Question about Onkyo TX-SR500 Receiver
Onkyo mute channels. When turned on, one or more channels remain mute. Acts like a contact problem; when switched on-off-on multiple times, mute channels may vary
    Top Expert:
  • Onkyo Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
The speakers are not connected properly. Check the speaker connections. The Mute function is activated. Turn off the Mute function. The volume is turned all the way down. Turn up the volume. Neither set of speakers is selected (if unit has A/B buttons to select sets of speakers). Press either A or B to select a set of speakers. Both sets of speakers are selected, but only one set is connected (if unit has A/B buttons to select sets of speakers). Press the appropriate button to deselect the speaker outputs which are not connected. The receiver is set to TAPE MONITOR (if applicable). Turn off TAPE MONITOR mode. Headphones are plugged into the main unit. Unplug the headphones. The source selector is set to the wrong source. Select the proper source. The impedance of the speakers is less than the rating for the system. Use speakers with the correct impedance rating.
Posted on Oct 12, 2013
NR626 - no sound
If none of your speakers gives any sound, perhaps you pressed the mute button on the remote control?
Make sure you have a source selected, that will give sound. Choose a low volume, before switching anything. You can destroy your speakers, when switching on with full volume.
If some speakers work, and only the surround does not work. check if you have surround sound as input. If you only feed 2 channels you can't expect to hear more than 2 channels.
Jul 01, 2014 | Onkyo TX-NR626
Unresponsive Acoustic channel 2 Marshall as100d ....
I have same problem. i have this map. please help me to find the problem. if you can point the area in this map that problem is from that.
Mar 04, 2013 | Marshall Amplification Marshall AS100D 2x8...
Cant get channel a & b to stay on together
You need to connect all the remote cables together then turn on the multiple room button on the onkyo p-301 preamp if u have it the it should turn on.
Dec 17, 2012 | Onkyo M-501 Amplifier
Onkyo sv545 one channel preout don't work
If you feel it is , here's the components to check:
Check Q444 (muting transistor)
Q407
Q403 ( TC9213P), Q371
Q402
Oct 09, 2012 | Onkyo TX-SV545 Receiver
Just got a vintage Onkyo receiver mod # TX-840. I have a very scratchy sound in both A and B right channels on all sources. Figured it was a blob channel HOWEVER this unit has a
Vintage hardware means vintage contacts on all the controls which means oxidation which would cause crackly sound or total silence. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts. Beyond that a trip to the hifi doctor would be advised.
Jun 21, 2011 | Onkyo Audio Players & Recorders
I have an older onkyo integra (TX-870) which pop when I change stations, then no sound. Need to turn off and begin again. Can this be fixed or should I purchase a new 2 channel sys?
Hi, It sounds like you are listening F.M. radio and the F.M. muting button is engaged ( as well it should be-otherwise you will have static between the stations ) sometimes there is almost a "THUMP" sound when you switch stations-this is caused by the receivers P.L.L. circuitry losing then locking in on stations, if you do not lower the system volume you will amost assuredly cause an overload of your final drivers, that's why it will come back on when turned off-it has reset. Turning off fm muting will get rid of the "POPPING" noise-it will however leave you with unbearable static which in turn should cause you to lower volume momentarily eliminating the need to constantly turn off the receiver. Thank for asking FixYa, I hope this helps, let me know how I did or if I can be of more assistance, good luck Prodzilla
Apr 13, 2011 | Onkyo Audio Players & Recorders
My onkyo tx-8222 suddenly stopped amplifying on both speakers and headphones. I can hear music faintly with the volume at max (just the pre-amp?). Time for a new amp?
Never use maximum volume for troubleshooting. The errant switch or control that you eventually find and flip will suddenly release the amp's full power and you'll destroy your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Look for a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Feb 21, 2011 | Onkyo TX-8222 Receiver
One channel muted until the volume is turned up
This problem is usually dur to some corrosion in the speaker relay. If the relay can be opened, burnish the contacts and you should be OK. The higher volume creates a higher voltage that can "jump the gap" so to speak. Once the connection is made it will remain. That is why lowering the volume will work.
Dan
Apr 14, 2010 | Yamaha AX-396 Amplifier
HDMI switching problems, ongoing, HDMI board has been replaced
Congrats? There's barely any information to go off of here, but assuming the receiver has broke multiple times, you need to contact Onkyo tech support and/or a better repair center to see if there is a different problem in the system. HDMI is a very complicated and annoying connection system. You should post your actual symptoms and components in your system along with how everything is connected and we'll have a better chance or narrowing down the problem, along with solving it.
Mar 11, 2010 | Onkyo TX-SR606 Receiver
Onkyo TX-SR605 7.1 Channels... Problem
firmware up date go to onkyo homepage
Apr 01, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR500 Receiver Logo
127 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
