My criterion wont light. all i hear is a humming. no fans move. i have replaced the ignitior with no joy.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 83 Answers
It most likely the pilot light will it come on and stay on ?
If not turn off gas , then you will see a solid round shiny piece that is by the pilot light take some real fine sandpaper or a new non wet brillo type pad and shine it up a little do not get carried away
Then turn on gas and try lighting the pilot light again
If that does not work then you may have to remove the pilot assembly and clean it or replace it
Posted on Oct 20, 2013
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not...
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Nov 11, 2014 | Refrigerators
Gas wont light
check the continuity on the ignitior if its open replace the igniter if closed replace the coil valve
Apr 12, 2012 | Frigidaire FGQ1442ES Gas Dryer
My pontiac montana 1999 is making a loud humming sound only when iam moving. The faster I go the louder it gets and every once in awhile it jerks
you will have to ask a local mechanic to diagnose this noise for you as without hearing the noise i have no idea what it could be ,if i could hear the noise i could tell you straight away ,sorry to be a bore but its one of the joys of motoring as this noise could be a wheel bearing or a water pump and without hearing it ???'
May 17, 2011 | 1999 Pontiac Montana
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    Rear end humming noise
    check the play in the pinion gear bearing on the rear end i think! you will find the yoke ie lose and also the bearing has excessive play and needs ro be changed
    Jan 22, 2010 | 2000 Chevrolet Blazer
    RHEEM CRITERION II FLAME LIGHT DOES NOT COME ON
    1/ overheat stat 2/ fan 3/ diaphrapm valve 4/micro switch when checking fan be sure to check the very small rubberor nylon hose for pinhole best of luck
    Oct 29, 2009 | Rheem Paloma PH-20R IFSN / RTG-53PVN...
    Ceiling fan will not spin, but I hear it
    It most likely has a faulty capacitor not allowing it to start. Remove the light kit or the cap where the light kit mounts, the speed and reversing switch will be in there along with a capacitor. You should be able to buy a replacement capacitor at most home improvement stores.
    Sep 30, 2009 | Dryers
    Replaced the lamp, still wont come on.
    1- Did you make sure you have the lamp door on correctly, there's a safety switch that activates and wont let the lamp light for your protection.
    2- Put your ear close to the lamp door and listen for a slight hum as soon as you turn it on, it will go in cycles. If you don't, it's going to be the ballast module or the color wheel, both these have to be working to let the lamp light. I suggest you call a service center after that, that's the best thing.
    Feb 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
    Heating & Cooling Logo
    24 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
