Question about Electronics - Others
Motomaster nautilus battery charger
I have a Nautilus 2/10/15 battery charger. I put in on my boat battery to charge and after an hour or so checked on it and the displaywas blank (no lights) I unplugged it and plugged it back in with no results.It does have kind of a hot electrical smell to it. Is there a reet or a fuse that I can check or any other suggestionsyou may have? Thanks Phil
freetek
  • 5568 Answers
SOURCE: peugeot 106 no electrics
Assuming that the polarity wasn't reversed during the reinstallation, I would check the terminal ends of the battery cables.
One (+) is likely connected to a starter terminal, the other (-) either to the engine block or chassis sheet metal. The latter cable may be fastened to sheet metal and have an additional cable tying the chassis and engine block together.
You should also have a multimeter so you can track down any breaks in the cables and to verify the fuses since these can have broken elements that might not be clearly visible.
Posted on Feb 25, 2009
270rexton
  • 782 Answers
SOURCE: nokia 5800 wont charge?
Use different charger. When charging leave the phone off. Fully charged after 4 hours.
Posted on Jun 10, 2009
SOURCE: Graco nautilus 3 in 1 car seat need help with strap installation
Yeah its a bit tricky. ON the fron of the car seat there is a strap that goes intot he seat and has a button to lossen it. Press it down to lossen that strap then flip seat over and on the bottom you will find other end of the same strap and it has a brass t-fitting. Take it and pull it up the back side of seat and the shoulder straps fit into the brass fitting then tighten by pulling strap in front of chair.
HAve fun ;)
Posted on Jun 25, 2009
Mike258
  • 1498 Answers
SOURCE: The inverter was working when I left the boat, I
Hi Janeosull,
There are all sorts of inverters on the market.
Could you comment back with the make and model please.
Also, ant information on how it was installed (hard wiring?), what it was operating, anything else that might be remotely related
Yhanks
Mike
Posted on Jan 30, 2010
merbuquis358
  • 94 Answers
SOURCE: My Sony Vaio battery light remains orange
Maybe your battery was damage due to over charging it. You need to replace your battery. The desktop icon can says it's fully charged because you have plugged it and those are the indication that your battery was damage if you unplugged the AC power. The battery of the laptop are disposable and it cannot be repaire. The best solution of your problem was to replace your battery.
Posted on May 26, 2010
I have a motomaster nautilus intelligent battery charger, and no matter what I do I have 8's flashing across the screen. is there something that I can do get it working again?
Unplug, and leave it until the ;intelligent' part looses its power and all the voltage in it drains out and it will loose its memory.
After about an hour plug it back in an it will return to factory settings, If there is not an internal problem, it will work the way it did, (All voltages would drain out of most of them in 20 minutes, but a few would hold a charge overnight,) If there is an internal problem the display will go back to the flashing as soon as the 'intelligent memory' detects the problem. Is it possible that the detected problem is a bad battery?
Apr 03, 2018 | Cell Phones
Tip
Ubuntu Nautilus in Action
1.Windows use Windows Explorer, its counterpart in Ubuntu
the Nautilus (file manager in Gnome environment).
2.Nautilus can offer us much more than that, it is enough
to wish to see Nautilus in real action.
3. Nautilus scripts are very powerful
they provide new ways to Handle files.
Right-clicking will become your new powerful weapon.
(1.A) Add a nautilus script:
System> Administration> Synaptic Package Manager
When you open it, you do Reload, Search and install:
nautilus-image-converter
nautilus-wallpaper
nautilus-script-manager
nautilus-script-collection-svn
Nautilus Subversion Management Scripts
nautilus-script-audio-convert
nautilus-share
nautilus-actions
nautilus-gksu
nautilus-open-terminal
rar
unrar
(1.B) After the installation:
Applications> Accessories> Terminal
When you open this copy it (when you ask for your password, type):
gconftool-2 --set --type=bool /apps/nautilus-open-terminal/desktop_opens_home_dir true
(1.C) Rise of Ubuntu and re-entry
System> Quit> Log Out
(1.D) Now you are quite prepared to see the Nautilus in Action
When you right-click, you get new opportunities in addiction,
whether you are on the desktop or in Nautilus, above pictures, etc..
Right-click easy to get:
-Set as wallpaper
change-size image
-open as root (administrator)
-Open Terminal here
-When you have over a file,
Right click> Create Archive. ZIP or. Rar ... the choice is yours ... etc.
on Jan 13, 2010 | Computers & Internet
How many amps to charge a car battery?
most chargers these days regulate the amperage as the battery charges. My Motomaster charger starts off at 16 amps on a depleted or low battery and goes down to 5 amps once fully charged. Battery maintainers put out about 2 amps.
Jun 12, 2014 | Vector Black And Decker High Frequency...
How do i fix Nautilus 5/6 wt. fly fishing reel. Re-assemble spool release side.
There are some videos on youtube.com that may help. Nautilus website does not show how to assemble this reel. Nautilus FW hub assy MOV
May 12, 2014 | Fishing
Just put in this nautilus dishwasher which worked fine in the other house is not working now. Where is the manual restart?
check wiring is the plug in working is check gp outlets are they all reset,check brakers is the cord ok ,were the cord goes to dish washer is it secured?
Aug 29, 2010 | GE Nautilus 24" Built-in Dishwasher
Lost AC charger and lighter adapter - need replacements
Although the MotoMasters are quite popular and are excellent products in most folk's opinions, parts are quite difficult to find. Complete units are in abundance.
Your charger doesn't have to be branded MotoMaster. And charger of approximately 500 to 750 mA and approximately 14 volts will work nicely.
From time to time Canadian Tire have some parts or open box sales. You might check with them. Hope this helps!
Sirwriter
Nov 06, 2009 | Eliminator MotoMaster Mobile Power...
Electronics - Others Logo
180 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
