Question about Honeywell TH6320R1004 Programmable Wireless Thermostat
The compressor cycle rate is from 1-6 for both stage 1 and 2. I want my turn off the compressor cycle rate. How can I do this?
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: can i use th5320u1001 on
Yes, that t-stat has that capability...
http://www.pexsupply.com/Honeywell-TH5320U1001-The-FocusPRO-Non-Programmable-Digital-Thermostat-Premier-White-4956000-p
If you need the manual to get it set up then check out this tip...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Posted on Sep 15, 2010
I have a DSZC16 manual indicates 2 stage compressor does that mean it increases speed when needed?
2 or 3 stage compressors normally run at a constant speed
the stages are from different size pistons
1st stage is a large piston for low pressures that feed to a second smaller piston for higher pressures and for 3 stage to an even smaller piston to get really high pressures
for example 1st stage =100psi
2nd stage =1500psi
3rdstage =3000psi
your manual should explain the set pressure for the compressor if the compressor speeds up , that is a two speed unit
Sep 12, 2017 | Air Tools & Compressors
I need a 4 piston A/C compressor or a 4 piston hydraulic pump for a project. do you know which models have this
http://www.boge.com/in/artikel/download/Brochure304_EN_Piston.pdf
Devair/DeVilbiss Piston Air Compressors
www.centrair.ca/piston_compressors.html 5hp piston air compressor, 7.5hp piston air compressor, 10hp piston air compressor, 15hp piston air compressor, 25hp ... PUMP: 2 x 447 (2 stage 4 cylinder)
10HP 4 Cylinder 2 Stage Air Compressor Pump
https://www.eatoncompressor.com/10hp-4-cylinder-2-stage-air-compress... Solid cast iron 2-stage V-4 piston series pump, oil lubricated design to extend pump ... This is our 10 HP, 4 Cylinder, 2-Stage, air compressor pump with 43 CFM ... Compressor Stages‎: ‎Two Stage CFM @ 100 PSI‎: ‎43 CFM Compressor Type‎: ‎Bare Piston Pump Horse Power‎: ‎43 CFM
Petstar 4 - Ingersoll Rand
www.ingersollrandproducts.com > ... > PET Compressed Air Solutions Ingersoll Rand PETStar® 4 reciprocating air compressors offer durability and ... pistons with heavy-duty Class 40 cast iron cylinder construction; Piston rings and ...
Jan 31, 2016 | Air Tools & Compressors
Is the Honeywell RTHL2310B 2-stage compatible?
sometimes the jumper cancels the cycles
Aug 03, 2017 | Heating & Cooling
Compressor fills air tank and when it cycle to refill tank it kicks a 20 amp dedicated circuit breaker. Sears looked at it twice and said it is OK. Changed breaker with new one because Sears said it...
try this. When compressor shuts off. TURN OFF POWER. then spin the compressor backwards or forwards until it is off the compression stroke. Turn unit back on. If it doesn't blow the breaker, then it is worth looking into the type of compressor (pump) you have. Many have a "reed valve" and that might be failing, holding the compressor itself under load when it shuts off so that on restart it is under heavy load and the motor draws too many amps to get it started hence blowing the breaker anyway hope this helps
Feb 17, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
We have bought a home with the wite rodgers thermostat 1f85-275 it doesn't seem to be working. on the top right of the screen it states 1&2 stages? anyway, help would be appriciated
Hi, this thermostat is for central heat and air systems that have more then 1 stage of heating or cooling. For example, your unit may have 2 stages of cooling, as in 2 compressors, or 1 stage of cooling and 2 stages of heating as used in commercial heat pumps. This is a multi-stage heat pump thermostat. It may be just a matter of programming the stat. If you can find a manual on it, this would help. If you open the cover, it should have directions on how to program it.Make sure you have power to everything, check all breakers to see if they may be shut of, even if you have a display, doesn't mean you have high voltage to run the unit. Make sure fan is in auto, and on heat or cool, and temperature set for it to come on. Please keep me posted.
Sincerely,
Shastalaker7
A/C, Heating Contractor
PS Your unit has 1 stage of cooling, and 2 stages of heating.
Nov 05, 2010 | Heating & Cooling
Poor supply air pressure
3 stage? It sounds like the first stage has a leaking valve, possibly second stage also - this would explain both the high temperature in stage 1 and the poor pressure from the final stage. Take a look at page 6 of the following link. This is the typical intake and outlet valve diagram for each stage. Valves #2 are intake valves, and valves #6 and 7 are discharge valves. They all perform like check valves, each valve allowing air flow in only one direction. It sounds like your valves are leaking between 1st and 2nd stages. Possibly debris in the valves, or valves damaged. Try taking air intake filter off and check for damage to air filter and debris at intake. Also try removing valve plates and check for debris/damaged valves on first and second stages.
http://www.irservicenet.com/filestorage/SCD-749_.pdf
May 05, 2010 | Ingersoll Rand - Rand Type - 30...
Compressor not cycling and building pressure after servicing
Hi
I suspect you may have either overfilled the sump or used the wrong viscosity oil, may have splashed up onto valves and patially jammed one open.
Aug 11, 2009 | Champion International Champion 532 2...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Im putting a 2 stage pump on my compressor
I would be glad to help with your project, sounds like you are a tinker-er. Most all compressors whether one or two stage are plumbed the same. The important difference is that two stage compressors are made for a higher pressure range. This means that the tank must be able to safely hold more pressure than single stage. Other considerations are that the pressure switch, safety valve, check valve, regulator and all the tubing would need to be upgraded. Finally two stage compressor takes longer to cycle because of lower volume. If you want to continue, post again listing the parts that you already have.
Nov 30, 2008 | Craftsman Air Tools & Compressors
Honeywell TH6320R1004 Programmable Wireless Thermostat Logo
76 people viewed this question
Top Honeywell Home Security Experts
Sean
Jay Finke
Jay Finke
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
