Question about Canon PIXMA Pro9000 InkJet Photo Printer
Canon Pixma Pro9000 won't transport the print head carrier. You can slide it freely by hand from one end of the case to the other. It does seem to lift and lower by itself. When you turn the printer on, something is broken and the head does not travel to the left or right. All else spins and rotates like normal. The head carrier won't and then I receive an idiot light notification. Trying to figure out where the broken/missing part is.
  • Canon Master
  • 1,606 Answers
Check the print head drive belt. It should go around a drive pulley on one side of the printer and a spring-loaded tension pulley on the other side. Verify that the tension pulley is keeping the belt from slipping. Also, if you can see the drive pulley with the cover closed ( you may need to shine a light on it), watch to see if it is turning during a print cycle.
Posted on Jul 03, 2017
SOURCE: canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Posted on Apr 03, 2009
  • 2306 Answers
SOURCE: Cannot print 11x14 paper on my Canon Pro9000 printer.
The printing software you are using should have that size for you, I use photo gallery, after you select the image the pop-ups should be your printing software with the paper size choices.
Posted on Sep 10, 2009
  • 787 Answers
SOURCE: Canon PIXMA iP3000 inkjet printer- print head is overheating
Try to remove the print head from printer and turn it on.If starts you need to replace the print head.It's part number is QY6-0064 becouse the old print head QY6-0034 is discontinued.
Posted on Oct 15, 2009
SOURCE: My Canon PIXMA Pro9000 InkJet Photo Printer paper jam error
Had the same problem with mine. Shook it upside down and cleaned it with air cans after reading this solution for other canon printers:
To my surprise, it worked perfectly... and was great stress relief.
Posted on Oct 22, 2009
  • 6826 Answers
SOURCE: Canon PIXMA MP480. Print head slams all the way
The above is a link where you can enter '5100' and it will return 3 possible solutions for the error code 5100.
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press the button. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON button does not shut off the printer.
  2. Wait approximately ten seconds and then press the button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
    Note: It may be necessary to unplug the power cord and retry if the above steps do not clear the error.
--- Secondly, it says that it could have 'packing' material in the printer when new, blocking the movement of the printhead, but I don't think that's the case since you say the carriage seems to move freely.
Posted on Feb 12, 2011
Blurry colorwashed photos from canon pixma pro9000. What can I do to fix this?
Hi there, I located this video about removing the print head and cleaning it. I've had to clean my print head from time to time, so take a look at this video and see if it can give some help. Your printer might not look exactly the same, but you should be able to remove the print head. If cleaning the print head doesn't clean up the color issue, try contacting Cannon support: Canon Contact Us. I wish you best of luck!
-Mr. W
Feb 25, 2015 | Canon PIXMA Pro9000 Printer
Can you fix the magenta tint on all my prints
The magenta print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 22, 2013 | Canon PIXMA Pro9000 Printer
Pixma pro9000 amber light flashing and will not load paper. Printer is not heavily used. I have cleaned the print head and cartridges look good. I have tried holding the printer upside down (its heavy)...
Most likely this is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer and wait for the carriage to slide over
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Nov 05, 2011 | Canon PIXMA Pro9000 Printer
My Canon Pizma Pro9000 prints photos that contain TOO MUCH black in it. All the colors appear to be much darker than on the screen. And when I lighten the pics, it doesn't help since all the shadows are...
I suggest you clean it manually by removing the ink cartridge and rub the print head into a paper with alochol and then run the print nozzle for 2 times to clear some ink residue that cause darken color
Mar 08, 2011 | Canon PIXMA Pro9000 Printer
I get error code 5100. Can't get past it. What to do...
This particular error has a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip.You can find the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display). Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on).
Thank you !!
Aug 09, 2010 | Canon PIXMA Pro9000 InkJet Photo Printer
Canon pixma ip500 horizontal bands of non-printing areas
Mar 18, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Cannon pixma ip1000
..ip1000 questions..'s cleaning time, a simple if messy operation. You will have to clean the print head and the waste ink pads, and whilst there might as well clean all the other gunk as well.. how to do this ?
..power on, open front, let carrier slide to middle front, pull power cable, pull computer cable.
..Remove cartridges hand slide carrier to left to below the grooves in the upper case front. Clip the grey print head retainer, it pivots to the printer back, it must go up in the grooves, then remove print head, it comes forward..
Sep 09, 2008 | Canon PIXMA iP1600 Printer
Printer does not power up
My Canon IP3000 would not turn. It turned out to be the Print Head. It had burnt out and gone short circuit. This caused the built in power supply to shut down, hence, the printer appears dead.
Now, how do you get the Print Head out when it is locked down on the left side (your right side if facing the printer)? Open the top lid and inside you will see a chrome sharft, about 10mm in diameter, that the Print Head slides along. Put you finger under this bar and lift it 3 to 4mm. It's under spring tension. The Print Head will also rise, releasing it from the lock. With your other hand, slide the Print Head to your left. You can now release the bar and move the Print head freely.
To confirm the fault, try to power up the printer with the Print Head removed. Don't forget to put the lock bar down first, to stop it hitting the cover when it tries to go home.
Jul 17, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Looks like your print head is clogged,you will have to clean it with head cleaning fluid.You can buy this solution either over the internet or in one of the good pc stores.good luck Ron
Jul 07, 2008 | Canon PIXMA Pro9000 Printer
Canon PIXMA  Pro9000 InkJet Photo Printer Logo
42 people viewed this question
old marine
old marine
