Question about XR3 29 Team Issue Tire
How to make a conversion on the clutch pedal of Ford XR3 1984
  • 252 Answers
What do you mean a conversion of the pedal? Do you have an automatic? or do you want an Xr3i clutch?
Posted on Oct 16, 2013
How to adjust the clutch on a 1999 Ford escort ZX2
The clutch is not adjustable it is fully hydraulic. That means it is self adjusting, if the clutch pedal engages high on the pedal and the clutch is hard to push you need a new clutch plate and pressure plate.
Mar 18, 2017 | 1999 Ford Escort
Ford everest 2011 3 litre4x4 dual clutch slipping in top gears clutch has only done 40000 long distance kilometers. Help
if hydraulics clutch system , replace the master cylinder ( blockage in compensating port or incorrect clutch pedal adjustment under dash
if cable clutch replace the cable or again adjust the clutch pedal for free play
Jun 10, 2016 | Ford Cars & Trucks
Where is the break safety switch located in a 2009 Ford Fusion
Jeanette, break switch is above brake pedal arm, safety neutral switch is on transmission, clutch pedal safety switch above clutch pedal arm. Links below have pics.
to show your appreciation press the helpful button and follow me on fixya for more tips and info.
06 ford fusion brake light switch replace
How To Test and Replace the Neutral Safety Swtich Inhibitor Switch P0705
Clutch switch behind clutch pedal Ford Focus Forum Ford Focus ST Forum...
Replace master cylinder clutch Ford Focus Forum Ford Focus ST Forum Ford...
Feb 15, 2016 | 2009 Ford Fusion
How adjust the clutch on 2001 ford mustang 3.8
Per the Ford owners manual:
The clutch on your
vehicle is operated by
a cable. As necessary, adjust the clutch as described
below.
1. Turn the engine off and shift into 1 (First).
2. Put your foot under the clutch pedal and gently
pull it up until the pedal stops.
3. Push the clutch pedal down slowly. You will hear a
click as the clutch adjusts itself.
Mar 31, 2012 | 2001 Ford Mustang
The clutch pedal on my 2000 Ford Focus ZTS broke. It seems the pedal itself is not connected to the clutch anymore. Only the pedal spring brings back up the pedal. I therefore cannot shift gears. The rest...
That car has a hydraulic actuated clutch so it could just be low on clutch fluid or one of the pipes going from the pedal to the clutch could be burst.
Feb 06, 2011 | 2000 Ford Focus
Replace mechanical clutch linkage with hydraulic assist type
Below u will find a photo gallery link on the conversion of a 1983 Bronco, the parts are the same for a F150 click on each picture for dialog of what u are looking at, the only way to do this is to find the bell housing used on 1986 through about 1991, the reason is these years used a external type slave cylinder, u will need to find all the parts in the pictures from those model years at a salvage yard, pedal linkage, bell housing clutch release ford and all the brackets and bolts and spacers, the install is easy, u will need to drill some holes to mount the master but as far as the rest goes it is a swap out, the job will take about 12 hours to complete, buy the clutch slave and master new. expect to spend about $500 for the parts
http://www.supermotors.net/registry/2742/12752
allot of guys think this is a waste of time and it is not really that muich of an advantage to use a hydraulic set up, they all think the best conversion for the money is to an automatic trans.
May 23, 2010 | 1988 Ford F 150
How to repair clutch pedal safety start switch on Ford Truck F550, 1999
Clutch Pedal Position (CPP) Switch
The clutch pedal position switch (CPP) is controlled by the clutch pedal. Depressing the clutch pedal manually closes the CPP switch and allows engine cranking. The CPP switch will also deactivate the speed control system.
303-14A: Electronic Engine Controls — Gasoline Engines 1999 F-Super Duty 250-550 Workshop Manual
REMOVAL AND INSTALLATION Clutch Pedal Position (CPP) Switch Removal
  1. sxo~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Always disconnect the battery ground cable prior to working on the electronic engine controls.
    Disconnect the battery ground cable; refer to Section 414-01 .
  1. Disconnect electrical connector from clutch pedal position switch (CPP) (9A837).
  1. Release the clutch pedal position switch (CPP) (11A152) from the orientation clip.
  1. Remove the plastic retainer.
    1. Push the lock tabs together.
    1. Slide the plastic retainer off the clutch pedal position switch.
  1. Remove the clutch pedal position switch.
Installation
  1. Follow the removal procedure in reverse order.
Feb 06, 2010 | 1999 Ford Super Duty F 550
Clutch Problem with 2001 Ford Explorer Sport
might have a fluid leak it is a hydraulic clutch see if there is fluid at the bottom of the trans bell housing
Apr 14, 2009 | 2001 Ford Explorer Sport
99 PSD AUTO-MANUAL CONVERSION KIT ?
It would be cheaper to fix the automatic
Feb 23, 2009 | 1999 Ford F350 Regular Cab
XR3 29 Team Issue Tire Logo
43 people viewed this question
Top Bontrager Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Bontrager Vehicle Part and Accessory Expert? Answer questions, earn points and help others
