Question about Lexmark T640 Laser Printer
Print buffer now error - Lexmark T640 Laser Printer
The first 6 copies print quickly, then it goess to "slow motion" for rest of print job. How can I get the printer to print at the same speed
My guess would be that the quick printing at first is because the print job get spooled into a buffer and when the buffer is full the print job starts. The printer begins printing and using the buffer data as the computer continues to process the job and supply the buffer. At some point the buffer gets empty and the printer is waiting on the computer for more data, causing the slowdown. This rarely happens anymore, unless you have a very old printer or very old computer, as most printers have a rather large internal buffer memory. You may be experiencing issues with connectivity if the printer is being used wirelessly. Check to ensure that the wireless signal is strong to ensure maximum data throughput capability.
Oct 14, 2016 | Office Equipment & Supplies
The printer is not printing receipts and the error indicator is blinking on and off, what is the solution to this?
Flashing (approx. once every second): Out of paper
Flashing (approx. twice every second): Mechanical error (Buzzer sounds once.)
Most likely your paper feed is giving you the error. Remove the current feed, ensure there are no paper jam & insert fresh paper.
If
Mechanical Error :: Quick blinking Buzzer Sounds continuously for a pprox. 1 second :: Reset the Power
switch
Paper End Blinks.:: Buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Paper Near End Blinks.(Once a second) :: buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Mechanical Error : If the printer mechanism has a greater load due to a paper jam, etc., the buzzer will sound and the SEL/ERROR lamp will blink to stop the printer mechanism.
Paper End : If the printer has run out of paper, the paper sensor in the paper path near the print head will detect the end of the paper roll, turn on the buzzer, and blink the SEL/ERROR lamp to stop the printer mechanism. If the paper is inserted into the paper path, the paper will be loaded.
Paper Near End : If the paper is running out, the paper near end sensor will be activated to turn on
the buzzer and make the SEL/ERROR lamp blink. Even after the paper near end is detected, a command can be used to print by the specified number of lines. (See a description on the command for setting the number of print lines after paper near end detection)
Finally
Backup Data Clear : When the power is turned on, depending on the SEL switch operation, the
backup data in the input buffer will be cleared according to the flowchart on the next page.
To clear the input buffer, turn on the power while pressing the SEL switch.
The following messages will be printed.
"Clear Data in Buffer"
"Cleared Data in Buffer"
To print the data in the input buffer, simply turn the power on.
The following message is printed and the data in the input buffer is printed.
"Power Down(Data in Buffer)
Dec 13, 2010 | Citizen iDP-3550 Matrix Printer
Error message on printer is buffer overflow
you can go into the menu and increase the buffer size and probably eliminate this error.
Mar 23, 2009 | Texas Instruments 8920 Printer
Xante CL30 Fatal Error 177
I think that's a buffer overflow error, but if you get that error no matter what you print I would check to make sure your memory isn't bad.
Feb 13, 2009 | Xante CL30 HSE Laser Printer
What does "flushing buffer" mean
No response from the original poster as of 6/6/09. Normally, a "Flushing Buffer" message is pointing at a Postscript problem. A quick easy test would be to set the printer for PCL and retry the job. If it works, then you really need to look at the PS print file to find the error. Don
Jan 20, 2009 | Lexmark T644 Laser Printer
Printing labels
Error 23 is "Image not found". You could try to increase the Image buffer size (in the front panel, "Setup, Service", "Memory Alloc", "Image Buff Size". I'd try to decrease the Rec and Trans buffers by 50kb to make 100kb available to add to the Image buf.
Sep 20, 2008 | Intermec EasyCoder 501e Label Printer
Whats error code 3501
According to Kodak, that error just means the cover was open. I noticed when I print a diagnostic sheet that error shows up whenever I change the ink.
Sep 02, 2008 | Kodak ESP 5 Printer
Error in Print Jobs in the Queue
The use of a Print Buffer will help, the problem happens when there is a buffer overflow. Reboot the printer and let the print queue to resume will fix it every time, a print buffer will help with the overflow, try get one with a fair bit of RAM
Jul 15, 2008 | Zebra Z4M Printer
Clearing buffer
Press the SEL or ONLINE key, then turn the printer off. Clear the print queue in the PC and then turn the printer on again.
May 05, 2008 | OKI MICROLINE 321 Elite Matrix Printer
Failed to Print error
clean the buffer before fiving print and then restart the system. If the problem occurs same then reinstall the printer driver and then try to print
May 05, 2008 | HP Deskjet 3915 InkJet Printer
Lexmark T640 Laser Printer Logo
295 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
