Question about Polaroid Tablet Computer PMID701
The screen is asking for a passwork with no Internest conneectionproblems
I turn on my tablet but it ask for a password with no interest connection. How can I reset this
When I turn on the tablet and swipe screen it asks for password,I dont know what it wants
Someone installed a password, so until you either perform a factory reset of the tablet to clear the password or remember the password you are kinda sunk. A reset will erase all stored data except what was loaded by the factory.
Jan 17, 2017 | Tablets & eReaders
How can I get my tablet to connect to my modem?
Have you tried having your tablet unlocked to home screen then connect to modem. Your tablet should be unlocked in settings for USB connections. If nothing works, back up your tablet to email, factory reset and try again like new, when done restore your tablet. Good luck
Jul 07, 2015 | Tablets & eReaders
How do I get my tablet to sync up with my router, even tho it is giving me a message that there is an excellent connection available on my router, using the MEP router code?
If you tell your tablet to connect to your router (click on your router) It should then ask ask for the pass phrase or password you will find this on your route usually on a sticker on the bottom enter this and it should connect you
Mar 03, 2015 | Proscan 7-Inch Android Internet Tablet,...
I wifi in my house for multable devices,the Tablet is one of them.well when I powered the tablet on it ask me for password or pin the only problem with that is I never set on up and I have no book for
Probably your WiFi home network is password-protected. You are asked to enter the network password , not the tablet's password. If you are asked about a pin, it means that the tablet is trying to connect to WiFi in WPS (WiFi Protected Setup) mode. You may find the network password in the set up guide of the wireless modem/router. The pin may be on a sticker affixed to the router. You enter the password or the pin, not both.
Dec 07, 2014 | Tablets & eReaders
How do I get internet on my.tablet
Hi Tara, if your tablet is WiFi compatible, it should have an option in the settings to select a WiFi source and connect. Most will require the correct password.
If it is and Android tablet you can swipe down on the screen and press and hold on the WiFi button to turn it on and select which source to connect to.
If it is and iPad, you can go to settings and enable it there, then select the WiFi source and enter the password.
Hope this helps. Don't forget to comment/rate the sollution or ask further questions on this thread.
Jul 15, 2014 | Tablets & eReaders
How to connect my tablet to internet
I'm assuming your tablet has wireless (WIFI) on board. If so, go to your settings screen and look for wireless networks (usually a tab somewhere in the settings screen). Make sure WIFI is turned on and then search for available networks.
On most tablets, available networks will automatically show up. Select the one to connect to that you prefer, type in the password when it asks, and you should be good to go.
Jun 19, 2014 | Tablets & eReaders
What is the screen supposed to look like when my tablet is charging?
my craig tablit is not letting me get in it is frozzon and ask me for my passwotd and i have for gotton my password and i wood like to change my e mail and my password to so can you help me do just that there is a line at the rigth side hat askes me for my password i have turn off the tablit so many ways and hold the botten on and off so place help from evangeline
Aug 01, 2013 | Craig CMP741d Tablet
How to unlock HUAWEI s7-931w tablet
If your having problem like this I suggest that you perform a hard reset. To hard reset just simply follow this step.
And remember reseting can delete your all access data specialy passwords and code.
To hard reset:
1. Turn off the whole system.
2.Hold together buttons: Power + Volume Down. In several second until logo appear on the screen.
3. Release the buttons. And without asking and without notice System will automaticaly doing a reset.
If this will not succesfull, try to create google account on PC. Then remember all information you've made, the email and password. You said system asking you to sign in to google. Use all information you've got to sign in.
Note: The google method is not working on other tablet, but most of it solve the problem. Then you should go to area where you have an a access of wifi, place where can you connect a wifi. Internet connection is realy realy needed.
Hope it will help.
Jan 28, 2013 | Huawei mediapad 7 s7 931w wifi tablet
How do i change my password
Click on can't remember password and hopefully it'll take you to where you type in your username or google email address then it should ask if you want a code sent to your cell phone, which it would show the last 2 digits of it if you set that up. If not it'll ask to send you the code to your alternate email. Then type in the code either from your phone or email and then you'll be able to make a new password and type it in twice and save it. That should work! Jennifer
Jan 06, 2013 | Curtis Klu 7-inch Touch Screen Mobile...
Polaroid Tablet Computer PMID701 Logo
19 people viewed this question
Top Polaroid Tablets & eReaders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
