Question about Sony STR-DE915
I have a SONY STR DE915 receiver home theater amp. After 14 years, it decides not to power up! Are there internal fuses? Can i replace the power supply myself?
    Genius:
  • Sony Master
  • 1,054 Answers
There are internal fuses that you can check. This model was notoriously bad for amp problems. These amps would burn up a lot of components when they go out.
Posted on Oct 11, 2013
SOURCE: No power -- bad power supply?
The fuse thats leads to the power supply on the sony receiver blows everytime i try to plug in the receiver. What makes this happen and what can i do to get the receiver going again. Model STR-DE135.
Posted on Oct 12, 2008
SOURCE: I have a Sony STR-D565 Receiver. I bought new
I resently hooked up my sony std d 565 reciever for 5.1 speakers and I keep hearing beeping, what is wrong?
Posted on May 01, 2009
  • 118 Answers
SOURCE: I have a Sony STR-D965 receiver that has worked
its a common problem when the amplifier outputs are shorted and need to be replaced. put tinfoil on the fuses and watch it smoke
Posted on Nov 04, 2009
SOURCE: No power on my Sony STR-DA555ES
i went to sony's webite and called direct and got a power supply for just under 200 dollars to my door better than paying 1500 for a new one i over loaded mine and plug to may things in the back of it but the part is available
Posted on Feb 11, 2010
  • 652 Answers
SOURCE: Sony STR DE-445 unit powers up but no sound
Check the fuse, Sony is known for its random problems with sound. The one I have you must tap it on the side. Its a flicker switch inside.
Posted on Feb 14, 2010
I have a Sony STR DE915 amp. It will not power up. I checked the internal fuse (it's OK). Power button has dislodged and may be broken. Am looking for disassembly instructions (not schematic diagr
Simple, if you are not confident in your ablility to fix the problem by dissasembling the boards then by all means, take it to a repair facility.
Apr 20, 2014 | Sony STR-DE915
No audio. Checked all the basics. Internal fuses are ok. Is this worth fixing?
Check power supply transformer, that could be last thing before deciding to throw it away.
-SS.
Oct 27, 2013 | Sony Stereo Am Fm Receiver Tuner Amplifier...
No sound out of sony DE915
Change the audio amplifier IC´s are damaged
Sep 10, 2009 | Sony STR-DE915
Protector push power - dvd home theater system
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Jan 20, 2009 | Sony STR-DE875 Receiver
Sony Receiver Won't Power On
Did you have any Rca Cables running to a Tv or anything by accident cuz it could run thru those, Lighting is a powerfull substance, if it hit the house then it could of ran into the cable to the tv an went out, thats wierd this is the 1st time ever hearing this, try looking in side to see any burn markings, an take a wiff cuz you can tell if somthings fried by the smell of it, if it is then its most likly dead
Oct 20, 2008 | Sony STR-DE915
STR-DE915
if your preferring to protect light your either, pushing to much power, or a wire could be touching along the line. Check all your wiring even the ones behind the receiver that could be your problem
Mar 10, 2008 | Sony STR-DE915
What power rated speaker shoud I use with my str-d865
Sony STRD865 Home Receiver - Dolby Pro Logic - 1995 Related Models << STRD665 ($300) | STRD965 ($400) >> Here's the specs, see below but looks like 100Wx2 speakers at 8ohms. Features: A/V remote; Digital Signal Processing w/ 6 soundfields (Dolby Surround, Hall, Theater, Stadium, Game, Acoustic), Soundfield link; 30 presets; 4 audio/ 4 video inputs (1 tape monitor); sleep timer Specs: Stereo: 100w x2 into 8 ohms (20-20k Hz) at 0.3% THD; Pro Logic: 100w x3; Surround: 25w x2; subwoofer preout; FM sens. 11.2 dBf; 17" W x 5 3/4" H x 14 1/2" D Hope this helps!
Sep 14, 2007 | Sony STR-D865
132 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
