Question about Mitsubishi VS-55705 55" Rear Projection Television
Lost my picture when went to pip
I have dish network connected to my tv. I was trying to bring up the pip on the satellite remote. Everything was ok until I changed the channel with the satellite remote. I have good sound, can pull up all dish network dvr and help screens. My other tv on this receiver is fine.
    Novelist:
    Scholar:
  • 149 Answers
Check your PIP source. I couldnt figure out my LCD pip, and why it wasnt working either until I was able to switch the source. It was automatically using a source that didnt have anything hooked up to, I had to switch mine in order for it to work. Try that and see if that might be the case. let me know. thanks!
Posted on Sep 24, 2007
SOURCE:
The picture is at the top left of the tv and everything else is black
xXComparedGaming7xX, I would be more than happy to assist you with this!
It sounds like picture-in-picture is enabled. To check this, look for a PIP button on the bottom of the remote. If there is one, press it and see if you can change the settings back to normal. If it continues, let me know!
Tommy Faust
DISH Social Media Representative
Nov 10, 2013 | DISH Network Televison & Video
I have Dish 322 receiver. Everything was fine; a week or so ago satellite 119 reception was spotty, now we can't get 119 at all. We get 110 but only about 34%. Sometimes the receiver will power itself off...
hartpark
It looks like you have lost the signal for the 119 satellite from your dish. Are you getting an error message, either 002 or 015, saying the satellite signal has been lost or acquiring satellite signal? First, check the cables on the back of the receiver to make sure they are secure. You can also run a check switch test to see if there is a problem between your dish and receiver.
Press the Menu button on your remote. This will bring up the Main Menu on your TV screen. Input the numbers: 6 (System Setup), 1 (Installation), and 1 (Point Dish). On the right side of the Point Dish screen are 3 buttons. Select the Check Switch button. Within the 2 large boxes are satellite numbers and green or red boxes. Make a note of the satellite numbers (should be 119, 110), the trans, the device, and switch. Super dish and alternate should not be checked. Select the Test button on the bottom of the screen. If a box pops up with a warning about TV 2, select Yes. It will now run the check switch test. Let it complete the test. After completion, the screen will automatically go back to the Installation Summary screen. You may get a message stating that the Check Switch test has found fewer satellites than previously detected. If you get this message cancel out of each screen (do not save the results) till you are back to the TV screen and it is acquiring Satellite signal.
If you don't get that error message, see if the information on the Installation Summary has changed. Then select Done on the next 2 screens and cancel out of the others till you get the message, Acquiring Satellite Signal. After it finishes acquiring satellite signal and downloads the program guide, see if you are getting a picture - try different channels. If you still have problems, please email me at, [email protected] If you are still experiencing problems, we will need to send a technician to fix the problem.
Ray Calo
DISH Network
Apr 23, 2011 | DISH Network 322 DTV Receiver
I have recently had dish network installed and now I cant get my DVD player to play I have tried contacting dish network for assistance and no one can figure out the problem. I have a LG TV
Hello! This is Dan with DISH Network customer support. have you tried cycling the inputs? If you have an HD tv the DISH receiver and your DVD are probably connected using different cables. I would power them both on and hit the input or source button on your LG remote until you get a picture from the dvd player. Remember what input comes up as you will need to change this to go from satellite to DVDand back.
Jan 12, 2011 | Directed 434MHZ Remote Control
Dish network changed to snow when I tried to change station to channel 13. I pressed "power" for 5 seconds with no change.
Hi, Mary with Dish Network Customer Service here. It sounds like when you try to change channels with your remote, it is changing the channels on your TV and not your Satellite Receiver. In the top left corner of the Dish Network remote is an SAT button. When you try to change channels on the Satellite receiver this button should be lighting up. If the TV button lights up, it means the remote is working the TV. Press and release the "SAT" button after you have the picture back on the TV and it should work normally. I hope this resolves your remote issue!
Jan 12, 2011 | Toshiba Televison & Video
I have a dish network echostar remote control (20.0 IR). When I press any button that normally controls the satellite box, nothing happens except the green "sat" button on the top left lights...
Unplug the satelite box and replug it back like about an hour later.By letting the box resetting and upgrading it softwares the remote should work again now.
Dec 25, 2010 | DISH Network IR Remote Control
I hit the wrong button on the remote - took me to a Dish option - I chose to exit. The screen is now black and blank, no matter what I do - no response. I went back to TV and chose channel again, but that...
Hiaschulte274 my name is Mike Houston of DISH Network, there are some things youcan do it get back to your programming. The first thing you will need to do isunplug the receiver for 10 seconds and after plugging it back in it will powerup and once you see the green light on the receiver you will want to go tochannel 3. If you still see no programming go through the different inputs onthe TV. I will send a link to help show how to resolve this issue as well. http://www.dishnetwork.com/SupportSection/bbs-screen
Jun 12, 2010 | DISH Network IR Remote Control
Need code for 32in.olivia tv
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, TiVo’s, DVD, Blu-Ray or even HD- DVD players. The learning remote is available at 866-965-3842
Dish Network Remote Codes 506 or 127
could try Dish Network..Remote Codes 506 or 127
Satellite TV Systems Dish Network Remote Codes 506 or 127
May 23, 2009 | Syntax Olevia 537H Television
Cannot connect second tv to Dish
Gregg,
If this is a replacement TV I would say you are probably better off with the universal remote if you are not able to bring up the menu using the front buttons on the set. Call me if you like and I will see what solution we can arrive at based on your receiver type and TV.
Jim
912-222-5778
Sorry, to hear of your trouble as well Mary and that we lost you as a customer.
Mar 01, 2009 | DISH Network IR Remote Control
Dish Network - Dish 500 Satellite 110 is not being recognized
chances are that you have only lined up the dish to pick up one satellite. there are several satellites up there for dish and its easy to miss the ones that you need. try to line up the dish keeping this in mind. if that doesn't work, write back.
Apr 30, 2008 | Televison & Video
PIP on an older SONY with DISH
If you are using the satellite remote then you need to contact the dish company and ask them how to program the remote. Good Luck
Dec 29, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Open Questions:
Mitsubishi VS-55705 55" Rear Projection Television Logo
101 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
