Question about Whirlpool Wdt770paym
Whirlpool Wdt770payb has a water leak about 1/4 " wide from the bottom of the undercarriage which occurs after the prewash cycle and shortly after the main wash begins. We have eliminated door leaks, leveling, sticking float, etc. which are recommended as first effort repairs. The unit is less than two years old. Suggestions are appreciated.
  • Harry Riebe
    Harry Riebe Oct 13, 2013
    Update to water leak problem. The source of the leak has been identified by elevation the dishwasher to where the bottom could be clearly viewed. The leak is coming from the shaft of the wash/drain relay which extend into the underside of the dishwasher chamber with contains the shutter that changes the system from wash to drain. Any suggestions as to what would be the easiest way to fix it as the bottom assembly looks challanging to take apart
SOURCE: water is leaking out of the washing powder drawer
the spray holes in the soap manifold are partially blocked and spraying at an angle. try to reduce the water flow pressure at the feed tap and clean the water holes in the soap tray manifold (above the tray).
Posted on Feb 16, 2008
SOURCE: Whirlpool Cabrio Leaks Water
you probably got coins or junk in the water pump on the bottom back of washer and it poked a hole in the housing. Thats what happened to me
Posted on Sep 16, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool GHW9300PW water leak
The problem, I suspect, is the door bellow. This is the gray rubber boot on the door and front of the tub. The key is the fact that it only leaks during fill, or when adding water, and only leaks in the front center. The washer fills through a dispenser tube in the door bellow. Water runs through this tube and into the front portion of the tub. If you pull back the rubber folds of the bellow and look, you may have some rips or tears causing the water to drip out. If there are no obvious signs of wear causing the leak, the other two possibilities would be the dispenser tube not inserted through the bellow all the way. That is, the tube may have slipped behind the bellow a bit and may be causing water to drip BEHIND the bellow instead of through the fill port. Another cause would be if one of the clamps that hold the bellow in place has come loose and is not sealing to the front of the tub, or door frame properly. The following link explains how to replace a door bellow:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I provide this link not only to give you advice in the event that your bellow needs replaced, but also to give you steps necessary to access the bellow in order the check or tighten the clamps. NOTE: An alternate method to checking the rear bellow clamp (located on the front of the tub) is to remove the washer top panel and attempt to access the 7mm clamp nut from the top. The method I have described in the link, however, offers the best access. NOTE: The clamp needs to be seated evenly around the entire perimeter of the tub facing and the clamp should be SNUG. DO NOT overtighten. This will cause damage to the clamp and/or tub facing.
If you require a replacement, you can order on line at appliancepartspros.com. Just type in your model number and look under the "Door and Latch Parts" heading for item number 5. Other items of interest are the rear bellow clamp, item 6 and the front bellow clamp, item 14. In most cases the clamps do not require replacement and can be reused. But, just in case you have to replace them, you now have them identified.
You can perform this repair on your own, if you like and save the cost of expensive labor charges. This is not a difficult repair, if you follow the instructions provided. This repair can usually cost $200 or more (cost of the part, plus the labor) if you have a repairman do it.
The problem could possibly have been caused by excessive vibration, but its hard to tell. Washers mounted on a pedestal can often have vibration problems if the washer is not mounted properly to the pedestal. Make sure all mounting bolts are installed that hold the washer to the pedestal. Make sure they are tight. Also, proper leveling can be an issue. DO NOT attempt to level the feet of the washer on a pedestal. Mount the washer and adjust the feet of the pedestal for proper leveling. Make sure the unit rests on a flat surface and is level front-to-back and side-to-side. A good foundation is also required to ensure the washer does not vibrate. If the flooring under these washers flex (even the slightest) they can cause vibration problems even if it is properly leveled. Flooring in an upstairs laundry room or a mobile home is usually the worst. Another item to consider is the pedestal itself. Look at the back of the pedestal. Is it open in the back, or does it have a back panel that encloses it? If the pedestal back is open, this can cause a condition known as "tin-canning", where the sides of the pedestal waffle in and out and begins to bounce when the washer spins. This can be overcome by purchasing a stiffener kit. Look at your pedestal and let me know if this may be the issue with yours. If so, I can provide you with a part number to order.
If you have further question, please let me know. I hope this helps you.
Posted on Feb 12, 2009
mgprice
  • 744 Answers
SOURCE: washer is leaking, but I dont know why
Hello, the most likely cause is the pump. Whirlpools are direct drive machines which means they do not have a belt2.gif. The pump is hooked up directly to the motor. To confirm this is the pump tip the machine back so that you can access it underneath. Make sure you wedge something underneath so it does not fall on you. Next take a look where the pump joins onto the motor shaft, this is where you will find the leak. This pump is a sealed unit so you will have to replace the whole pump. You can do this by removing the inlet and outlet pipes. Next with a screwdriver release the 2 clips holding the pump and remove the pump.....reassemble with new pump in reverse order. Good Luck!! If you have any further question's please feel free to comment. Mike
Posted on Oct 01, 2009
j_alcaidinho
  • 107 Answers
SOURCE: Whirlpool Duet Sport washing machine with a leaking door.
You need to check if the door is not loose on the washer, make sure you tighten all the screws on the door
Posted on Jan 20, 2010
Wont drain in automatic cycles
maybe is necesary to set the drain operation in the automatic cycle,like you can set the temperature of the wather ,the time to prewashing and so on.
Dec 26, 2013 | Whirlpool Washing Machines
My whirlpool duet sport is leaking from the front underneath. Not from the door. When the wash cycle starts it starts spraying water out the bottom. Does not do it when it drains.
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Oct 11, 2011 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
I need a short program for washing and i lost the manual. i don t know how to program it
I have an AWM 5100 and the programs are printed on the outside of the detergent drawer, 1,2,3 prewash cotton, synthetic, delicates, 4 full wash,5 short wash cotton etc..this is not on your machine? Check the Whirlpool site, if no luck, reply here and I will see if I can help more..perhaps I can scan and email to you? but might not be same control options.. my machine also has a rapid wash button, which speeds any cycle.
Good luck
Jun 21, 2010 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool dishwasher stuck on prewash cycle
the eprom memory is brocken,the main board must be changed.
Feb 14, 2010 | Whirlpool 24 in. ADG7952 Built-in...
How to i stop my Whirlpool Gold from leaking water from the bottom? (Fridge on Top, Freezer on Bottom)
This water is accumulated during the automatic defrost cycle, which occurs every 24-hours. A fan is supposed to pull air over it to evaporate it.
Clean all the dust and lint accumulation from under the unit, remove the condensation collection pan and clean it, and make sure the bottom fan is running.
I can't emphasize strongly enough how much of an enemy the accumulation of dirt and dust under a refrigerator can be its worst enemy. It can make the refrigerator exhibit symptoms of much more serious problems. Sometimes a good cleaning can have it operating like new with no real 'repairs' whatsoever.
Aug 22, 2009 | Whirlpool GB2SHDXTS Stainless Steel
Interior water leak on model ET18PKX6HB1 whirlpool refrigerator
The drain is clogged up. Check the clear plastic line that goes from the back to the drip pan on the bottom of the unit.
Mar 30, 2009 | Whirlpool Refrigerator Inverter Box -...
My Whirlpool LSQ8543J has started overflowing after rinse cycle
Replace the water valve where your hoses connect to the washer.
Mar 17, 2009 | Whirlpool LSQ8543J
Whirlpool Fron Load washer. Can not unlock door.
There is a manual way to unlock door. I copyed this from the tech sheet.
Manually Unlocking the
Door Lock System
1. Unplug the power cord from
the outlet.
2. Remove the lower kick panel.
3. Reach up along the inside of
the front and locate the bottom
of the door switch/lock unit.
4. Located on the bottom of the
door switch/lock unit is a
tear-drop shaped tab.
5. Gently pull the tab down about
a ¼” or until a click is heard.
6. The door may be opened.
Also there is a test procedure you can run to check the door lock actuator.
DIAGNOSTIC TEST
The washer must be empty and
the control must be in the OFF
state before pressing the
touchpad sequence to start the
test.
Starting the Test Mode
 Close the door.
 Push CONTROL/ON (if present on
this model).
 Select the DRAIN/SPIN cycle.
 Select NO SPIN by pressing the
SPIN SPEED touchpad.
 Push PREWASH OPTION four
times
within five seconds. (If
PREWASH OPTION is not present
on this model, press RINSE HOLD
four times within five seconds.)
C:00 will light up on the display.
Hope this helps.
Dec 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool calypso clothes washer stuck on the "FL" for overfill code - will not reset after hitting stop/cancel or after unpluging - one year ago the customer service for whirlpool gave us the...
Try pressing the following key pad buttons within 5 seconds - PREWASH OPTIONS - WASH TIME, PREWASH OPTIONS - WASH TIME, in this sequence and allow the washer to run. The LED display will start counting down as the washer begins a sequence of short diagnostics tests. If no error is present, the washer will return to standby. If the error persists, you may have a blockage in your drain pump. Please run the test and let me know the results. Total test time is about 1 minute 40 seconds. I hope this helps you.
Jul 24, 2008 | Whirlpool Washing Machines
Dishwasher leaks out front
If pre-rinsing dishes use only 1 or two teaspoons of soap in the main wash cup..do not put soap in the prewash cup. Excess soap can cause oversudsing and cause water to spill over out the bottom of th door. Use rinse-aid for better drying performance
May 29, 2008 | Dishwashers
Whirlpool Wdt770paym Logo
66 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
