Question about Pool & Spa
Jandy bluehaven bh6100
How to cancel a program in menu want to cancel all the different run times
Need to cancel filter programs
go into the system set up and go to programs then delete or edit
Apr 20, 2013 | Jandy Pool & Spa
BH6100 error code
check to see if 4 pin connectors wires arent touching at plugs if ok check to see if wires are cut
Nov 05, 2012 | Jandy AQUALINK RS TELELINK KIT
I have a blue haven bh6100 and the spa drained into the pool
check valve actuators must be on and in correct positions
Jun 12, 2012 | Jandy AQUALINK RS TELELINK KIT
How to turn off freeze protection on BH6100 control panel
go into system setup go to freeze protection and un highlight that device
Dec 04, 2011 | Jandy AquaLink RS2/6 All Button Dual...
How do you reset the programs? Unit is saying
You need to hit the menu button and go into program. In there you will see each item, such as the filter that is on a schedule. When you hit the filter, it will have 3 options, add, remove, or change. Just hilight the schedule and hit remove, that program will be deleted.
May 15, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Need to clear a program from my aqualink
Start with the cancel button. It will then prompt you to cancel the desired program. Go through the menu as you would with a program but follow the prompts to cancel. Remember, press cancel to start.
Dec 26, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool & Spa Logo
454 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
