Question about Pets - Others
Given Bargain Hound 26" L x 17" W x 18" H. Doesn't have side locks. Need 8.
Name of retired greyhound now 8 years known as Nobby. Ran at Harlow track and first part of racing name is Lord Nobs....
Why on earth have you posted this query in a forum dealing with Camcorders ? Try the Grey Hound Trust, RSPCA or contact the dog track and ask them.
Oct 14, 2017 | Video Cameras
2000 cadillac deville driver side won't open with the key
1) Key turns but dose not unlock door. This means that the rod that goes to the back of the lock has came off. This also means that is the reason door is not unlocking with the remote as it pops the lock rod inside the door which pushes the lock open.
2) Key does not turn lock at all but works passengers side door. This means that the locks has been changed in the door, but that doesn't sound like the problem as you say the remote doesn't open the drivers side door so more than likely the rod has came off the back of the lock
Nov 07, 2012 | Cars & Trucks
Powered electric driver's window doesn't come down
There shouldbetwobrowb wires at the switch. One should have power all thetime. The other hound have power in only the down position. If there's power in the up position than the switch is bad. The dark blue wire should have power with the switch in the up position. If there is power in the up position than he switch is bad. If the switch checks out fine than motor is the problem. You can try to confirm this by tapping on the motor while holding the switch in either th up or down position. If it starts to work replace it.
Jan 03, 2012 | 1995 Chevrolet Monte Carlo
I want to know where to go to catch the grey hound
im not sure where you are but the grey hound bus station in ottawa is on cathrine street 2 blocks west of bank street
Mar 03, 2011 | Cycling
I need a replacement thimble lock for a mitutoyo 6-12" outside micrometer(104-138 s/n#1080588).
i image the 6 - 12" is a fairly expensive set. you could buy the 0-1" which has the same thimble lock. i have one at home. and switch them out. can be bought $100 or less brand new. or search for an ebay bargain.ive never heard of the thimble lock go missing or break before. its doubtful mititoyo supplies replacement parts for mics.
Mar 31, 2010 | Mitutoyo Measuring Tools & Sensors
Trying to connect to my pc via active sync and use it with Tool Hound. this scanner was previously used with another application.
You will need an appropriate application for Tool Hound. They have a client for your gun. You will have to contact Tool Hound. Your previous application on the gun is looking for it's host. It won't work until you get your Tool Hound rep involved.
Bill Barcode
Nov 04, 2009 | Zebra Symbol Technologies MC909X-G Series...
Power head stopped working could it be the switch? could it be the motor? thanks
If its an electric head switch it off and remove the screws underneath or if it has a slide out cartridge check that the brush isn't clogged with dust. Sometimes the toothed belt can come undone if there's an obstruction.
Jun 13, 2009 | Miele S514 Solaris Turbo Plus Vacuum
Main frame and worn wheels of the quinny buzz
Hi I got a nearly new frame off ebay for a bargain! There are loads of spare parts to be had on there.
Aug 03, 2008 | Quinny Buzz 3 Sulphur Jogger
Pets - Others Logo
51 people viewed this question
Top Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a Pets - Other Expert? Answer questions, earn points and help others
