operating System, Spreadsheet Program and Printer" for us to give you a difinitive answer. Whithout this info I will attempt to give you a general answer.
    In your spreadsheet program, go to "File" and select "Page Setup" and set your paper size and set your margines and Portrait/landscape option. Your spreadsheet display should show you the paper limits for printing each page. Adjust the columns to the paper size. Highlight all the columns and rows you want to print. Find the menu option to set print area and click it. Now the computer will send the paged information to the printer and print as many pages as needed to cover the print area.
    May 31, 2009 | Apple Office Equipment & Supplies
    Printer "out of memory"
    So which printer are you wanting help with?
    Nov 23, 2008 | Office Equipment & Supplies
    Mail Merge Print Problem
    Was a recipient address created in an Excel spreadsheet or a database? Data needs to be pulled from somehwere to be added to the envelope.
    Dec 05, 2007 | Dell Latitude D800 Notebook
    Microsoft Office Excel 2007 Logo
    81 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
