Question about Husqvarna Garden
Model 2554 runs fine until blades are engaged then it cuts out.
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 80 Answers
Sounds like your seat/safety switch is malfunctioning. Try running a loop wire by unplugging it from the seat and connecting a wire from one terminal to the other to complete the circuit
Posted on Oct 12, 2013
SOURCE: Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Posted on Mar 24, 2009
  • 79 Answers
SOURCE: 18 hp craftsman 2 44 inch cut engine dies when blades engage.
HI
Check wires going to safety switch under seat.
Posted on Apr 07, 2009
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
SeaDaddy46
SOURCE: Craftsman GT5000: Dies when switch is pulled to engage blades
I have the same tractor. If you have the transmission in <reverse> this will happen every time. It's a safety feature. Be sure the tractor is in <neutral> or one of the 6 forward gears.
Jim Romines
Posted on Jul 31, 2009
SOURCE: Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Posted on Nov 24, 2010
My Husqvarna LGT 2554 deck hung up on high spot mowing. Turned off deck & mower pushed by hand. Engaged deck,started to mow, wound to stop. Belts fine. Pull up on knob to engage, you get nothing.
The engine runs but the blades do not engage? Make sure the wire connecting the electric clutch is still plugged in. If all is connected and the belt is really fine, there is a problem with either the electric clutch or PTO switch.
May 21, 2015 | Husqvarna Garden
Husqvarna LGT 2554, run out of gas, blades were engaged. Put gas in it and now it will not turn over. Jumped battery, would not turn over / click. New battery.
Sounds like you still have PTO switch in the on position which would prevent the starter circuit from working.
Oct 19, 2014 | Garden
Loss of power when blades engaded.
Remove deck belt from blade pulleys and Tri to spin blades by hand. If they don't spin freely, you probably need new spindle bearings but if you do need a new spindle I would replace the whole spindle housing... Just make sure the one (s) you buy has housing, spindle, bearings, nut and washer.
Jul 04, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When everi i engage the blades, the mover cuts off on 40
I still think its a seat switch issue, many seat switch block connecters have fail safes in them should they come away from the switch, it is difficult to by pass these as they will earth out as soon as you pull it away from the switch
Jun 03, 2012 | Murray Garden
My LGT 2554 Husgvarna mower engine tends to die when the mower blades are engaged. When the engine runs with the blades off at low idle it is ok. When you advance the throttle fast to full it loses power...
A common problem on the 21 & 23HP models is bent valve push rods on one cylinder. With this the engine runs and seems fine, albeit a bit quieter, until you put a load on it like engaging the blades which causes it to nearly die. So you may want to eliminate this as a possibility by running the engine with one plug wire removed and then the other. If it runs with one wire on alone, but not with the other wire on alone, then you have a nonworking cylinder even though it is receiving spark. Just a thought.
Jul 30, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I have a Kraftsman 91.5 42 inch cut model #
Safety switch at seat or reverse. Mower will cut of when blades are engaged if you get off the seat or put into reverse. Check these switches for stuck on, damaged, disconnected, or just plain broke. Good luck.
Mar 19, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
May 14, 2009 | Mtd Garden
Garden Logo
41 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
