Question about Dryers
Fit thermostat beko
WHERE CAN I GET A THERMOSTAT FOR A BEKO DSC85W
3 Suggested Answers
SOURCE: i have a beko drcs68s
Take the back cover off. The thermostat is located next to the heating coil, usually held on by two wires.
Your local parts supplier will also be able to test it for you to see if that the problem before you buy it
Posted on Feb 16, 2011
FitzOriginal
  • 842 Answers
SOURCE: Beko Tumble Dryier - Model DRVS 73 W the Belt 9PHW
Very easy on all tumble dryers.
UNPLUG FROM POWER FIRST!
This is simply a case of:
Take the top off the machine (Usually a couple of screws holding the lid on at the back).
Or - Rempove the inspection panel from the back
Drop the new belt over the drive motor spindle
On some machines you may need to thread the belt around a tensioning wheel
Now take the belt and place it on the side main wheel that drives the drum and simply spin the drum wheel with your hand, guiding the new belt into place as you spin the wheel.
It should simply stretch a little and work its way onto the wheel as it is hand turned.
Note, once it is on, take a look at the drive motor and make sure that the belt is sitting in the same place as the old one. Most of these motors have a slotted spindle and you can see from the clean and shiny surface where on the spindle the belt used to sit. If it is a little out of place, once again just take hold of the belt and pull it toward you or push it away as you spin the main drum wheel in order to move it into the correct slot.
Posted on Jun 23, 2011
Beko 450 dishwasher hot on all washes is it a thermostat problem
CHECK UR WATER TEMPERATURE THERMOSTAT AND UR WATER INLET VALVE THE COLD WATER COIL MAY HAVE GONE BAD OR GOTTEN CLOGGED ? CHECK UR WATER LINE FROM THE HOUSE TO MACHINE TO MAKE SURE ITS OK
Feb 19, 2015 | Beko Dishwashers
How the fan for beko fridge. work.
Please restate you question with better grammar & spelling.
May 07, 2014 | Beko Fridge/freezer Thermostat Genuine...
The fridge side of my beko fridge freezer is freezing all the food
This is a thermostat problem
A new thermostat needs to be fitted
A technician can help you with that
Mar 24, 2011 | Refrigerators
I ve got beko electric cooker model DC543 and the oven doesn't work
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
    If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 15, 2011 | Ovens
Have beko D533W electric cooker oven not heating up fan still working
Generally speaking, if the fan is working o/k, then it is usually the fan oven element that has failed.
This is usually located at the rear of the oven compartment behind a removeable cover.
Nov 14, 2010 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Beko double oven electric cooker - bottom oven (fan assisted) doesnt come on, rest of cooker works fine
Oct 03, 2008 | Kitchen Ranges
Dryers Logo
21 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
