Question about Hobart Dishwasher Am-14 Commercial Dish Washer
I have just replaced the pcb board in my amika 6xl now the pump kicks in runs for few seconds stops the starts again and just keeps doing this any ideas please
1994 Ford escort GT 1.8liter my fuel pump is not kicking off after three second's it runs consitly while the key is in on position why
Maybe your fuel pump relay is sticking on, and needs replaced. Even when you turn it off from running, and then key back to on, it keeps running constantly? The computer signal to the relay, energizing it to pass power to the pump, should only last 2 or 3 seconds. I think it automatically stops the signal after that short period. The relay should click off then and stop the pump. The computer would signal it again when it senses the engine cranking, but not until then.
May 28, 2015 | Ford Escort Cars & Trucks
Got a Amika dishwasher model 6xl, it's running continuously, suspect the relay contacts welded, want to know where is the relay located, suspect it's the one on the pub. Anyone knows.
Does it have a mechanical timer or a pub? The mechanical timer motors sometimes burn out leaving it in the wash cycle continuously
Sep 23, 2014 | Dishwashers
Truck will start and then stops just started acting up
Found on a '92 Toyota pickup w/V6, a bad/intermittent fuel pump relay.
Had fuel rail pressure so fooled us initially, found by listening to pump run then quit, cycle key and pump would run again then quit, sometimes when trying to start, motor would start and run for a few seconds then quit, or not start at all, this created by intermittent relay operation. Need two people, one at passenger side by tank and other to work ignition switch.
Relay located behind right, passenger kick panel, dealer item I believe about $28.00.
Just another possibility.
Mar 12, 2014 | 1992 Toyota Pickup
My ice machine manitowoc q 132a starts up stops after few seconds while water pump start
There is a high pressure switch that stops the unit running if a fan fails or the condenser is clogged. Next time you start the ice machine, watch the bottom led on the pcb. It will tell you if there is a fault. Meantime, reset the hp switch and clean the condenser thoroughly.
Sep 06, 2012 | Refrigerators
Engine acts like it is out of gas keeps stalling i can turn it off for a few minutes will run for a mile or two then does it again
Vent valve has failed closed or cannister is clogged up. Have the evap system checked from the tank to the charcoal canister. If you need to drive to a mechanic, try driving with the gas cap loose.
Dec 16, 2017 | Hyundai Motor 1999 Elantra
Aprilia mx50 will kick over then stop after 5 seconds kick over again and will stop after 2 seconds, then wont start, leave for a few mins and will kick over and will run for 5 seconds and so on, any idea...
If your bike starts even for 5 seconds you should investigate your fuel delivery system.Check fuel pump,filter,try spray carb cleaners like Gum Out.Most importantly make sure your choke is working.You got your ignition (spark) it is most likely fuel related.Good Luck.
Sep 19, 2009 | 2005 Aprilia MX 125
Fuwl pump runs for three seconds and stops
The relay is supposed to run for a few seconds to bring the fuel pressure up to specifications,,then shuts off again,,this is normal behavior in most cars with electric fuel pumps.
When you start the vehicle, the pump will cycle on again and shut it'self down when it needs to.
Jan 19, 2009 | 1997 Jeep Tj
Zanussi Aquacycle 1000 f1045 spin dry fault
test the machine empty without clothes in it, if all is well then i think your problem may be the motor carbons, take them off and check for damage, make sure one of them has not spit down the middle, also look at the armature for signs of sparking,a worn armature or carbons will work fine at slow speeds
you haven't mentioned the carbons, its trying to spin so may not be the pcb
Oct 14, 2007 | Zanussi FJD1666W Front Load Washer
Hobart Dishwasher Am-14 Commercial Dish Washer Logo
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
