Question about Holman Kitchen Appliances - Others
How to change conveyer on the ez10 - Holman Kitchen Appliances - Others
Where is the fns conveyance door on a konica 7020
Open the finisher should be to you up & right it would be where the paper comes out of the copier and into the finisher between both units is the conveyance
Jul 22, 2014 | Konica Minolta Office Equipment & Supplies
WHY IS MY EZ 10 GIVING A LOW HEAT CODE
Message is displayed and sterilization does not start if the autoclave has not reached sterilization temp. after heating for 50 mins. while in wrapped or unwrapped programs (80 mins in the Glassware program).
1) Clogged air jet, clean air jet.
2) no pwer to the heating elements.
3) Low line voltage delaying heat up. Not enough power to supply unit.
May 06, 2014 | Tuttnauer EZ10 Automatic...
Questing for an SMZ1244TX v2 driver for Win7 32 bit(pref x64 but I ain't holding my breath), otherwise known as the SMC-EZ10/100 "Compaq Special". Card came out of an ancient Compaq Presario 5000 Seri
First things first, x64 is for a 64 bit platform which your OS isn't ,but secondly if this card is ancient then it probably won't be supported on that platform anyways. Lookup the driver for a x86 (yes it's a higher number but it stands for the 32 bit OS your on. Why? That's another story) once you find the x86 bit driver to install it, just put windows 7 into compatibility mode for the windows version that driver was meant for. Confirm the changes in the bios and everything should work.
Dec 09, 2013 | Computers & Internet
Codigo C7760 de una Kyocera kilometros 1635
C7410 C7800 C7810 C8010 C8030 Drum unit connector insertion problem • Absence of the drum unit is detected continuously for 1500 ms while there is no error on the copier. Broken external temperature thermistor wire • The input voltage is above 4.5 V. Short-circuited external temperature thermistor • The input voltage is below 0.5 V. Finisher* paper conveying motor problem • The paper conveying motor lockup signal is detected for 0.5 s or longer. Finisher* paper conveying belt problem • An on-to-off or off-to-on state change of the paper conveying belt home position sensor is not detected within 2 s of the paper conveying belt clutch turning on. Drum unit connector inserted incorrectly. Defective drum unit connector. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the paper conveying motor connector terminals. The paper conveying motor malfunctions. Defective finisher main PCB. The paper conveying belt is out of phase. The paper conveying belt clutch malfunctions. The paper conveying belt home position sensor malfunctions. The paper conveying belt home position sensor connector makes poor contact. The internal tray is incorrectly inserted. Reinsert the drum unit connector if necessary. Replace the drum unit. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the paper conveying motor and check for correct operation. Replace the finisher main PCB and check for correct operation. Adjust the paper conveying belt so that it is in phase and check for correct operation. Replace the paper conveying belt clutch and check for correct operation. Replace the paper conveying belt home position sensor and check for correct operation. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Check whether
Jan 19, 2010 | Office Equipment & Supplies
Please close FNS conveyance door
Aug 31, 2009 | Office Equipment & Supplies
Holman qt14
Change the direction the conveyor drive motor turns. There should be a reversing switch located in the control box. TURN THE BREAKER OFF FIRST. Then access the control box.
Jul 22, 2009 | Ovens
Konica 7130 Conveyance Door
Contact a Local Konicaminolta dealer order part
Mar 12, 2009 | Office Equipment & Supplies
Have a apw wyott conveyor toaster, conveyor randomly stops
I had a similar problem I changed the Rear Bearings in the belt & Check the Fan motor in the rear which houses the conveyer Motor wheather it is working or not it could be the fan not working and over heating the motor the last thing is the screws that hold the conveyer motor are too tight as the motor is self adjusting.
Jan 17, 2009 | APW Wyott AT-Express Conveyor Toaster
Sony Slv-EZ10 Error
try unpluging it for a day
good luck
please mark the post with a fixya!
Feb 04, 2008 | Televison & Video
Kitchen Appliances - Others Logo
24 people viewed this question
Top Holman Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Holman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
