Question about John Deere 310sj Backhoe
Install upper rear window - John Deere 310sj Backhoe
Window regulator replacement in 1988 olds cutlass calais (non-motor). How do I replace the window regualtor?
1985-1998 Oldsmobile Grand Am/Achieva/Calais/Skylark/Somerset
REMOVAL & INSTALLATION
Door Glass and (manual) Regulator
See Figure 1
Fig. 1: Common window attachment
SEE ILLUSTRATION #1 BELOW
1. Remove the door panel.
2. Remove the water deflector from the door.
Be careful not to tear the water deflector when removing it from the door.
The "water deflector" is also known as the "dew wiper"
3. Connect the power window switch/window regulator handle.
4. Lower window to full down position.
CAUTION
Use extreme caution when operating the window with the door panel removed. The window regulator can cause severe personal injury if body parts become entangled in the mechanism.
5. Remove the window run channel.
6. Move window to the half down position.
7. Remove the window retaining nuts.
8. While holding onto the window, lower the regulator to the full down position.
9. Remove the window by sliding it towards the rear and rotating the front of the window upward.
To install:
10. Position the new window in the door.
11. While holding onto window move regulator to half up position.
12. Install the nuts. Roll the window to the full up position.
13. Install the rear run channel.
14. Install the plastic water deflector. If necessary, secure with waterproof adhesive
15. Install the door trim panel.
Window Regulator
See Figures 2 and 3
Fig. 2: Location of the front door window regulator-1995 vehicle shown
SEE ILLUSTRATION #2 BELOW
Fig. 3: Exploded view of the rear door window regulator-1995 vehicle shown.
SEE ILLUSTRATION #3 BELOW
2. Remove the plastic window deflector. Be careful not to tear the deflector when removing it from the door.
3. Remove the door window assembly.
4. Remove the bolts securing the regulator to the door.
5. Remove the nuts securing the upper regulator guide.
6. Using a 1/4 in. drill, drill out the regulator rivets.
7. If equipped with power windows, detach the electrical connector.
8. Remove the regulator through the large access hole in door.
To install.
9. Install the regulator to the door, and attach the electrical connector if equipped with power windows.
10. While holding the regulator to the inner door panel, insert the rivets, and secure them with a rivet tool.
11. Fasten the regulator bolts and upper guide nuts.
12. Install the door glass, and inside door plastic panel.
13. Install the inside door trim panel.
14. Install the plastic water deflector. If necessary, secure with waterproof adhesive.
Fig.1---------------------------------------------------------------------- Fig. 2
Fig. 3
Oct 03, 2011 | 1988 Oldsmobile Calais
My back automatic window went down and now won't come back up. No sound from motor. Checked fuses. Even took back seat apart but don't know what to do or what caused it. How can I get window to go...
it may need to be reset.
SECTION 501-11: Glass, Frames and Mechanisms 2001 Explorer Sport/Sport-Trac Workshop Manual
GENERAL PROCEDURES Rear Window Motor Initialization s1r~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure that no obstructions are present in the power rear window system when carrying out this procedure.
NOTE: This procedure must be carried out when repairs are performed on any part of the power rear window system including when: the power rear window motor is removed from the window regulator drum housing, a new power rear motor is installed, a new power rear window regulator is installed, a new power rear window module is installed, and any operation in which grease or lubricants are applied to the power rear window system.
NOTE: All power rear window components (window glass module, window regulator, window motor, and glass runs) must be installed and torqued to specification before carrying out this procedure.
NOTE: Steps 1-6 must be completed within 30 seconds. The entire procedure must be completed within five minutes.
NOTE: Once the ignition key is turned to the ON position in Step 6, it must remain on until the entire procedure is completed.
NOTE: Steps 7 and 9 require that the power rear window control switch be held in the closed position until the power rear window motor stalls the window in the upper header seal. Step 8 requires that the window control switch be momentarily turned to the open position.
  1. Start with the ignition in the OFF position.
  1. Turn the ignition to the ON position.
  1. Press the power rear window control switch vent button six times.
  1. Turn the ignition to the OFF position.
  1. Turn the ignition to the ON position. The power rear window will move up-down-up-down approximately 20 mm (0.8 in). This movement indicates that the power rear window motor has entered initialized mode.
  1. Rotate and hold the power rear window control switch to the closed position until the window stalls in the upper header seal.
  1. Momentarily rotate the power rear window control switch to the open position and release. The power rear window will carry out a one-touch down operation until the window stalls at the bottom of the travel stop designed into the window regulator.
  1. Rotate and hold the power rear window control switch to the closed position until the window stalls into the upper header seal. Once this operation is complete, the window will move up-down-up-down approximately 20 mm (0.8 in). This movement indicates that the power rear window motor has been successfully initialized.
  1. Verify correct operation of the power rear window by moving the window to the fully open, vent, then fully closed positions.
  • The power rear window is inoperative (Explorer Sport Trac only)
  • Circuitry.
  • Battery Junction Box (BJB) fuse 3 (30A).
  • Central Junction Box (CJB) fuse 20 (7.5A).
  • Power rear window control switch.
  • Rear window glass motor.
  • Go To Pinpoint Test K .
Sep 15, 2011 | 2001 Ford Explorer Sport Trac
Replacing the upper brake light in rear window , I bought the car used and don't hae an owners manual
In 1994 Toyota Camry, the third stop light was located at lower center part of the rear window, not in the upper part.
Nov 27, 2010 | 1994 Toyota Camry
Where is the rear window relay located on the 2002 Ford Explorer sport trac. Not the rear door windows but the very back window.
  • Circuitry.
NOTE: The power rear window motor is not on the multiplex link. Any diagnosis and testing carried out on the power rear window will not involve the GEM module. NOTE: The reinitialization procedure must be carried out when repairs are performed on any part of the power rear window system including when the power rear window motor is removed from the window regulator drum housing, a new power rear motor is installed, a new power rear window regulator is installed, a new power rear window module is installed, and any operation in which grease or lubricants are applied to the power rear window system.
Nov 16, 2010 | 2001 Ford Explorer Sport Trac
How to replace a heater core
Heater Core Removal & Installation Front To Remove:
  1. Make sure you have the anti-theft codes for the audio and the navigation system, and then write down the audio presets.
  2. Disconnect the negative cable from the battery.
  3. From under the hood, disconnect the heater valve cable from the heater valve. Turn the heater valve arm to the fully opened position.
  4. When the engine is cool, drain the engine coolant from the radiator.
  5. Disconnect the inlet heater hose and the outlet heater hose from the heater core.
  6. Remove the mounting nut from the heater unit. Take care not to damage or bend the fuel lines, the brake lines, and related parts.
  7. Remove the dashboard.
  8. Remove the evaporator.
  9. Remove the mounting bolts and remove the heater unit. Front heater unit honda-10-00-4128.gif
  10. Remove the self-tapping screws and the clamp.
  11. Carefully pull out the heater core so you don't bend the inlet and outlet pipes.
To Install:
  1. Using care, install the heater core to the heater unit and secure.
  2. Using care, install the heater unit and tighten mounting nuts and bolts to 7 ft-lb (10 Nm).
  3. Install the evaporator.
  4. Install the dashboard.
  5. Connect the inlet heater hose and the outlet heater hose to the heater core.
  6. Connect the heater valve cable to the heater valve.
  7. Refill the cooling system with engine coolant.
  8. Adjust the heater valve cable.
  9. Make sure that there is no coolant leakage.
  10. Make sure that there is no air leakage.
  11. Connect the negative battery cable.
  12. Perform the power window control unit resetting procedure.
  13. Enter the anti-theft codes for the audio and the navigation system, and then enter the audio presets.
Rear To Remove:
NOTE: The rear blower motor, the rear heater core, the blower screen, the rear blower resistor (heating/air conditioning system) and the rear power transistor (climate control system), the rear air mix control motor (climate control system) , the rear mode control motor and the rear expansion valve can be replaced without removing the rear heater-A/C unit.
  1. Remove the self-tapping screws and the clamp, and then remove the bolts and the rear evaporator lines with the rear expansion valve. If necessary, remove the rear expansion valve. Use a second wrench to hold the other fitting on the valve so the rear evaporator lines won't twist. Leave the first fitting loosely connected so you can use it to hold the valve while you loosen the second fitting.
  2. Remove the rear heater hoses.
  3. If necessary, remove the rear blower motor, the rear heater core, the blower screen, the rear blower resistor (heating/air conditioning system), the rear power transistor (climate control system), the rear air mix control motor and the rear mode control motor.
  4. Remove the self-tapping screws and the lower housing.
  5. Remove the self-tapping screws, and carefully separate the left upper housing from the right upper housing. Remove the rear heater core.
To Install:
  1. Replace the rear heater core.
  2. Attach the heater hoses.
  3. Make sure no air is leaking from the left upper housing and the right upper housing fitting and from the upper housings and the lower housing fitting.
  4. Before reassembly, make sure that the rear air mix control linkage and door move smoothly without binding.
  5. Before reassembly, make sure that the rear mode control linkage and door move smoothly without binding.
  6. Reassemble the housing.
  7. After reassembly, make sure the rear air mix control motor runs smoothly.
  8. After reassembly, make sure the rear mode control motor runs smoothly.
  9. Refill the cooling system and make sure that there is no coolant leakage.
Oct 16, 2010 | 2005 Honda Pilot
How to replace the shocks on my 2000 Mazda 626
REMOVE**** FRONT SHOCKS, FIRST OF ALL.SUPPORT THE LOWER CONTROL ARM WITH A JACK,REMOVE FRONT WHEEL, REMOVE BRAKE HOSE AND ABS SENSOR HARNESS TO THE STRUT BOLTS OR CLIPS,REMOVE ACTUATOR FROM TOP OF THE STRUT,IF EQUIPPED WITH AUTOMATIC ADJUSTING SUSPENSION. PAINT ALIGNMENT MARKS ON THE UPPER STRUT MOUNTING BLOCK AND STRUT TOWER AND ON THE LOWER STRUT MOUNT TO STEERING KNUCKLE SO THAT CAN BE REINSTALLED IN THE SAME POSITION. REMOVE UPPER STRUT MOUNTING NUTS, REMOVE THE STRUT TO KNUCKLE BOLTS,REMOVE STRUT ASSEMBLY.TO INSTALL ***** INSTALL STRUT INTO THE STRUT TOWER ALIGNING THE PAINT MARKS MADE DURING REMOVAL.INSTALL UPPER MOUNTING NUTS AND TIGHTEN TO 34 - 46 FT LBS. INSTALL STRUT TO KNUCKLE BOLTS TIGHTEN TO 55 - 61 FT LBS. INSTALL ACTUATOR AND ENGAGE THE ELECTRICAL CONNECTOR IF EQUIPPED WITH AAS. INSTALL BRAKE HOSE AND ABS SENSOR HARNESS CLIPS OR BOLTS.INSTALL WHEEL AND CHECK ADJUST THE FRONT END ALIGNMENT. TO ( REPLACE REAR SHOCKS ) REMOVE REAR WHEELS, REMOVE REAR PACKAGE TRIM. REMOVE SPEED SENSOR HARNESS, REMOVE TOP STRUT NUTS,THE SUSPENSION WILL DROP WHEN THE WEIGHT LIFTS OFF THE WHEELS. REMOVE BOTTOM STRUT BOLTS.REMOVE STRUT ASSEMBLY.TO INSTALL ***** INSTALL STRUT ASSEMBLY, INSTALL BOTTOM STRUT MOUNT BOLTS AND TIGHTEN TO 55 - 61 FT LBS.INSTALL UPPER MOUNTING NUTS AND TIGHTEN TO 33 - 46 FT LBS. INSTALL SPEED SENSOR HARNESS.INSTALL REAR PACKAGE TRIM. INSTALL REAR WHEELS.
Sep 22, 2010 | Mazda 626 Cars & Trucks
How too remove back seat in a 1995 Nissan Maxima
Rear
See Figures 3, 4, 5 and 6
  1. Remove the lower seat cushion by pulling straight up on the front portion and disengaging the clips. Then hinge the seat upward to release the rear clips.
Fig. 3: Pull up on the front of the lower seat cushion and disengage the clips
  1. Remove upper rear seat back-to-chassis bolts.
Fig. 4: Remove the bolts behind the center armrest ...
Fig. 5: ... and the bolts on the lower corners ...
Fig. 6: ... Then pull up on the seat to disengage the three clips on the top of the seat
  1. Remove rear seat back by tilting forward and pulling straight up.
To install:
  1. Install the lower seat cushion and torque the lower rear seat-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm).
  2. Install the upper rear seat back cushion and torque the upper rear seat back-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm)
Hope help with this (remember rated this).
Jul 19, 2010 | 1995 Nissan Maxima
My 2001 Town and Country's rear windshield wiper motor is kaput. How do I change it without destroying the rear tailgate paneling
Pretty straight forward.....here are the steps:
Please don't forget to rate--
Rear Window Wiper Motor Removal & Installation To Remove:
  1. Disconnect and isolate the negative battery cable.
  2. Remove the rear wiper arm.
  3. Open the liftgate.
  4. Perform the following to remove the liftgate trim panel.
    • If equipped, remove the lift motor link
    • Remove the upper frame molding
    • Remove assist handle screws
    • Disengage the hidden clips around perimeter of liftgate trim
    • Disconnect the electrical connectors.
  5. Disconnect the wire connector from the wiper motor.
  6. Remove the wiper motor mounting screws.
  7. Remove the wiper motor.
To Install:
  1. Position the wiper motor in the liftgate.
  2. Install the wiper motor mounting screws.
  3. Connect the wiring connector.
  4. Install the liftgate trim panel.
  5. Close the liftgate.
Jul 24, 2009 | 2001 Chrysler Town & Country
When i try to open the door it wont move the bottom latch releases but the top wont and i cna get to it to try to remove it
Section 501-14A: Handles, Locks, Latches and Mechanisms 1997 F-150, F-250 Workshop Manual REMOVAL AND INSTALLATION Latch, Rear Door — Upper Removal
  1. Remove the rear door trim panel; refer to Section 501-05 .
  1. Remove the rear door radio speaker.
    1. Remove the four radio speaker screws.
    1. Disconnect the electrical connector.
  1. Carefully peel off the rear door watershield.
  1. Disconnect the upper rear door latch cable.
    1. Lift the clip.
    1. Pull to release the cable from its seated position.
  1. Remove the upper rear door latch.
    1. Remove the three screws.
    1. Pull the upper rear door latch and the cable up through the door latch opening.
Apr 14, 2009 | 1997 Ford F150 Regular Cab
Window Regulator, Rear Door, Explorer Removal
  1. Remove the rear door trim panel and watershield. Refer to Section 01-05B .
Trim Panel, Rear Door, Explorer, Hi-Series Four-Door Removal and Installation
  1. Remove the two screws retaining the rear door trim panel (27406) located above the door handle.
  1. Remove trim cup at the door handle using a screwdriver or sharp object. Retention nibs will flex for easy removal.
  1. To remove window regulator switch plate (14524) , use notch located at lower end of plate using a screwdriver to lift and remove.
  1. Remove window regulator switch plate from rear door trim panel pulling wire harness from rear door trim panel .
  1. From bottom of window regulator switch plate , remove two screws and disconnect connector from window regulator control switch (14529) .
  1. At each plastic clip location, pry the rear door trim panel away from the door inner panel using the door trim panel removing tool from Rotunda Moulding/Trim Kit 107-00401 or equivalent.
  1. Remove panel, lift slightly to remove flange at the top of rear door trim panel from trough in the glass weatherstrip. For installation, follow removal procedures in reverse order. Replace any bent, damaged or missing plastic clips on the rear door trim panel to the door inner panel, firmly loading clips into slots provided on rear door trim panel .
  1. If equipped with power windows, disconnect the wire from the regulator.
  1. Remove the rear door window glass as described in this section.
  1. Remove the window guide, if equipped, (nuts and washers). Remove guide from door belt opening.
  1. Remove three 1/4-inch rivets attaching motor bracket (electric) to inner panel and two 1/4-inch rivets attaching regulator lower bracket to inner panel. Use drift punch to knock out center pins for each rivet. NOTE: Use care not to enlarge sheet metal holes in the door inner panel when drilling.
  1. Using a 1/4-inch diameter drill, drill out the remainder of the rivet.
  1. Remove two upper regulator attaching nuts.
  1. Remove regulator from the front door (20125) .
Installation
  1. Lubricate regulator mechanism with Multi-Purpose Grease D0AZ-19584-AA or equivalent.
  1. Install regulator into access hole in inner panel.
  1. Position regulator using upper regulator studs and tabs on motor mounting bracket (electric) or cup mounting plate (manual).
  1. Install rivets attaching regulator to door inner panel (1/4-20 x 1/2-inch bolt and 1/4-20 nut and washer assemblies or equivalent metric fasteners may be used as alternates).
  1. Install two upper regulator attachment nuts.
  1. Install door glass as outlined under Door Glass Installation.
  1. Adjust glass as outlined under Adjustments .
  1. Reconnect wire to regulator, if equipped.
  1. Check operation of window regulator.
  1. Install door watershield and trim panel. Refer to Section 01-05B .
Apr 11, 2009 | 1994 Ford Explorer Limited
John Deere 310sj Backhoe Logo
35 people viewed this question
Top John Toys Experts
Vernon Taylor
Adam Fjeld
Adam Fjeld
Are you a John Toy Expert? Answer questions, earn points and help others
